Commit 30a0329e authored by SOLIMAN Sylvain's avatar SOLIMAN Sylvain
checking conservations from kinetics too, fixes stuff in kinetics on the way
parent 50805643
...@@ -65,6 +65,7 @@ check_conservations :- ...@@ -65,6 +65,7 @@ check_conservations :-
'checks all conservation laws against reactions, and if necessary kinetics 'checks all conservation laws against reactions, and if necessary kinetics
(see also \\command{add_conservation/1}).' (see also \\command{add_conservation/1}).'
compute_ode,
forall( forall(
item([model: current_model, kind: conservation, id: Id]), item([model: current_model, kind: conservation, id: Id]),
...@@ -106,11 +107,12 @@ check_conservation(C) :- ...@@ -106,11 +107,12 @@ check_conservation(C) :-
message('~w checked from reactions', [C]) message('~w checked from reactions', [C])
message('~w not checked from reactions', [C]),
check_conserv_num(C) check_conserv_num(C)
message('~w checked from kinetics', [C]) message('~w checked from kinetics', [C])
message('~w trusted but not checked', [C]), message('~w not checked from kinetics either, but trusted anyway', [C]),
throw(error(unchecked_conservation_law(C))) throw(error(unchecked_conservation_law(C)))
...@@ -128,8 +130,18 @@ check_conserv_reactions(C) :- ...@@ -128,8 +130,18 @@ check_conserv_reactions(C) :-
check_conserv_num(_) :- check_conserv_num(C) :-
fail. get_weighted_ode(C, WeightedSum),
simplify(WeightedSum, Sum),
write(Sum), nl,
Sum == 0.
get_weighted_ode([], 0).
get_weighted_ode([K*M | L], K*O + S) :-
ode(M, O),
get_weighted_ode(L, S).
scalar_conservation([], _, 0). scalar_conservation([], _, 0).
...@@ -69,6 +69,20 @@ test( ...@@ -69,6 +69,20 @@ test(
with_output_to(atom(_), command(check_conservations)). with_output_to(atom(_), command(check_conservations)).
test(
'check_conservations is ok with kinetically conserved moieties',
setup(models:clear_model),
cleanup(models:clear_model)
% writing with 'command' produces a parsing error on k…
add_reaction('for'(k*[a], '=>'(a, b))),
add_reaction('for'(k*[a], '=>'(a, 2*a))),
command(add_conservation(a)),
test( test(
'check_conservations is unhappy with non-conserved moieties', 'check_conservations is unhappy with non-conserved moieties',
...@@ -10,6 +10,8 @@ kinetics(Kinetics, Reactants, Expression) :- ...@@ -10,6 +10,8 @@ kinetics(Kinetics, Reactants, Expression) :-
Kinetics = 'MA'(Coefficient) Kinetics = 'MA'(Coefficient)
mass_action(Coefficient, Reactants, Expression) mass_action(Coefficient, Reactants, Expression)
Expression = Kinetics
...@@ -21,5 +23,5 @@ mass_action(Coefficient, Reactants, Expression) :- ...@@ -21,5 +23,5 @@ mass_action(Coefficient, Reactants, Expression) :-
concentration_product([], 1). concentration_product([], 1).
concentration_product([Coefficient * Reactant | Reactants], Product) :- concentration_product([Coefficient * Reactant | Reactants], Product) :-
Product = Coefficient * [Reactant] * ProductTail, Product = [Reactant] ^ Coefficient * ProductTail,
concentration_product(Reactants, ProductTail). concentration_product(Reactants, ProductTail).
...@@ -20,8 +20,8 @@ list_ODE :- ...@@ -20,8 +20,8 @@ list_ODE :-
compute_ode :- compute_ode :-
retractall(ode(_, _)), retractall(ode(_, _)),
item([model: current_model, kind: rule, item: Item]), item([model: current_model, kind: reaction, item: Item]),
rule(Item, Kinetics, Reactants, Products), reaction(Item, Kinetics, Reactants, Products),
kinetics(Kinetics, Reactants, KineticsExpression), kinetics(Kinetics, Reactants, KineticsExpression),
add_molecules(Reactants, -KineticsExpression), add_molecules(Reactants, -KineticsExpression),
...@@ -58,7 +58,7 @@ add_molecule(Coefficient * Molecule, Kinetics) :- ...@@ -58,7 +58,7 @@ add_molecule(Coefficient * Molecule, Kinetics) :-
Expression = 0 Expression = 0
asserta(ode(Molecule, Expression + Kinetics / Coefficient)). asserta(ode(Molecule, Expression + Coefficient * Kinetics )).
print_ode :- print_ode :-
...@@ -118,6 +118,17 @@ simplify_addition(A, Value * B, Result) :- ...@@ -118,6 +118,17 @@ simplify_addition(A, Value * B, Result) :-
ValueOpp is -Value, ValueOpp is -Value,
Result = A - ValueOpp * B. Result = A - ValueOpp * B.
simplify_addition(-A, B, C) :-
simplify_difference(B, A, C).
simplify_addition(A, -B, C) :-
simplify_difference(A, B, C).
simplify_addition(A, A, 2 * A) :-
simplify_addition(A, B, A + B). simplify_addition(A, B, A + B).
...@@ -148,6 +159,17 @@ simplify_difference(A, Value * B, Result) :- ...@@ -148,6 +159,17 @@ simplify_difference(A, Value * B, Result) :-
Result = A + ValueOpp * B. Result = A + ValueOpp * B.
simplify_difference(A, A, 0) :-
simplify_difference(A, -B, C) :-
simplify_addition(A, B, C).
simplify_difference(-A, B, -C) :-
simplify_difference(A, B, A - B). simplify_difference(A, B, A - B).
