Commit 77373bd6 authored by SOLIMAN Sylvain's avatar SOLIMAN Sylvain
text in ball.ipynb
parent 2b239d53
...@@ -8,7 +8,7 @@ ...@@ -8,7 +8,7 @@
about/0 about/0
version('4.1.8'). version('4.1.9').
copyright( copyright(
'Copyright (C) 2003-2018 Inria, EPI Lifeware, Saclay-Île de France, France' 'Copyright (C) 2003-2018 Inria, EPI Lifeware, Saclay-Île de France, France'
%% Cell type:markdown id: tags: %% Cell type:markdown id: tags:
# Bouncing ball example # Bouncing ball example
classical example of the hybrid system community classical example of the hybrid system community (https://github.com/dreal/dreal2/tree/master/benchmarks/hybrid_systems/bouncing_ball)
implemented here with reactions and events implemented here with reactions and events
%% Cell type:code id: tags: %% Cell type:code id: tags:
load(ball.bc). load(ball.bc).
list_model. list_model.
%%%% Output: execute_result %%%% Output: execute_result
MA(c)for _=[v]=>x. MA(c)for _=[v]=>x.
g/c for v=>_. g/c for v=>_.
MA(D*c)for v=[v]=>_. MA(D*c)for v=[v]=>_.
present(x,x0). present(x,x0).
present(y,3.5). present(y,3.5).
parameter( parameter(
x0 = 8.725, x0 = 8.725,
D = -0.05, D = -0.05,
K = 0.75, K = 0.75,
g = 9.8, g = 9.8,
c = 1.0 c = 1.0
add_event(x<=0, c = -K*c). add_event(x<=0, c = -K*c).
list_ode. list_ode.
[0] d(v)/dt= -1*g/c-D*c*v^2 [0] d(v)/dt= -1*g/c-D*c*v^2
[1] d(x)/dt=c*v [1] d(x)/dt=c*v
[2] d(y)/dt=0 [2] d(y)/dt=0
# Numerical simulation # Numerical simulation
In a hybrid system numerical simulations are relatively time consuming due to the necessity of precisely checking the satisfaction time of events In a hybrid system numerical simulations are relatively time consuming due to the necessity of precisely checking the satisfaction time of events
numerical_simulation. plot. numerical_simulation. plot.
%%%% Output: display_data %%%% Output: display_data
# Model robustness to parameter perturbations # Model robustness to parameter perturbations
Statistical evaluation by sampling the parameter space Statistical evaluation by sampling the parameter space
This is time consuming since it involves making one simulation for each parameter set This is time consuming since it involves making one simulation for each parameter set
The FO-LTL formula defines the amplitude range of x in the domain of the free variable h The FO-LTL formula defines the height of the first bounce of x in the domain of the free variable h
The amplitude 3.96 exceeds here the objective of 3.5, the satisfaction degree is thus greater than one showing some formula robustness The height 3.96 exceeds here the objective of 3.5, the satisfaction degree is thus greater than one showing some formula robustness
However the model robustness w.r.t. (default) parameter perturbations is below one (0.88) showing that some parameter perturbations destroy the amplitude objective. However the model robustness w.r.t. (default) parameter perturbations is below one (0.88) showing that some parameter perturbations destroy the height objective.
%timeout 180 %timeout 180
Timeout set to 180 Timeout set to 180
validity_domain(F(x < h /\ F(x > h))). validity_domain(F(x < h /\ F(x > h))).
h<3.96646/\h> -1.0e-6 h<3.96646/\h> -1.0e-6
satisfaction_degree(F(x < h /\ F(x > h)), [h -> 3.5]). satisfaction_degree(F(x < h /\ F(x > h)), [h -> 3.5]).
1.466440 1.466440
seed(0). seed(0).
robustness(F(x < h /\ F(x > h)), [x0, K, D], [h -> 3.5]). robustness(F(x < h /\ F(x > h)), [x0, K, D], [h -> 3.5]).
Time: 158.027 s Time: 158.027 s
Robustness degree: 0.88414 Robustness degree: 0.88414
# Formula robustness # Formula robustness
With a satisfaction degree greater than 1 the formula is already satisfied with some margin With a satisfaction degree greater than 1 the formula is already satisfied with some margin
Formula robustness can be further optimized by parameter optimization with formula robustness as objective function with no extra cost and much faster computation time than for estimating model robustness Formula robustness can be further optimized by parameter optimization with formula robustness as objective function with no extra cost and much faster computation time than for estimating model robustness
It gives an amplitude of 4.84 which obviously improves the satisfaction degree of the formula It gives a height of 4.84 which obviously improves the satisfaction degree of the formula
This is shown to also improve the model robustness (0.93) to parameter perturbations as expected in many examples This is shown to also improve the model robustness (0.93) to parameter perturbations as expected in many examples
seed(0). seed(0).
search_parameters(F(x < h /\ F(x > h)), [5 <= x0 <= 10, 0.5 <= K <= 1.0 , -0.1 <= D <= 0.0], [h -> 3.5], cmaes_stop_fitness: -0.5). search_parameters(F(x < h /\ F(x > h)), [5 <= x0 <= 10, 0.5 <= K <= 1.0 , -0.1 <= D <= 0.0], [h -> 3.5], cmaes_stop_fitness: -0.5).
Time: 27.491 s Time: 27.491 s
Stopping reason: Fitness: function value -5.72e-01 <= stopFitness (-5.00e-01) Stopping reason: Fitness: function value -5.72e-01 <= stopFitness (-5.00e-01)
Best satisfaction degree: 2.339136 Best satisfaction degree: 2.339136
[0] parameter(x0=9.555198250463423) [0] parameter(x0=9.555198250463423)
[1] parameter(K=0.8014006370116868) [1] parameter(K=0.8014006370116868)
[2] parameter(D= -0.058468364144163905) [2] parameter(D= -0.058468364144163905)
h<4.83916/\h> -1.0e-6 h<4.83916/\h> -1.0e-6
2.339120 2.339120
seed(0). seed(0).
Time: 100.736 s Time: 100.736 s
Robustness degree: 0.930547 Robustness degree: 0.930547
