Commit 74a7faf6 authored by HEMERY Mathieu's avatar HEMERY Mathieu
Add tests for rosenbrock events
parent 9faf5fe7
...@@ -7,7 +7,7 @@ option( ...@@ -7,7 +7,7 @@ option(
error_epsilon_relative: 1e-6, error_epsilon_relative: 1e-6,
initial_step_size: 1e-6, initial_step_size: 1e-6,
maximum_step_size: 1e-2, maximum_step_size: 1e-2,
minimum_step_size: 1e-4, minimum_step_size: 1e-5,
precision: 6, %5 precision: 6, %5
nusmv_initial_states: all, nusmv_initial_states: all,
nusmv_counter_example: no, nusmv_counter_example: no,
...@@ -18,6 +18,13 @@ check_integration_2([Head|Tail], Epsilon) :- ...@@ -18,6 +18,13 @@ check_integration_2([Head|Tail], Epsilon) :-
ValueS is sin(T), near(ValueS, Sin, Epsilon), ValueS is sin(T), near(ValueS, Sin, Epsilon),
check_integration_2(Tail, Epsilon). check_integration_2(Tail, Epsilon).
check_integration_ball([], _Epsilon) :- !.
check_integration_ball([Head|Tail], Epsilon) :-
Head = row(_T,_TT,X,_Y),
X >= -Epsilon,
check_integration_ball(Tail, Epsilon).
:- begin_tests(rosenbrock). :- begin_tests(rosenbrock).
test(eva_coeff_1) :- test(eva_coeff_1) :-
...@@ -52,4 +59,22 @@ test(cosinus_integration, [setup(command(clear_model)), cleanup(command(clear_mo ...@@ -52,4 +59,22 @@ test(cosinus_integration, [setup(command(clear_model)), cleanup(command(clear_mo
get_table_data(D), get_table_data(D),
check_integration_2(D, 1e-5). check_integration_2(D, 1e-5).
test(test_ball, [setup(command(clear_model)), cleanup(command(clear_model))]) :-
command(load("library/examples/RobustMonitoring/ball.bc")),
command(option(maximum_step_size:1e-2)),
command(numerical_simulation(method:rsbk)),
get_table_data(D),
check_integration_ball(D, 1e-3).
test(test_time_event, [setup(command(clear_model)), cleanup(command(clear_model))]) :-
command(k*a for a => b),
command(present(a,1.0)),
command(parameter(k=1)),
command(add_event('Time'>2, k=0)),
command(add_event('Time'>=4, k=1)),
command(numerical_simulation(method:rsbk, time:5)),
get_table_data(D),
last(D, row(T,_B,A)),
near(A, exp(2-T), 1e-5).
:- end_tests(rosenbrock). :- end_tests(rosenbrock).
