Commit ef67c734 authored by Lucas Bourneuf's avatar Lucas Bourneuf
first working implementation for CLI only
embeds lots of code from initial implementation of biseau,
including all scripts
parents
*.pyc
*.vim
.cache/
.pytest_cache
__pycache__/
build/
biseau.egg-info/
dist/
venv-*/
venv/
include README.mkd
include MANIFEST.in
exclude Makefile
recursive-include biseau *.py
recursive-include scripts *.json
recursive-include scripts *.lp
recursive-include scripts *.py
prune test
prune doc
prune out
run-test:
python -m biseau scripts/example.lp scripts/black_theme.json -o out/out.png
t: test
test:
python -m pytest biseau test --ignore=venv --doctest-module
fullrelease:
fullrelease
install_deps:
python -c "import configparser; c = configparser.ConfigParser(); c.read('setup.cfg'); print(c['options']['install_requires'])" | xargs pip install -U
install:
python setup.py install
# Biseau
__B__uild by __I__nput __S__ome __E__asy __A__SP from __U__sers.
Helps the exploration of formal structures by using ASP as a DSL for drawing graphs.
## Principles
Now, you may want to read about:
- [visualization details](doc/user-doc.mkd#visualization-principles), that explains the theory behind the visualization itself.
- [visualization DSL](doc/user-doc.mkd#asp-to-dot), that explains which atoms produces which effect in visualization.
- [scripting](doc/user-doc.mkd#scripting), that allow you to implement new behavior for biseau.
## Installation
See [user documentation](doc/user-doc.mkd#installation) for details,
but in short, you need [clingo](https://potassco.org/clingo/),
[graphviz](http://graphviz.org/) and `make install-deps`.
## Usage
See [user documentation](doc/user-doc.mkd#basic-usage) for details.
See [`Makefile`](Makefile) for various recipes.
Running biseau can be done using the following commands:
python -m biseau gui # run the Graphical User Interface
python -m biseau # run the Command Line Interface
python -m biseau --help # get help for the CLI
from .module_loader import Script
from .core import single_image_from_filenames
__version__ = '0.0.1'
"""Entry point for package
import os
import argparse
from . import core
def parse_cli(args:iter=None) -> dict:
# main parser
parser = argparse.ArgumentParser(description=__doc__)
parser.add_argument('infiles', type=str, nargs='+', metavar='MODULE',
default=[], help='files containing ASP or Python code')
parser.add_argument('--outfile', '-o', type=str, default='out.png',
help="output file. Will be overwritten with png data. Can be templated with '{model_number}'")
parser.add_argument('--dotfile', '-d', type=str, default=None,
help="output file. Will be overwritten with dot data. Can be templated with '{model_number}'")
# flags
parser.add_argument('--flag-example', action='store_true',
help="Do nothing currently")
return parser.parse_args(args)
if __name__ == '__main__':
args = parse_cli()
core.single_image_from_filenames(
args.infiles,
dotfile=args.dotfile,
outfile=args.outfile,
return_image=False,
# encoding: utf8
"""The core part of visualization, compiling ASP into dot.
import textwrap as textwrap_module
from collections import namedtuple, defaultdict
from biseau import utils
RANK_TYPES = {'same', 'min', 'source', 'max', 'sink'}
DOTABLE_PREDICATES = {'link', 'color', 'shape', 'label', 'annot', 'dot_property', 'obj_property', 'textwrap', 'rank'}
VisualConfig = namedtuple('VisualConfig', 'arcs, properties, upper_annotations, lower_annotations, global_properties, ranks')
arcs -- iterable of 2-uplet (source's uid, target's uid)
properties -- map uid -> (field -> value) and (uid, uid) -> (field -> value)
upper_annotations -- map uid -> {field -> value} specialized for annotations
lower_annotations -- map uid -> {field -> value} specialized for annotations
global_properties -- map object -> (field -> value), with object in (graph, edge, node)
ranks -- map rank-type -> iterable of sets of node
Properties are mapping directly dot properties to nodes (single uid)
or edges (two uid). This allow user to build very precisely the output dot.
def visual_config_from_asp(asp_models:iter, annotation_sep:str=' ') -> [VisualConfig]:
"""Yield VisualConfig instances initialized according to rules
found in each given asp models.
asp_models -- iterable of clyngor.Answers instances
annotation_sep -- separator between each annotation content on same node
base_atoms = defaultdict(set) # predicate -> {args}
for model in asp_models.by_predicate:
viz_atoms = defaultdict(lambda: defaultdict(set)) # level -> {predicate: {args}}
for viz in model.get('viz', ()):
if len(viz) == 1:
pred, args = viz[0]
base_atoms[pred].add(args)
elif len(viz) == 2: # the first param is here to define the level
pred, args = viz[1]
viz_atoms[int(viz[0])][pred].add(args)
# put the predicate not in viz() in the base level
for predicate in DOTABLE_PREDICATES:
base_atoms[predicate] |= frozenset(model.get(predicate, ()))
if viz_atoms:
for level, atoms in viz_atoms.items():
yield visual_config_from_atoms(atoms, base_atoms, annotation_sep)
else: # no viz atoms
yield visual_config_from_atoms({}, base_atoms, annotation_sep)
def visual_config_from_atoms(atoms:dict, base_atoms:dict,
annotation_sep:str) -> VisualConfig:
arcs = []
upper_annotations = defaultdict(lambda: defaultdict(set))
lower_annotations = defaultdict(lambda: defaultdict(set))
properties = defaultdict(lambda: defaultdict(set)) # node -> (property -> {value})
global_properties = defaultdict(lambda: defaultdict(set)) # dot object -> (property -> value)
ranks = defaultdict(set) # rank-type -> {node}
max_label_width = {} # object: maximal text width
def get_atoms_of_predicate(predicate:str):
assert predicate in DOTABLE_PREDICATES, predicate
yield from base_atoms.get(predicate, ())
yield from atoms.get(predicate, ())
def get_uid_from_atom(atom:str or tuple):
if isinstance(atom, str):
return atom
elif isinstance(atom, tuple):
if len(atom) == 2: # a regular atom
if len(atom[1]) == 0:
return atom[0]
else: # atom with args
return '{}({})'.format(atom[0], ','.join(map(get_uid_from_atom, atom[1])))
raise ValueError("Malformed node uid found: " + str(atom))
for link in get_atoms_of_predicate('link'):
if len(link) == 2:
arcs.append(tuple(map(get_uid_from_atom, link)))
for args in get_atoms_of_predicate('textwrap'):
if len(args) == 1: # global value
max_label_width[None] = int(args[0])
elif len(args) == 2:
node, value = args
max_label_width[node] = int(value)
elif len(args) == 3:
src, trg, value = args
max_label_width[src, trg] = int(value)
for annotation in get_atoms_of_predicate('annot'):
if len(annotation) == 3:
type, node, content = annotation
node = get_uid_from_atom(node)
if type == 'upper':
upper_annotations[node]['taillabel'].add(content.strip('"'))
elif type == 'lower':
lower_annotations[node]['headlabel'].add(content.strip('"'))
elif type == 'label':
properties[node]['label'].add(content.strip('"'))
else:
print('Unknow annotation type: {}'.format(type))
elif len(annotation) == 4: # other field
type, node, field, content = annotation
if type == 'upper':
upper_annotations[node][field].add(content.strip('"'))
lower_annotations[node][field].add(content.strip('"'))
for property in get_atoms_of_predicate('dot_property'):
if len(property) == 3: # it's for node
node, field, value = property
properties[node][field.strip('"')].add(value.strip('"'))
elif len(property) == 4: # it's for edges
src, trg, field, value = property
src, trg = map(get_uid_from_atom, (src, trg))
properties[src, trg][field.strip('"')].add(value.strip('"'))
for ranking in get_atoms_of_predicate('rank'):
if len(ranking) == 2: # rank, node
ranktype, node = ranking
if ranktype not in RANK_TYPES:
print("WARNING: atom rank({},{}) describe a rank with unknow "
"type {}. Expected types: {}."
"".format(*ranking, ranktype, ', '.join(RANK_TYPES)))
ranks[ranktype].add(node)
for colored in get_atoms_of_predicate('color'):
if len(colored) == 2: # node
node, color = colored
properties[node]['fillcolor'].add(color)
elif len(colored) == 3: # edge
src, trg, color = colored
properties[src, trg]['color'].add(color) # fillcolor do not exists for edges
for shaped in get_atoms_of_predicate('shape'):
if len(shaped) == 2: # node
node, shape = shaped
properties[node]['shape'].add(shape)
for labeled in get_atoms_of_predicate('label'):
if len(labeled) == 2: # node
node, label = labeled
properties[node]['label'].add(label)
elif len(labeled) == 3: # edge
src, trg, label = labeled
properties[src, trg]['label'].add(label)
for property in get_atoms_of_predicate('obj_property'):
obj, field, value = map(lambda s:str.strip(s, '"'), property)
if obj not in {'graph', 'edge', 'node'}:
print('WARNING: object property {} is unexpected, and may '
'lead to error in generation.'.format(obj))
if field in global_properties:
print('WARNING: object property {} set multiple times with {} replacing {}.'
''.format(field, value, graph_properties[field]))
global_properties[obj.strip('"')][field] = value
# posttreat the data for later use
arcs = tuple(arcs)
nodes = frozenset(properties.keys())
def treat_texts(texts:iter, node, max_label_width=max_label_width) -> str:
ret = annotation_sep.join(map(get_uid_from_atom, texts)).strip('"')
text_width = max_label_width.get(node, max_label_width.get(None))
if text_width:
ret = textwrap_module.fill(ret, width=int(text_width))
return ret
for node in upper_annotations:
props = upper_annotations[node]
props.setdefault('color', 'transparent')
props.setdefault('labelangle', '90')
for key in props:
if not isinstance(props[key], str):
props[key] = treat_texts(props[key], (node, node))
for node in lower_annotations:
props = lower_annotations[node]
props.setdefault('labelangle', '270')
for key in props:
for key in properties:
if 'color' in properties[key]:
try:
properties[key]['color'] = utils.color_from_colors(properties[key]['color'])
except ValueError: # invalid color
properties[key]['color'] = next(iter(properties[key]['color']))
if 'fillcolor' in properties[key]:
try:
properties[key]['fillcolor'] = utils.color_from_colors(properties[key]['fillcolor'])
properties[key]['fillcolor'] = next(iter(properties[key]['fillcolor']))
for field in properties[key]:
if field not in {'color', 'fillcolor'}:
properties[key][field] = treat_texts(properties[key][field], key)
return VisualConfig(
"""Core functions implementing the main behaviors.
Call example in main.
import os
import clyngor
import tempfile
from PIL import Image
from . import utils
from . import Script
from . import asp_to_dot
from . import dot_writer
from . import module_loader
EXT_TO_TYPE = utils.reverse_dict({
'Python': {'.py'},
'ASP': {'.lp'},
'json/ASP': {'.json'},
}, multiple_values=True, aggregator=lambda x: next(iter(x)))
LOADABLE = {'Python', 'ASP', 'json/ASP'}
def single_image_from_filenames(fnames:[str], outfile:str=None, dotfile:str=None, return_image:bool=True) -> Image or None:
pipeline = build_pipeline(fnames)
final_context = run(pipeline)
return compile_to_single_image(final_context, outfile=outfile, dotfile=dotfile, return_image=return_image)
def build_pipeline(fnames:[str]) -> [Script]:
"Yield scripts found in given filenames"
for fname in fnames:
ext = os.path.splitext(fname)[1]
ftype = EXT_TO_TYPE.get(ext, 'unknow type')
if ftype not in LOADABLE:
raise ValueError(f"The type '{ftype}' can't be loaded")
yield from module_loader.build_scripts_from_file(fname)
def run(scripts:[Script], initial_context:str='') -> str:
context = initial_context
for script in scripts:
if script.erase_context:
context = script.run_on(context)
else:
context += '\n' + script.run_on(context)
return context
def compile_to_single_image(context:str, outfile:str=None, dotfile:str=None, return_image:bool=True) -> Image or None:
"Return a pillow.Image object, or write it to outfile if given"
configs = asp_to_dot.visual_config_from_asp(
clyngor.solve(inline=context)
dot = dot_writer.one_graph_from_configs(configs)
del_outfile = False
if outfile is None:
with tempfile.NamedTemporaryFile(delete=False) as fd:
outfile = fd.name
del_outfile = True
dot = dot_writer.dot_to_png(dot, outfile, dotfile=dotfile)
if return_image:
img = Image.open(outfile)
if del_outfile:
os.unlink(outfile)
return img
# encoding: utf8
"""Routines manipulating the dot.
import pydot
from .asp_to_dot import VisualConfig
DEFAULT_DOT_FILE = 'out/out.dot'
DEFAULT_PROG_FILE = 'dot'
def _dot_from_properties(properties:dict or None, prefix:str=' ') -> str:
"""Return a dot '[]' expression where given properties are represented.
If given properties are None, empty string will be output.
if properties:
content = ' '.join(
'{}="{}"'.format(field, value.replace('"', r'\"'))
for field, value in properties.items()
return prefix + '[' + content + ']'
else:
return ''
def multiple_graphs_from_configs(visual_configs:[VisualConfig]) -> iter:
"""Yield lines of dot describing the given VisualConfig instances.
Produce one graph per VisualConfig.
See function counterpart, one_graph_from_configs.
for visual_config in visual_configs:
yield 'Digraph biseau_graph {\n'
yield from _from_config(visual_config)
yield '}\n\n\n'
def one_graph_from_configs(visual_configs:[VisualConfig]) -> iter:
Produce only one graph,
using the union of visual_configs to implement the view.
yield '}'
def _from_config(visual_config:VisualConfig) -> iter:
"""Yield lines of dot's graph describing the given VisualConfig instance.
arcs, properties, upper_annotations, lower_annotations, globals_props, ranks = visual_config
for object, props in globals_props.items():
yield '\t{}{};\n'.format(object, _dot_from_properties(props))
if 'node' not in globals_props:
yield '\tnode [shape=ellipse style=filled width=.25]\n'
if 'edge' not in globals_props:
yield '\tedge [arrowhead=none labeldistance=1.5 minlen=2]\n'
treated_nodes = set() # contains nodes already treated
for source, target in arcs:
for node in source, target:
if node not in treated_nodes:
treated_nodes.add(node)
node_dot_props = _dot_from_properties(properties.get(node))
if node_dot_props:
yield '\t{n}{d}\n'.format(n=node, d=node_dot_props)
if lower_annotations.get(node):
yield '\t{n} -> {n} {d}\n'.format(
n=node, d=_dot_from_properties(lower_annotations[node]))
if upper_annotations.get(node):
n=node, d=_dot_from_properties(upper_annotations[node]))
yield '\t{}->{}{}\n'.format(source, target, _dot_from_properties(properties.get((source, target))))
# build ranks
for ranktype, nodes in ranks.items():
yield '\t{{rank={}; {}}}\n'.format(ranktype, ';'.join(nodes))
def dot_to_png(dot_lines:iter, outfile:str, dotfile:str=DEFAULT_DOT_FILE,
prog:str=DEFAULT_PROG_FILE):
"""Write in outfile a png render of the graph described in given dot lines"""
dot_lines = ''.join(dot_lines)
if dotfile:
with open(dotfile, 'w') as fd:
fd.write(dot_lines)
graphs = iter(pydot.graph_from_dot_data(dot_lines))
for graph in graphs:
with open(outfile, 'wb') as fd:
fd.write(graph.create(prog=prog, format='png'))
break
# TODO: handle multiple graphs (see #10)
print('WARNING: an additionnal graph as been found in the dot file.'
'It will be ignored.')
print(graph)
This diff is collapsed.
# encoding: utf8
"""Various helpers"""
import os
import inspect
from functools import partial, wraps
from collections import defaultdict
HANDLED_COLORS = {'red', 'green', 'blue'}
def color_from_colors(colors:set) -> str:
"""Return one color that represents the given ones"""
if all(color in HANDLED_COLORS for color in colors):
if len(colors) == 1: return next(iter(colors))
if len(colors) == 2:
if 'red' in colors:
if 'blue' in colors: return 'magenta'
else: return 'yellow' # red and green
else: return 'cyan' # blue and green
if len(colors) == 3: return 'white'
elif len(colors) == 1: # special case where only one non handled color is given
raise ValueError('UNVALID COLORS: ' + ', '.join(colors))
def normalized_path(path:str) -> str:
return os.path.expanduser(os.path.abspath(os.path.expanduser(path)))
def join_on_genstr(funcgen:callable, joiner:str='') -> str:
"""If funcgen is a generator, will join its result on call
>>> join_on_genstr(lambda: 'abc')()
'abc'
>>> def g(): yield from 'abc'
>>> join_on_genstr(g)()
'abc'
>>> def g(c): return c+'bc'
>>> join_on_genstr(g)('a')
'abc'
if inspect.isgeneratorfunction(funcgen) or inspect.isgenerator(funcgen):
return wraps(funcgen)(lambda *a, **k: joiner.join(funcgen(*a, **k)))
return funcgen
def compile_python_code(code:str) -> dict:
return compile(code, '<string>', 'exec')
def run_compiled_python_code(code:'code', namespace:dict=None) -> dict:
namespace = namespace or {}
exec(code, namespace)
return namespace
def run_python_code(code:str, namespace:dict=None) -> dict:
>>> run_python_code('a = 1')['a']
>>> a = 1
>>> run_python_code('a = 2')['a']
2
>>> a
return run_compiled_python_code(compile_python_code(code), namespace or {})
def ispartialsubclass(obj:object, cls:object or (object,)) -> bool:
return ispartial(obj, cls, subclass=True)
def ispartialinstance(obj:object, cls:object or (object,)) -> bool:
return ispartial(obj, cls, instance=True)
def ispartial(obj:object, cls:object or (object,), subclass:bool=False,
instance:bool=False) -> bool:
if obj is cls: return True
while type(obj) is partial:
obj = obj.func
# make it a tuple
clss = cls if isinstance(cls, tuple) and obj is not tuple else (cls,)
if subclass and instance:
raise ValueError("Can't test for both subclass and instance")
if subclass:
test = lambda obj, cls: type(obj) is type and issubclass(obj, cls)
elif instance:
test = lambda obj, cls: isinstance(obj, cls)
else:
test = lambda obj, cls: obj is cls
return any(test(obj, cls) for cls in clss)
def reverse_dict(d:dict, aggregator=set, multiple_values:bool=False) -> dict:
"""Return a new dict containing keys as values (aggregated into an `aggregator`)
and values as keys.
>>> sorted(tuple(reverse_dict({1: 2, 2: 3, 4: 2}).items()))
((2, {1, 4}), (3, {2}))
out = defaultdict(list)
if multiple_values:
for key, vals in d.items():
for val in vals:
out[val].append(key)
else:
for key, val in d.items():
return {key: aggregator(val) for key, val in out.items()}
set local
REM This script runs biseau's GUI, asserting that user is running it
REM while in the same directory as this script.
REM Also, it will add the path to graphviz/dot.exe if
REM it exist in the local PATH env copy.
REM Add path to dot
set DOTPATH="C:\Program Files (x86)\Graphviz2.38\bin"
IF EXIST DOTPATH SET PATH=%PATH%;DOTPATH
REM run biseau
cd ..
REM you should make a copy of this script, if you want to modify it,
REM and modify/use the copy instead.
REM Probably you will want to modify path to clingo. Use --clingo option.
# This script runs biseau's GUI, asserting that user is running it
# while in the same directory as this script.
cd ..
# you should make a copy of this script, if you want to modify it,
# and modify/use the copy instead.
# Probably you will want to modify path to clingo. Use --clingo option.
"C:\Program Files\Git\cmd\git.exe" pull
pause
\ No newline at end of file
git pull
# wrapped in bash call because some shells do not handle -n option correctly
bash -c "read -n 1 -p 'press any key to quit'"
!.gitignore
# encoding: utf8
"""Allow user to export (some parts of) the ASP program into a file.
import os
import clyngor
import tkinter as tk
NAME = 'ASP Extractor'
TAGS = {'utils'}
INPUTS = {}
OUTPUTS = {}
DEFAULT_SHOWS = """% Let the #show begin:
#show link/2.
DEFAULT_EXPORT_FILE = 'extraction.lp'
with open(DEFAULT_EXPORT_FILE, 'ab') as fd:
pass # be sure that it exists
OPTION_FILETYPE = partial(tk.filedialog.asksaveasfilename, defaultextension='.lp')
def run_on(context:str, *, shows:str=DEFAULT_SHOWS, export_file:OPTION_FILETYPE=DEFAULT_EXPORT_FILE):
shows -- ASP lines that will be used to export, but will not be added to the context
export_file -- name of the file to export to. If it contains an '{}', each model will generate its own file
try:
if not export_file: return context
models = clyngor.solve((), inline=context + '\n' + shows).atoms_as_string.careful_parsing
istemplate = isinstance(export_file, str) and '{}' in export_file
if not istemplate: # empty it before writing it
with open(export_file, 'w') as fd:
pass
for idx, model in enumerate(models):
fname = export_file.format(idx) if istemplate else export_file
with open(fname, 'w' if istemplate else 'a') as fd:
fd.write('\n\n%% MODEL {}:\n'.format(idx))
fd.write(''.join(atom + '.\n' for atom in model))
except clyngor.ASPSyntaxError as err:
raise err
except clyngor.utils.ASPSyntaxError:
print('UTILS?!')
return context
"ASP": "\nobj_property(edge,color,white).\nobj_property(edge,fontcolor,white).\nobj_property(graph,bgcolor,black).\n",
"description": "Draw with a black background",
"name": "black theme",
"tags": ["theme"],
"inputs": [],
"outputs": ["obj_property/3"],
"active at startup": false
# encoding: utf8
"""Biseau script.
Compute concepts and AOC poset as a single model.
import os
import clyngor
