GitLab
Support
Community forum
Keyboard shortcuts
B
biseau
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
BOURNEUF Lucas
biseau
7b9a6c85
7b9a6c85
Lucas Bourneuf
nb_model argument + fix multiple image generation
9dc74f26
3
3 changed files
30 additions
15 deletions
+30
-15
biseau/__init__.py
biseau/__init__.py
+1
-1
biseau/__main__.py
biseau/__main__.py
+13
-4
biseau/core.py
biseau/core.py
+16
-10
biseau/__init__.py
7b9a6c85
from
.module_loader
import
Script
from
.module_loader
import
Script
from
.core
import
single_image_from_filenames
gif_from_filenames
from
.core
import
multiple_images_from_filenames
gif_from_filenames
__version__
'0.0.5.dev0'
__version__
'0.0.5.dev0'
biseau/__main__.py
7b9a6c85
@@ -9,6 +9,7 @@ import os
import
argparse
import
argparse
import
itertools
import
itertools
from
import
core
from
import
core
from
import
__version__
def
parse_cli
args
iter
None
dict
def
parse_cli
args
iter
None
dict
@@ -18,13 +19,15 @@ def parse_cli(args:iter=None) -> dict:
parser
add_argument
'infiles'
type
str
nargs
metavar
'MODULE'
parser
add_argument
'infiles'
type
str
nargs
metavar
'MODULE'
default
help
'files containing ASP or Python code'
default
help
parser
add_argument
'--outfile'
'-o'
type
str
default
'out.png'
parser
add_argument
'--outfile'
'-o'
type
str
default
'out.png'
help
"output file. Will be overwritten with png data. Can be templated with '{
model_number
help
"output file. Will be overwritten with png data. Can be templated with '{}'"
parser
add_argument
'--dotfile'
'-d'
type
str
default
None
parser
add_argument
'--dotfile'
'-d'
type
str
default
None
help
"output file. Will be overwritten with dot data. Can be templated with '{
model_number
help
"output file. Will be overwritten with dot data. Can be templated with '{}'"
parser
add_argument
'--config'
'-c'
type
str
default
None
parser
add_argument
'--config'
'-c'
type
str
default
None
help
"configuration file, specifying scripts and their options"
help
parser
add_argument
'--gif-duration'
'-gd'
type
int
default
500
parser
add_argument
'--gif-duration'
'-gd'
type
int
default
500
help
"gif duration in second"
help
"gif duration in millisecond"
parser
add_argument
'--nb-model'
'-n'
type
int
default
help
"number of model of the final context to handle. 0 for all."
parser
add_argument
'-v'
'--verbosity'
action
'count'
default
parser
add_argument
'-v'
'--verbosity'
action
'count'
default
# flags
# flags
@@ -52,12 +55,18 @@ if __name__ == '__main__':
dotfile_template
args
dotfile
dotfile_template
args
dotfile
duration
args
gif_duration
duration
args
gif_duration
verbosity
args
verbosity
verbosity
args
verbosity
nb_model
args
nb_model
else
else
core
if
args
outfile
in
args
outfile
builder
core
else
builder
core
builder
all_infiles
all_infiles
dotfile
args
dotfile
dotfile
args
dotfile
outfile
args
outfile
outfile
args
outfile
return_image
False
return_image
False
verbosity
args
verbosity
verbosity
args
verbosity
nb_model
args
nb_model
biseau/core.py
7b9a6c85
@@ -26,17 +26,21 @@ EXT_TO_TYPE = utils.reverse_dict({
LOADABLE
'Python'
'ASP'
'json/ASP'
LOADABLE
'Python'
'ASP'
'json/ASP'
def
fnames
str
outfile
str
None
dotfile
str
None
return_image
bool
True
verbosity
int
None
def
fnames
str
outfile
str
None
dotfile
str
None
nb_model
int
return_image
bool
True
verbosity
int
None
pipeline
build_pipeline
fnames
verbosity
pipeline
build_pipeline
fnames
verbosity
final_context
run
pipeline
verbosity
verbosity
final_context
run
pipeline
verbosity
verbosity
return
compile_to_single_image
final_context
outfile
outfile
dotfile
dotfile
return_image
return_image
verbosity
verbosity
return
final_context
nb_model
nb_model
outfile
outfile
dotfile
dotfile
return_image
return_image
verbosity
verbosity
def
fnames
str
outfile
str
'out-{}.png'
dotfile
str
None
nb_model
int
return_image
bool
True
verbosity
int
None
pipeline
build_pipeline
fnames
verbosity
final_context
run
pipeline
verbosity
verbosity
return
tuple
compile_to_images
final_context
nb_model
nb_model
outfile_template
outfile
dotfile_template
dotfile
return_image
return_image
verbosity
verbosity
def
gif_from_filenames
fnames
str
giffile
str
None
dotfile_template
str
None
duration
int
1000
loop
int
verbosity
int
bytes
str
def
gif_from_filenames
fnames
str
giffile
str
None
dotfile_template
str
None
duration
int
1000
loop
int
nb_model
int
verbosity
int
bytes
str
"""Make a gif, with each ASP model as an image. Save it in outfile and dotfile_template"""
pipeline
build_pipeline
fnames
verbosity
pipeline
build_pipeline
fnames
verbosity
final_context
run
pipeline
verbosity
verbosity
final_context
run
pipeline
verbosity
verbosity
first
lasts
compile_to_images
final_context
dotfile_template
dotfile_template
return_image
True
verbosity
verbosity
first
lasts
compile_to_images
final_context
dotfile_template
dotfile_template
return_image
True
nb_model
nb_model
verbosity
verbosity
output
io
BytesIO
if
giffile
is
None
else
giffile
output
io
BytesIO
if
giffile
is
None
else
giffile
first
save
output
format
'gif'
append_images
lasts
duration
duration
loop
loop
save_all
True
first
save
output
format
'gif'
append_images
lasts
duration
duration
loop
loop
save_all
True
return
output
getvalue
if
giffile
is
None
else
giffile
return
output
getvalue
if
giffile
is
None
else
giffile
@@ -106,15 +110,16 @@ def run(scripts:[Script], initial_context:str='', verbosity:int=0) -> str:
return
context
return
context
def
solve_context
context
str
clyngor
Answers
def
solve_context
context
str
nb_model
int
clyngor
Answers
return
clyngor
solve
inline
context
by_predicate
careful_parsing
int_not_parsed
return
clyngor
solve
inline
context
nb_model
nb_model
options
'--project'
by_predicate
careful_parsing
int_not_parsed
def
context
str
outfile
str
None
dotfile
str
None
def
context
str
outfile
str
None
dotfile
str
None
return_image
bool
True
verbosity
int
None
nb_model
int
return_image
bool
True
verbosity
int
None
"Return a pillow.Image object, or write it to outfile if given"
configs
asp_to_dot
visual_config_from_asp
configs
asp_to_dot
solve_context
context
solve_context
context
nb_model
nb_model
dot
dot_writer
one_graph_from_configs
configs
dot
dot_writer
configs
del_outfile
False
del_outfile
False
@@ -131,7 +136,8 @@ def compile_to_single_image(context:str, outfile:str=None, dotfile:str=None,
def
compile_to_images
context
str
outfile_template
str
None
dotfile_template
str
None
def
compile_to_images
context
str
outfile_template
str
None
dotfile_template
str
None
return_image
bool
True
verbosity
int
nb_model
int
return_image
bool
True
verbosity
int
"""Yield pillow.Image objects, and write it to outfile if given
outfile_template -- template name for png files, or None
@@ -139,7 +145,7 @@ def compile_to_images(context:str, outfile_template:str=None, dotfile_template:s
configs
asp_to_dot
configs
asp_to_dot
solve_context
context
solve_context
context
nb_model
nb_model
if
outfile_template
not
in
outfile_template
if
outfile_template
not
in
outfile_template
raise
ValueError
"Outfile argument is not a valid template"
raise
ValueError
