Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit b2a8559f authored by Thierry Martinez's avatar Thierry Martinez
LaTeX commands!
parent 8689e7be
MODULES=$(shell sed -n 's/^- \(.*\.pl\(t\?\)\)$$/\1/p' toc.org) MODULES=$(shell sed -n -E 's/^- (.*\.plt?)$$/\1/p' toc.org)
all: biocham biocham_debug tests doc all: biocham biocham_debug tests doc
...@@ -11,6 +11,20 @@ ...@@ -11,6 +11,20 @@
:- doc(' :- doc('
The Biochemical Abstract Machine (Biocham) is a software environment for The Biochemical Abstract Machine (Biocham) is a software environment for
modeling and analyzing biochemical systems. modeling and analyzing biochemical systems.
Biocham is mainly composed of :
\\begin{itemize}
\\item a rule-based language for modeling biochemical systems (compatible with
SBML and SBGN),
\\item different simulators (Boolean, differential, stochastic),
\\item a temporal logic based language to formalize the temporal properties of
a biological system and validate models with respect to such specifications,
\\item unique features for developing/correcting/completing/reducing/coupling
models, including the inference of kinetic parameters in high dimension from
temporal logic constraints.
\\end{itemize}
Biocham is a free software protected by the GNU General Public License GPL
version 2. This is an Open Source license that allows free usage of this
software.
start :- start :-
...@@ -761,32 +761,45 @@ write_command(index, Key, Doc) :- ...@@ -761,32 +761,45 @@ write_command(index, Key, Doc) :-
write_command(begin, itemize, Doc) :- write_command(begin, itemize, Doc) :-
nb_setvar(opened_li, false), nb_setval(opened_li, false),
write(Doc, '<ul>'). write(Doc, '<ul>').
write_command(begin, enumerate, Doc) :- write_command(begin, enumerate, Doc) :-
write(Doc, '<ol>'). write(Doc, '<ol>').
write_command(item, Argument, Doc) :- write_command(item, Argument, Doc) :-
( close_opened_li(Doc),
nb_getvar(opened_li, true) write(Doc, '<li>'),
write(Doc, '</li>'),
nb
true
atom_chars(Argument, ArgumentChars), atom_chars(Argument, ArgumentChars),
write_doc_chars(ArgumentChars, Doc), write_doc_chars(ArgumentChars, Doc).
write(Doc, Argu).
write_command(end, itemize, Doc) :-
write(Doc, '</ul>').
write_command(end, enumerate, Doc) :-
write(Doc, '</ol>').
write_command(Command, _Argument, _Doc) :- write_command(Command, _Argument, _Doc) :-
throw(error(unknown_command(Command))). throw(error(unknown_command(Command))).
close_opened_li(Doc) :-
nb_getval(opened_li, true)
true
:- dynamic(index_contents/2). :- dynamic(index_contents/2).
