Commit fa60c634 authored by SOLIMAN Sylvain's avatar SOLIMAN Sylvain
Better…
parent 8125cbec
...@@ -171,12 +171,13 @@ ...@@ -171,12 +171,13 @@
%% Cell type:markdown id: tags: %% Cell type:markdown id: tags:
## Question 5 ## Question 5
Now try PAC learning on that model, choosing yourself the number of initial states and simulation lenght. Now try PAC learning on that model, choosing yourself the number of initial states and simulation lenght, so that you are satisfied with the result.
Are you satisfied with the result?
What happens if you impose `cnf_clause_size: 1`? How would you expect that to be reflected in the behavior of the model?
%% Cell type:code id: tags: %% Cell type:code id: tags:
