Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit 67bf8eb1 authored by Lucas Bourneuf's avatar Lucas Bourneuf
bugfix: gif not generated properly ; loop argument
parent aa8c2ec1
...@@ -32,13 +32,13 @@ def single_image_from_filenames(fnames:[str], outfile:str=None, dotfile:str=None ...@@ -32,13 +32,13 @@ def single_image_from_filenames(fnames:[str], outfile:str=None, dotfile:str=None
return compile_to_single_image(final_context, outfile=outfile, dotfile=dotfile, return_image=return_image, verbosity=verbosity) return compile_to_single_image(final_context, outfile=outfile, dotfile=dotfile, return_image=return_image, verbosity=verbosity)
def gif_from_filenames(fnames:[str], giffile:str=None, dotfile_template:str=None, duration:int=1000, verbosity:int=0) -> bytes or str: def gif_from_filenames(fnames:[str], giffile:str=None, dotfile_template:str=None, duration:int=1000, loop:int=0, verbosity:int=0) -> bytes or str:
"""Make a gif, with each ASP model as an image. Save it in outfile and dotfile_template""" """Make a gif, with each ASP model as an image. Save it in outfile and dotfile_template"""
pipeline = build_pipeline(fnames, verbosity) pipeline = build_pipeline(fnames, verbosity)
final_context = run(pipeline, verbosity=verbosity) final_context = run(pipeline, verbosity=verbosity)
first, *lasts = compile_to_images(final_context, dotfile_template=dotfile_template, return_image=True, verbosity=verbosity) first, *lasts = compile_to_images(final_context, dotfile_template=dotfile_template, return_image=True, verbosity=verbosity)
output = io.BytesIO() if giffile is None else giffile output = io.BytesIO() if giffile is None else giffile
first.save(output, save_all=True, append_images=lasts, duration=duration, loop=0) first.save(output, format='gif', append_images=lasts, duration=duration, loop=loop, save_all=True)
return output.getvalue() if giffile is None else giffile return output.getvalue() if giffile is None else giffile
