Commit 42ef53ce authored by Thierry Martinez's avatar Thierry Martinez
Kinetics
parent e563da73
...@@ -35,6 +35,7 @@ start :- ...@@ -35,6 +35,7 @@ start :-
initialize :- initialize :-
initialize_library_path, initialize_library_path,
set_prolog_flag(allow_variable_name_as_functor, true),
prolog_history(enable), prolog_history(enable),
set_counter(item_id, 0), set_counter(item_id, 0),
new_model. new_model.
...@@ -231,7 +231,7 @@ build_rule(Kinetics, Left, Catalyst, Right, Reversible, Rule) :- ...@@ -231,7 +231,7 @@ build_rule(Kinetics, Left, Catalyst, Right, Reversible, Rule) :-
Rule = Body Rule = Body
Rule = Kinetics for Body Rule = (Kinetics for Body)
list_to_solution(Left, LeftSolution), list_to_solution(Left, LeftSolution),
list_to_solution(Catalyst, CatalystSolution), list_to_solution(Catalyst, CatalystSolution),
Supports Markdown
