Commit 5c2ec4e5 authored by Thierry Martinez's avatar Thierry Martinez
More robust graph API
parent 1f4edde9
:- module( :- module(
graph_editor, graph_editor,
% Grammars
edge/1,
edgeref/1,
% Commands
new_graph/0, new_graph/0,
delete_graph/1, delete_graph/1,
set_graph_name/1, set_graph_name/1,
...@@ -8,9 +12,7 @@ ...@@ -8,9 +12,7 @@
select_graph/1, select_graph/1,
add_vertex/1, add_vertex/1,
delete_vertex/1, delete_vertex/1,
edge/1,
add_edge/1, add_edge/1,
edgeref/1,
delete_edge/1, delete_edge/1,
list_edges/0, list_edges/0,
list_isolated_vertices/0, list_isolated_vertices/0,
...@@ -22,21 +24,51 @@ ...@@ -22,21 +24,51 @@
list_attributes/1, list_attributes/1,
place/1, place/1,
transition/1, transition/1,
% Public API
new_graph/1,
set_graph_name/2,
get_current_graph/1, get_current_graph/1,
set_current_graph/1, set_current_graph/1,
get_graph_name/2, get_graph_name/2,
get_attribute/2 get_attribute/2,
get_attribute/3,
set_attribute/3,
place/2,
transition/2,
kind/3,
add_vertex/3,
add_edge/3
:- devdoc('\\section{Grammars}').
:- grammar(edge).
edge(From -> To) :-
name(From),
name(To).
:- grammar(edgeref).
edgeref(Edge) :-
edge(Edge).
:- devdoc('\\section{Commands}'). :- devdoc('\\section{Commands}').
new_graph :- new_graph :-
biocham_command, biocham_command,
doc('Creates a new graph.'), doc('Creates a new graph.'),
add_item([kind: graph, key: new_graph, id: Id]), new_graph(Id),
set_current_graph(Id). set_current_graph(Id).
...@@ -52,7 +84,7 @@ set_graph_name(Name) :- ...@@ -52,7 +84,7 @@ set_graph_name(Name) :-
type(Name, name), type(Name, name),
doc('Sets the name of the current graph.'), doc('Sets the name of the current graph.'),
get_current_graph(Id), get_current_graph(Id),
replace_item(Id, graph, Name, Name). set_graph_name(Id, Name).
list_graphs :- list_graphs :-
...@@ -73,10 +105,11 @@ add_vertex(NameList) :- ...@@ -73,10 +105,11 @@ add_vertex(NameList) :-
biocham_command(*), biocham_command(*),
type(NameList, '*'(name)), type(NameList, '*'(name)),
doc('Adds new vertices to the current graph.'), doc('Adds new vertices to the current graph.'),
get_current_graph(GraphId),
member(Name, NameList), member(Name, NameList),
add_vertex(Name, _VertexId) add_vertex(GraphId, Name, _VertexId)
...@@ -94,14 +127,6 @@ delete_vertex(NameList) :- ...@@ -94,14 +127,6 @@ delete_vertex(NameList) :-
:- grammar(edge).
edge(From -> To) :-
name(From),
name(To).
add_edge(EdgeList) :- add_edge(EdgeList) :-
type(EdgeList, '*'(edge)), type(EdgeList, '*'(edge)),
...@@ -109,21 +134,15 @@ add_edge(EdgeList) :- ...@@ -109,21 +134,15 @@ add_edge(EdgeList) :-
Adds the given set of edges to the current graph. Adds the given set of edges to the current graph.
The vertices are added if needed. The vertices are added if needed.
member(Edge, EdgeList), member(Edge, EdgeList),
add_edge(Edge, _EdgeId) add_edge(GraphId, Edge, _EdgeId)
edgeref(Edge) :-
edge(Edge).
delete_edge(EdgeRefList) :- delete_edge(EdgeRefList) :-
type(EdgeRefList, '*'(edgeref)), type(EdgeRefList, '*'(edgeref)),
...@@ -186,6 +205,33 @@ attribute(Name) :- ...@@ -186,6 +205,33 @@ attribute(Name) :-
name(Name). name(Name).
set_attribute(Id, Attribute) :-
integer(Id),
Attribute = Key: _Value
true
Key = Attribute
item(
[parent: Id, kind: attribute, key: Key, item: Item, id: AttributeId]
Item = Attribute
true
replace_item(AttributeId, attribute, Key, Attribute)
add_item([parent: Id, kind: attribute, key: Key, item: Attribute])
set_attribute(GraphObjectSet, Attribute) :- set_attribute(GraphObjectSet, Attribute) :-
type(GraphObjectSet, {graph_object}), type(GraphObjectSet, {graph_object}),
...@@ -194,34 +240,8 @@ set_attribute(GraphObjectSet, Attribute) :- ...@@ -194,34 +240,8 @@ set_attribute(GraphObjectSet, Attribute) :-
Adds an attribute to every vertex or edge in the given set. Adds an attribute to every vertex or edge in the given set.
The vertices and the edges are added if needed. The vertices and the edges are added if needed.
\+ ( get_current_graph(GraphId),
member(GraphObject, GraphObjectSet), set_attribute(GraphId, GraphObjectSet, Attribute).
add_graph_object(GraphObject, Id),
true
Key = Attribute
item(
Item = Attribute
true
place(NameList) :- place(NameList) :-
...@@ -230,9 +250,8 @@ place(NameList) :- ...@@ -230,9 +250,8 @@ place(NameList) :-
doc(' doc('
Sets that the vertices \\argument{NameList} are places. Sets that the vertices \\argument{NameList} are places.
add_vertex(NameList), get_current_graph(Id),
set_attribute(NameList, kind: place). place(Id, NameList).
transition(NameList) :- transition(NameList) :-
...@@ -241,30 +260,45 @@ transition(NameList) :- ...@@ -241,30 +260,45 @@ transition(NameList) :-
doc(' doc('
Sets that the vertices \\argument{NameList} are transitions. Sets that the vertices \\argument{NameList} are transitions.
set_attribute(NameList, kind: transition). transition(Id, NameList).
delete_attribute(Id, Attribute) :-
integer(Id),
delete_item([parent: Id, kind: attribute, key: Attribute]).
delete_attribute(GraphObject, Attribute) :- delete_attribute(GraphObject, Attribute) :-
type(GraphObject, graph_object), type(GraphObject, graph_object),
type(Attribute, name), type(Attribute, name),
doc('Removes an attribute from \\argument{GraphObject}.'), doc('Removes an attribute from \\argument{GraphObject}.'),
find_graph_object(GraphObject, Id), get_current_graph(GraphId),
delete_item([parent: Id, kind: attribute, key: Attribute]). find_graph_object(GraphId, GraphObject, Id),
delete_attribute(Id, Attribute).
list_attributes(GraphObject) :- list_attributes(GraphObject) :-
doc('List the attributes of \\argument{GraphObject}.'), doc('List the attributes of \\argument{GraphObject}.'),
list_items([parent: Id, kind: attribute]). list_items([parent: Id, kind: attribute]).
:- devdoc('\\section{Public API}'). :- devdoc('\\section{Public API}').
new_graph(Id) :-
add_item([kind: graph, key: new_graph, id: Id]).
set_graph_name(Id, Name) :-
get_current_graph(Id) :- get_current_graph(Id) :-
get_selection(current_model, current_graph, [Id]). get_selection(current_model, current_graph, [Id]).
...@@ -290,41 +324,103 @@ get_attribute(Id, Attribute) :- ...@@ -290,41 +324,103 @@ get_attribute(Id, Attribute) :-
item([parent: Id, kind: attribute, key: Key, item: Attribute]). item([parent: Id, kind: attribute, key: Key, item: Attribute]).
get_attribute(GraphObject, Attribute) :- get_attribute(GraphId, GraphObject, Attribute) :-
get_attribute(Id, Attribute). get_attribute(Id, Attribute).
set_attribute(GraphId, GraphObjectSet, Attribute) :-
list(GraphObjectSet),
set_attribute(GraphId, GraphObject, Attribute)
set_attribute(GraphId, GraphObject, Attribute) :-
add_graph_object(GraphId, GraphObject, Id),
set_attribute(Id, Attribute).
place(GraphId, NameList) :-
kind(GraphId, NameList, place).
transition(GraphId, NameList) :-
kind(GraphId, NameList, transition).
kind(GraphId, NameList, Kind) :-
list(NameList),
kind(GraphId, Name, Kind)
kind(GraphId, Name, Kind) :-
add_vertex(GraphId, Name, VertexId),
set_attribute(VertexId, kind: Kind).
add_vertex(GraphId, Name, VertexId) :-
item([parent: GraphId, kind: vertex, key: Name, id: VertexId])
true
add_item([parent: GraphId, kind: vertex, key: Name, id: VertexId])
add_edge(GraphId, Edge, EdgeId) :-
Edge = (From -> To),
add_vertex(GraphId, From, FromId),
add_vertex(GraphId, To, ToId),
item([parent: GraphId, kind: edge, key: Edge, id: EdgeId])
true
add_item([parent: GraphId, kind: edge, key: Edge, id: EdgeId]),
add_dependency(EdgeId, FromId),
add_dependency(EdgeId, ToId)
:- devdoc('\\section{Private predicates}'). :- devdoc('\\section{Private predicates}').
find_vertex(Name, Id) :- find_vertex(GraphId, Name, Id) :-
find_item([parent: GraphId, kind: vertex, key: Name, id: Id]). find_item([parent: GraphId, kind: vertex, key: Name, id: Id]).
find_edge(Edge, Id) :- find_edge(GraphId, Edge, Id) :-
find_item([parent: GraphId, kind: edge, key: Edge, id: Id]). find_item([parent: GraphId, kind: edge, key: Edge, id: Id]).
find_graph_object(GraphObject, Id) :- find_graph_object(GraphId, GraphObject, Id) :-
GraphObject = (_From->_To) GraphObject = (_From->_To)
find_edge(GraphObject, Id) find_edge(GraphId, GraphObject, Id)
find_vertex(GraphObject, Id) find_vertex(GraphId, GraphObject, Id)
add_graph_object(GraphObject, Id) :- add_graph_object(GraphId, GraphObject, Id) :-
add_edge(GraphObject, Id) add_edge(GraphId, GraphObject, Id)
add_vertex(GraphObject, Id) add_vertex(GraphId, GraphObject, Id)
...@@ -355,30 +451,3 @@ isolated_or_attributed_vertices(GraphId, VerticesId) :- ...@@ -355,30 +451,3 @@ isolated_or_attributed_vertices(GraphId, VerticesId) :-
VerticesId VerticesId
add_vertex(Name, VertexId) :-
true
add_edge(Edge, EdgeId) :-
add_vertex(From, FromId),
add_vertex(To, ToId),
true
...@@ -174,6 +174,7 @@ test('get_attribute', [true(Kind == transition)]) :- ...@@ -174,6 +174,7 @@ test('get_attribute', [true(Kind == transition)]) :-
clear_model, clear_model,
new_graph, new_graph,
command(transition('A')), command(transition('A')),
once(get_attribute('A', kind: Kind)). get_current_graph(GraphId),
once(get_attribute(GraphId, 'A', kind: Kind)).
:- end_tests(graph_editor). :- end_tests(graph_editor).
graphviz, graphviz,
% Commands
draw_graph/0, draw_graph/0,
export_graph/1, export_graph/1,
% Public API
draw_graph/1,
export_graph/2,
set_draw_graph_driver/1 set_draw_graph_driver/1
...@@ -14,8 +18,8 @@ ...@@ -14,8 +18,8 @@
draw_graph :- draw_graph :-
doc('Draws the current graph.'), doc('Draws the current graph.'),
get_draw_graph_driver(Driver), get_current_graph(Id),
Driver. draw_graph(Id).
export_graph(OutputFile) :- export_graph(OutputFile) :-
...@@ -28,13 +32,23 @@ export_graph(OutputFile) :- ...@@ -28,13 +32,23 @@ export_graph(OutputFile) :-
\ttexttt{.png} or \ttexttt{.svg} \ttexttt{.png} or \ttexttt{.svg}
-- assuming no extension is \\texttt{.dot}. -- assuming no extension is \\texttt{.dot}.
file_name_extension(_, Suffix, OutputFile), get_current_graph(Id),
export_graph(Suffix, OutputFile). export_graph(Id, OutputFile).
draw_graph(Id) :-
nb_getval(draw_graph_driver, Driver),
call(Driver, Id).
export_graph(Id, OutputFile) :-
export_graph(Suffix, Id, OutputFile).
set_draw_graph_driver(Driver) :- set_draw_graph_driver(Driver) :-
nb_setval(draw_graph_driver, Driver). nb_setval(draw_graph_driver, Driver).
...@@ -42,53 +56,46 @@ set_draw_graph_driver(Driver) :- ...@@ -42,53 +56,46 @@ set_draw_graph_driver(Driver) :-
:- devdoc('\\section{Internal predicates}'). :- devdoc('\\section{Internal predicates}').
export_graph('', OutputFile) :- export_graph('', Id, OutputFile) :-
atom_concat(OutputFile, '.dot', FilenameDot), atom_concat(OutputFile, '.dot', FilenameDot),
export_graph('.dot', FilenameDot). export_graph('.dot', Id, FilenameDot).
export_graph('dot', OutputFile) :- export_graph('dot', Id, OutputFile) :-
get_current_graph(GraphId), !,
create_cgraph(GraphId, Graph), create_cgraph(Id, Graph),
agwrite(Graph, OutputFile), agwrite(Graph, OutputFile),
agclose(Graph). agclose(Graph).
export_graph('pdf', OutputFile) :- export_graph(Format, Id, OutputFile) :-
render_current_graph('pdf', OutputFile). graphviz_format(Format),
export_graph('eps', OutputFile) :- create_cgraph(Id, Graph),
render_current_graph('eps', OutputFile). gvLayout(Graph, dot),
gvRenderFilename(Graph, Format, OutputFile),
export_graph('ps', OutputFile) :- gvFreeLayout(Graph),
render_current_graph('ps', OutputFile). agclose(Graph).
export_graph('png', OutputFile) :-
render_current_graph('png', OutputFile).
export_graph('svg', OutputFile) :- graphviz_format('pdf').
render_current_graph('svg', OutputFile).
graphviz_format('eps').
get_draw_graph_driver(Driver) :- graphviz_format('ps').
nb_getval(draw_graph_driver, Driver).
graphviz_format('png').
render_current_graph(Format, OutputFile) :- graphviz_format('svg').
