Commit 995af213 authored by SOLIMAN Sylvain's avatar SOLIMAN Sylvain
fixing stuff again
parent f1f10a97
...@@ -42,9 +42,8 @@ revise_model([E | ECTL], UCTL, ACTL, Et, Ut, At) :- ...@@ -42,9 +42,8 @@ revise_model([E | ECTL], UCTL, ACTL, Et, Ut, At) :-
revise_model([], [U | UCTL], ACTL, Et, Ut, At) :- revise_model([], [U | UCTL], ACTL, Et, Ut, At) :-
item([kind: option, item: option(nusmv_initial_states: Init)]), item([kind: option, item: option(nusmv_initial_states: Init)]),
item([kind: option, item: option(boolean_semantics: Bool)]), item([kind: option, item: option(boolean_semantics: Bool)]),
check_ctl_impl(U, Init, silent, Bool, Result),
Result = true check_ctl_impl(U, Init, no, Bool, true)
print_message(informational, step('U')) print_message(informational, step('U'))
...@@ -55,7 +54,7 @@ revise_model([], [U | UCTL], ACTL, Et, Ut, At) :- ...@@ -55,7 +54,7 @@ revise_model([], [U | UCTL], ACTL, Et, Ut, At) :-
append([U | Ut], At, AllSpec) append([U | Ut], At, AllSpec)
print_message(informational, step('U''''')), print_message(informational, step('U''''')),
find_and_delete_rules, delete_rules,
% FIXME check At too since self-loops can be added by removing a reaction % FIXME check At too since self-loops can be added by removing a reaction
append([U | Ut], Et, AllSpec) append([U | Ut], Et, AllSpec)
...@@ -74,10 +73,17 @@ revise_model([], [], [A | ACTL], Et, Ut, At) :- ...@@ -74,10 +73,17 @@ revise_model([], [], [A | ACTL], Et, Ut, At) :-
revise_model([], [], ACTL, Et, Ut, [A | At]) revise_model([], [], ACTL, Et, Ut, [A | At])
print_message(informational, step('A''')), print_message(informational, step('A''')),
list_reactions, (
find_and_delete_rules, nusmv:trace(_)
delete_rules_from_trace,
append(Ut, Et, AllSpec), append(Ut, Et, AllSpec)
delete_rules,
% we delete blindly, so we need to check A now
append([A | Ut], Et, AllSpec)
% FIXME the published algorithm actually allows to not re-check, but % FIXME the published algorithm actually allows to not re-check, but
% simply split and add again to the formulae to be verified % simply split and add again to the formulae to be verified
recheck_spec(AllSpec, Init, Bool), recheck_spec(AllSpec, Init, Bool),
...@@ -216,7 +222,6 @@ find_rule(R) :- ...@@ -216,7 +222,6 @@ find_rule(R) :-
add_reaction_backtracking(R) :- add_reaction_backtracking(R) :-
add_item([kind: reaction, item: R]), add_item([kind: reaction, item: R]),
% list_reactions,nl,
print_message(informational, added(R)) print_message(informational, added(R))
delete_item([kind: reaction, item: R]), delete_item([kind: reaction, item: R]),
...@@ -226,16 +231,6 @@ add_reaction_backtracking(R) :- ...@@ -226,16 +231,6 @@ add_reaction_backtracking(R) :-
find_and_delete_rules :-
nusmv:trace(_)
delete_rules
delete_rules_from_trace :- delete_rules_from_trace :-
enumerate_all_molecules(Molecules), enumerate_all_molecules(Molecules),
findall(State, nusmv:trace(State), States), findall(State, nusmv:trace(State), States),
