Commit e2c36b46 authored by Thierry Martinez's avatar Thierry Martinez
Merged Makefile
parents dd83b3c6 b4253594
MODULES=$(shell sed -n -E 's/^- (.*\.plt?)$$/\1/p' toc.org) MODULES=$(shell sed -n -E 's/^- (.*\.pl)$$/\1/p' toc.org)
# load_test_files/1 should make this useless, but I cannot find how to use it
TEST_MODULES=$(wildcard $(MODULES:.pl=.plt))
all: biocham biocham_debug tests doc all: biocham biocham_debug tests doc
...@@ -17,9 +19,9 @@ tests: biocham_tests ...@@ -17,9 +19,9 @@ tests: biocham_tests
doc: biocham doc: biocham
./biocham --generate-doc ./biocham --generate-doc
biocham_tests: $(MODULES) Makefile biocham_tests: $(MODULES) $(TEST_MODULES) Makefile
swipl -o biocham_tests \ swipl -o biocham_tests \
--goal="call_cleanup((run_tests, halt(0)), halt(1))" -c $(MODULES) --goal="call_cleanup((run_tests, halt(0)), halt(1))" -c $(MODULES) $(TEST_MODULES)
clean: clean:
-rm -f biocham biocham_debug biocham_tests -rm -f biocham biocham_debug biocham_tests
...@@ -15,6 +15,8 @@ test( ...@@ -15,6 +15,8 @@ test(
command(add_conservation(a-a + 2*a)), command(add_conservation(a-a + 2*a)),
all_items([model: current_model, kind: conservation], Conservations). all_items([model: current_model, kind: conservation], Conservations).
%%% FIXME should test that conservations are properly used for numerical
%%% integration
test( test(
'delete_conservation deletes the correct conservation', 'delete_conservation deletes the correct conservation',
...@@ -44,7 +46,8 @@ test( ...@@ -44,7 +46,8 @@ test(
'check_conservations is ok with trivial P-invariants', 'check_conservations is ok with trivial P-invariants',
setup(models:clear_model), setup(models:clear_model),
cleanup(models:clear_model) cleanup(models:clear_model),
blocked(not_implemented)
% not written 'a => b' to allow flycheck by separate compilation… % not written 'a => b' to allow flycheck by separate compilation…
...@@ -53,6 +56,21 @@ test( ...@@ -53,6 +56,21 @@ test(
command(check_conservations). command(check_conservations).
test(
'check_conservations is unhappy with non-conserved moieties',
error(unproven_conservation_law([1*'a', 2*'b'])),
fixme(not_implemented)
command(add_rule('=>'(a, b))),
command(add_conservation(a + 2*b)),
add_some_conservations :- add_some_conservations :-
command(add_conservation(b-b + 2*b)), command(add_conservation(b-b + 2*b)),
...@@ -2,16 +2,13 @@ ...@@ -2,16 +2,13 @@
** Overview ** Overview
- doc.pl - doc.pl
- biocham.pl - biocham.pl
- biocham.plt
- about.pl - about.pl
** Installing and Running Biocham Locally ** Installing and Running Biocham Locally
- commandline.pl - commandline.pl
- util.pl - util.pl
- simplify_arithmetic.pl - simplify_arithmetic.pl
- formal_derivation.pl - formal_derivation.pl
- formal_derivation.plt
- gsl.pl - gsl.pl
- gsl.plt
- counters.pl - counters.pl
** About this manual ** About this manual
- filename.pl - filename.pl
...@@ -30,44 +27,34 @@ ...@@ -30,44 +27,34 @@
** Loading, listing and exporting models ** Loading, listing and exporting models
*** Biocham files *** Biocham files
- models.pl - models.pl
- models.plt
*** SBML files *** SBML files
*** ODE files *** ODE files
*** Graphics files *** Graphics files
*** Other files *** Other files
- nusmv.pl - nusmv.pl
- nusmv.plt
** Listing and editing rules and events ** Listing and editing rules and events
*** Rules *** Rules
- rule_editor.pl - rule_editor.pl
- rule_editor.plt
- ode.pl - ode.pl
*** Events *** Events
- events.pl - events.pl
** Listing and defining initial states, molecules and locations ** Listing and defining initial states, molecules and locations
*** Initial state *** Initial state
- initial_state.pl - initial_state.pl
- initial_state.plt
** Listing and declaring parameters, macros, aliases and invariants ** Listing and declaring parameters, macros, aliases and invariants
*** Parameters *** Parameters
- parameters.pl - parameters.pl
- parameters.plt
*** Macros *** Macros
- macros.pl - macros.pl
- macros.plt
*** Aliases *** Aliases
- aliases.pl - aliases.pl
- aliases.plt
*** Algebraic invariants, conservation laws and P-invariants *** Algebraic invariants, conservation laws and P-invariants
- conservation_laws.pl - conservation_laws.pl
- conservation_laws.plt
** Simulations ** Simulations
*** ODE and stochastic simulations *** ODE and stochastic simulations
- numerical_simulation.pl - numerical_simulation.pl
- numerical_simulation.plt
*** Traces *** Traces
- traces.pl - traces.pl
- traces.plt
* Index * Index
+ index + index
* Bibliography * Bibliography
