Commit 05a20cf1 authored by FAGES Francois's avatar FAGES Francois
test de modification de M2_gene
parent 99b40482
...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
"\n", "\n",
"F. Fages, Feb. 2020\n", "F. Fages, Feb. 2020\n",
"\n", "\n",
"In this session, we explore\n", "In this session, we explore:\n",
"* the process of gene expression: activation by *promotor*, *trancription* in RNA, and *translation* in proteins (discovered by François Jacob and Jacques Monod, Nobel prize 1965)\n", "* the process of gene expression: activation by *promotor*, *trancription* in RNA, and *translation* in proteins (discovered by François Jacob and Jacques Monod, Nobel prize 1965)\n",
"* the stochastic effects caused by low numbers of molecules (a gene is in one single copy)\n", "* the stochastic effects caused by low numbers of molecules (a gene is in one single copy)\n",
"* the expressive power of autocatalysis\n", "* the expressive power of autocatalysis\n",
