Commit a3911976 authored by SOLIMAN Sylvain's avatar SOLIMAN Sylvain
handle molecules defined only in query
parent 14434ad2
......@@ -58,7 +58,6 @@ export_nusmv_stream_reactions(Stream) :-
findall(
(Reactants, [], Products, []),
% FIXME we do not take care of reversible reactions
item([kind: reaction, item: Item]),
reaction(Item, _, Reactants, Products)
......@@ -85,7 +84,15 @@ enumerate_all_molecules(Molecules) :-
InfluenceMolecules = []
union(ReactionMolecules, InfluenceMolecules, Molecules).
union(ReactionMolecules, InfluenceMolecules, ModelMolecules),
query_mols(QueryMolecules)
true
QueryMolecules = []
union(ModelMolecules, QueryMolecules, Molecules).
export_initial_state(Stream, Molecules) :-
......@@ -476,11 +483,17 @@ check_ctl_impl(Query, some, NusmvCX, BoolSem, Result) :-
:- dynamic(trace/1).
% stores unknown molecules coming from the query
:- dynamic(query_mols/1).
% care that if Result is instantiated, the predicate might fail before parsing
% the full output/trace
check_ctl_impl(Query, all, NusmvCX, BoolSem, Result) :-
retractall(trace(_)),
normalize_query(Query, NQuery),
retractall(query_mols(_)),
normalize_query(Query, NQuery, Mols),
assertz(query_mols(Mols)),
translate_ctl_for_nusmv(NQuery, NusmvQuery),
% FIXME better template, in $TMP, check if not existing, etc.
export_nusmv_file(nusmv, BoolSem),
......@@ -628,3 +641,7 @@ parse_nusmv_out_trace(Out) :-
state_string_to_trace(String, Trace) :-
split_string(String, "\t", "\t", [_ | Trace]).
prolog:message(error(unknown_molecule)) -->
['Unknown molecule in query.'].
......@@ -19,7 +19,7 @@ revise_model(Query) :-
'Use theory-revision on the current model to satisfy the query given as
argument. cf. \\texttt{CCFS05tcsb}.'
normalize_query(Query, NQuery, _),
categorize_query(NQuery, ECTL, UCTL, ACTL),
nb_setval(need_recheck, false),
revise_model(ECTL, UCTL, ACTL, [], [], []).
......@@ -30,7 +30,6 @@ revise_model(Query) :-
revise_model([E | ECTL], UCTL, ACTL, Et, Ut, At) :-
item([kind: option, item: option(nusmv_initial_states: Init)]),
item([kind: option, item: option(boolean_semantics: Bool)]),
write(checking(E)),nl,
check_ctl_impl(E, Init, no, Bool, true)
......@@ -47,7 +46,6 @@ revise_model([E | ECTL], UCTL, ACTL, Et, Ut, At) :-
revise_model([], [U | UCTL], ACTL, Et, Ut, At) :-
write(checking(U)),nl,
check_ctl_impl(U, Init, no, Bool, true)
......@@ -71,7 +69,6 @@ revise_model([], [U | UCTL], ACTL, Et, Ut, At) :-
revise_model([], [], [A | ACTL], Et, Ut, At) :-
write(checking(A)),nl,
check_ctl_impl(A, Init, silent, Bool, Result),
Result = true
......@@ -80,10 +77,7 @@ revise_model([], [], [A | ACTL], Et, Ut, At) :-
% we only consider adding U' and E' when A is fully satisfied, thus moving
% a step from the A' step of the algorithm to the A step
% FIXME check At too since self-loops can be added by removing a reaction
write(split(Et, Ut)),nl,
check_and_split(Et, Ut, [], Ett, Utt, [], Eprime, Uprime, [], Init, Bool),
write(true(Ett, Utt)),nl,
write(false(Eprime, Uprime)),nl,
revise_model(Eprime, Uprime, ACTL, Ett, Utt, [A | At])
print_message(informational, step('A''')),
