Commit c4edc110 authored by Mathieu Hemery's avatar Mathieu Hemery
Avoid redundancy in code
parent f83bef10
...@@ -16,12 +16,14 @@ ...@@ -16,12 +16,14 @@
matrix_sum/3, matrix_sum/3,
create_diag_matrix/3, create_diag_matrix/3,
sub_matrix/1, sub_matrix/1,
row_sum/3,
transpose_matrix/2, transpose_matrix/2,
lusubst/2, lusubst/2,
solve_linear_problem/3 solve_linear_problem/3
:- use_module(util).
/* Module Matrix /* Module Matrix
* Several operations are done on a "global variable" of SWI-prolog (using nb_set/getval) * Several operations are done on a "global variable" of SWI-prolog (using nb_set/getval)
...@@ -323,17 +325,10 @@ matrix_apply([Row|Matrix],Vector,[ResultElement|ResultVector]):- ...@@ -323,17 +325,10 @@ matrix_apply([Row|Matrix],Vector,[ResultElement|ResultVector]):-
matrix_sum([],[],[]). matrix_sum([],[],[]).
matrix_sum([RowA|MatrixA],[RowB|MatrixB],[SumRow|SumMatrix]):- matrix_sum([RowA|MatrixA],[RowB|MatrixB],[SumRow|SumMatrix]):-
row_sum(RowA,RowB,SumRow), add_list(RowA,RowB,SumRow),
matrix_sum(MatrixA,MatrixB,SumMatrix). matrix_sum(MatrixA,MatrixB,SumMatrix).
row_sum([],[],[]).
row_sum([ElementA|RowA],[ElementB|Row2],[SumElement|SumRow]):-
SumElement is ElementA+ElementB,
row_sum(RowA,Row2,SumRow).
%! create_diag_matrix(+Size, +Value, -Diag_matrix) %! create_diag_matrix(+Size, +Value, -Diag_matrix)
% Store a diagonal matrix in the global variable and return it % Store a diagonal matrix in the global variable and return it
...@@ -919,6 +919,11 @@ test_condition(State,Time,Condition1 or Condition2,Result) :- ...@@ -919,6 +919,11 @@ test_condition(State,Time,Condition1 or Condition2,Result) :-
Result = false Result = false
%! apply_changes(State, Time, Condition)
% to be called when an events is triggered
apply_changes(State,Time, Parameter = (if Condition then IfTrue else IfFalse)) :- apply_changes(State,Time, Parameter = (if Condition then IfTrue else IfFalse)) :-
test_condition(State,_,Condition,Result), test_condition(State,_,Condition,Result),
...@@ -938,6 +943,12 @@ apply_changes(State,Time, Parameter = Expression) :- ...@@ -938,6 +943,12 @@ apply_changes(State,Time, Parameter = Expression) :-
nb_setval(parameters_list,NewParameters). nb_setval(parameters_list,NewParameters).
/* Euler method */
%! euler(+Equations, +Time, +CurrentState, +CurrentTable)
euler(Equations,Time,CurrentState,CurrentTable) :- euler(Equations,Time,CurrentState,CurrentTable) :-
format("One event occured ~n",[]), format("One event occured ~n",[]),
retractall(euler_last_state(_,_)), retractall(euler_last_state(_,_)),
...@@ -965,11 +976,14 @@ euler(Equations,Time,CurrentState,CurrentTable) :- ...@@ -965,11 +976,14 @@ euler(Equations,Time,CurrentState,CurrentTable) :-
nb_setval(last_time,TimeNewState). nb_setval(last_time,TimeNewState).
%! euler_step(+Equations, +CurrentState, +StepSize, +Parameters, -NewCurrentState)
euler_step(Equations,CurrentState,StepSize,Parameters,NewCurrentState) :- euler_step(Equations,CurrentState,StepSize,Parameters,NewCurrentState) :-
eval_state(CurrentState,Parameters,EvaluatedCurrentState), eval_state(CurrentState,Parameters,EvaluatedCurrentState),
eval_row(Equations,CurrentState,Parameters,EvaluatedEquations), eval_row(Equations,CurrentState,Parameters,EvaluatedEquations),
multiply_list(EvaluatedEquations,StepSize,TrueEvaluatedEquations), multiply_list(EvaluatedEquations,StepSize,TrueEvaluatedEquations),
row_sum(EvaluatedCurrentState,TrueEvaluatedEquations,NewCurrentState). add_list(EvaluatedCurrentState,TrueEvaluatedEquations,NewCurrentState).
/*:- doc('\\begin{example}Ball simulation using event:'). /*:- doc('\\begin{example}Ball simulation using event:').
:- biocham_silent(clear_model). :- biocham_silent(clear_model).
Supports Markdown
