Commit bd50f79b authored by Gérard Huet's avatar Gérard Huet
Suppression of useless SERVERPROTOCOL config parameter
parent 18baa957
...@@ -739,7 +739,7 @@ value title_instructions = ...@@ -739,7 +739,7 @@ value title_instructions =
value doctype = "<!DOCTYPE html>" (* Assuming HTML5 *) value doctype = "<!DOCTYPE html>" (* Assuming HTML5 *)
value url dns = (* Paths.server_protocol *) "http://" ^ dns value url dns = "http://" ^ dns
value ocaml_site = url "ocaml.org" value ocaml_site = url "ocaml.org"
and inria_site = url "www.inria.fr/" and inria_site = url "www.inria.fr/"
...@@ -4,7 +4,6 @@ TRANSLIT='WX' ...@@ -4,7 +4,6 @@ TRANSLIT='WX'
LEXICON='SH' LEXICON='SH'
DISPLAY='deva' DISPLAY='deva'
SERVERHOST='127.0.0.1' SERVERHOST='127.0.0.1'
SERVERPROTOCOL='http'
SERVERPUBLICDIR='/var/www/html/SKT/# amba' SERVERPUBLICDIR='/var/www/html/SKT/# amba'
SKTDIRURL='/SKT/# amba' SKTDIRURL='/SKT/# amba'
SKTRESOURCES='/home/ambaji/SKT/Heritage_Resources/' SKTRESOURCES='/home/ambaji/SKT/Heritage_Resources/'
...@@ -4,7 +4,6 @@ TRANSLIT='VH' ...@@ -4,7 +4,6 @@ TRANSLIT='VH'
DISPLAY='roma' DISPLAY='roma'
SERVERPUBLICDIR='/Library/WebServer/Documents/SKT/' SERVERPUBLICDIR='/Library/WebServer/Documents/SKT/'
SKTDIRURL='/SKT/' SKTDIRURL='/SKT/'
SKTRESOURCES='/Users/huet/Sanskrit/Heritage_Resources/' SKTRESOURCES='/Users/huet/Sanskrit/Heritage_Resources/'
SERVERHOST='sanskrit.inria.fr# sanskrit' SERVERHOST='sanskrit.inria.fr# sanskrit'
SERVERPROTOCOL='https'
SERVERPUBLICDIR='/var/www/sanskrit.rocq.inria.fr/' SERVERPUBLICDIR='/var/www/sanskrit.rocq.inria.fr/'
SKTDIRURL='https://sanskrit.inria.fr/# sanskrit' SKTDIRURL='https://sanskrit.inria.fr/# sanskrit'
SKTRESOURCES='/home/huet/Sanskrit/Heritage_Resources/' SKTRESOURCES='/home/huet/Sanskrit/Heritage_Resources/'
...@@ -103,9 +103,6 @@ SERVERHOST should be the domain name (or IP address) of the target HTTP server. ...@@ -103,9 +103,6 @@ SERVERHOST should be the domain name (or IP address) of the target HTTP server.
For instance, use SERVERHOST='127.0.0.1' for localhost service For instance, use SERVERHOST='127.0.0.1' for localhost service
(SERVERHOST='localhost' should work too). (SERVERHOST='localhost' should work too).
SERVERPROTOCOL should be set to 'http' for a localhost or non secured server,
and to 'https' for a server with a security certificate.
SERVERPUBLICDIR should be the absolute path on the server file system of the data SERVERPUBLICDIR should be the absolute path on the server file system of the data
to be used by its cgi-bin executables - it should be allowed as readable from to be used by its cgi-bin executables - it should be allowed as readable from
all. The fields of the configuration file relevant to the Apache server all. The fields of the configuration file relevant to the Apache server
...@@ -148,9 +148,6 @@ SERVERHOST=#SERVERHOST ...@@ -148,9 +148,6 @@ SERVERHOST=#SERVERHOST
# SERVERHOST=pauillac.inria.fr# pauillac # SERVERHOST=pauillac.inria.fr# pauillac
# SERVERHOST=213.41.153.152# dhruva gerardh.net1.nerim.net [legacy] # SERVERHOST=213.41.153.152# dhruva gerardh.net1.nerim.net [legacy]
# Protocol used by the server (http or https)
SERVERPROTOCOL=#SERVERPROTOCOL
# For remote invocation of cgi services (eg Sanskrit Library) # For remote invocation of cgi services (eg Sanskrit Library)
REMOTESERVERHOST=https://sanskrit.inria.fr/# remote host Inria REMOTESERVERHOST=https://sanskrit.inria.fr/# remote host Inria
...@@ -433,7 +430,6 @@ echo 'and skt_resources_dir = "$(SKTRESOURCES)"'; \ ...@@ -433,7 +430,6 @@ echo 'and skt_resources_dir = "$(SKTRESOURCES)"'; \
echo 'and public_skt_dir = "$(SERVERPUBLICDIR)"'; \ echo 'and public_skt_dir = "$(SERVERPUBLICDIR)"'; \
echo 'and skt_dir_url = "$(SKTDIRURL)"'; \ echo 'and skt_dir_url = "$(SKTDIRURL)"'; \
echo 'and server_host = "$(SERVERHOST)"'; \ echo 'and server_host = "$(SERVERHOST)"'; \
echo 'and server_protocol = "$(SERVERPROTOCOL)"'; \
echo 'and remote_server_host = "$(REMOTESERVERHOST)"'; \ echo 'and remote_server_host = "$(REMOTESERVERHOST)"'; \
echo 'and cgi_dir_url = "$(CGIBINURL)"'; \ echo 'and cgi_dir_url = "$(CGIBINURL)"'; \
echo 'and cgi_index = "$(CGIINDEX)"'; \ echo 'and cgi_index = "$(CGIINDEX)"'; \
...@@ -24,9 +24,6 @@ DISPLAY='roma' ...@@ -24,9 +24,6 @@ DISPLAY='roma'
# URL of host server -- '127.0.0.1' for localhost # URL of host server -- '127.0.0.1' for localhost
# Protocol used by the host server: 'http' or 'https'
# IMPORTANT: in SERVERPUBLICDIR as well as CGIDIR below, you must plan on # IMPORTANT: in SERVERPUBLICDIR as well as CGIDIR below, you must plan on
# creating the directories in the Apache area /var/www, in supervisor mode # creating the directories in the Apache area /var/www, in supervisor mode
VERSION='3.12' VERSION='3.12'
DATE='2019-01-15' DATE='2019-01-17'
...@@ -22,10 +22,10 @@ goldendict_path="SITE/goldendict.html" ...@@ -22,10 +22,10 @@ goldendict_path="SITE/goldendict.html"
meta_docintro_path="DOC/docintro" meta_docintro_path="DOC/docintro"
docintro_path="DOC/docintro.tex" docintro_path="DOC/docintro.tex"
makefile_keys=["TEMPLATE","PLATFORM","TRANSLIT","LEXICON","DISPLAY","WARN", makefile_keys=["TEMPLATE","PLATFORM","TRANSLIT","LEXICON","DISPLAY","WARN",
"SERVERHOST","SERVERPROTOCOL","SERVERPUBLICDIR","SKTDIRURL", "SERVERHOST","SERVERPUBLICDIR","SKTDIRURL",
"SKTRESOURCES","CGIBINURL","CGIDIR","CGIEXT","MOUSEACTION", "SKTRESOURCES","CGIBINURL","CGIDIR","CGIEXT","MOUSEACTION",
"ZENDIR"] "ZENDIR"]
# deprecated "SCLURL","SCLINSTALLDIR","TEMPAREA","OUTPUTFONT", # deprecated "SCLURL","SCLINSTALLDIR","TEMPAREA","OUTPUTFONT","SERVERPROTOCOL"
counter_keys=["CAPTION"] counter_keys=["CAPTION"]
version_keys=["VERSION","DATE"] version_keys=["VERSION","DATE"]
TEMPLATE='#' TEMPLATE='#'
