Commit 26fa3951 authored by Gérard Huet's avatar Gérard Huet
VERSION bumped to 3.13
parent a002873f
...@@ -4,7 +4,7 @@ ...@@ -4,7 +4,7 @@
(* Gérard Huet *) (* Gérard Huet *)
(* ©2018 Institut National de Recherche en Informatique et en Automatique *) (* ©2019 Institut National de Recherche en Informatique et en Automatique *)
(*i module Canon = struct i*) (*i module Canon = struct i*)
...@@ -732,7 +732,7 @@ and matra_indic_unicode_point = fun ...@@ -732,7 +732,7 @@ and matra_indic_unicode_point = fun
(* om 50 udatta 51 anudatta 52 grave 53 acute 54 avagraha 3D .ll 61 (* om 50 udatta 51 anudatta 52 grave 53 acute 54 avagraha 3D .ll 61
danda 64 ddanda 65 0 66 1 67 2 68 3 69 4 6A 5 6B 6 6C 7 6D 8 6E 9 6F ° 70 *) danda 64 ddanda 65 0 66 1 67 2 68 3 69 4 6A 5 6B 6 6C 7 6D 8 6E 9 6F deg 70 *)
value inject_point s = "&#x09" ^ s ^ ";" value inject_point s = "&#x09" ^ s ^ ";"
value deva_unicode c = value deva_unicode c =
(*i module Encode = struct i*) (*i module Encode = struct i*)
...@@ -21,12 +21,12 @@ value is_vowel c = vowel c || c>100 && c<114 (* accounts for upper case *) ...@@ -21,12 +21,12 @@ value is_vowel c = vowel c || c>100 && c<114 (* accounts for upper case *)
value rec normalize = normal_rec False value rec normalize = normal_rec False
where rec normal_rec after_vow = fun where rec normal_rec after_vow = fun
| [ 14 (* .m *) :: [] ] -> [ 14 ] (* and NOT m *) | [ 14 (* .m *) ] -> [ 14 ] (* and NOT m *)
| [ 14 (* .m *) :: [ c :: l ] ] -> | [ 14 (* .m *) :: [ c :: l ] ] ->
if after_vow then if after_vow then
let c' = homonasal c in [ c' :: [ c :: normal_rec (is_vowel c) l ] ] let c' = homonasal c in [ c' :: [ c :: normal_rec (is_vowel c) l ] ]
else raise (In_error "Anusvaara should follow vowel") else raise (In_error "Anusvaara should follow vowel")
| [ 16 (* .h *) :: [] ] -> | [ 16 (* .h *) ] ->
if after_vow then [ 16 ] if after_vow then [ 16 ]
else raise (In_error "Visarga should follow vowel") else raise (In_error "Visarga should follow vowel")
(* No change to visarga since eg praata.hsvasu.h comes from praatar|svasu.h (* No change to visarga since eg praata.hsvasu.h comes from praatar|svasu.h
...@@ -79,7 +79,7 @@ value strip w = match w with ...@@ -79,7 +79,7 @@ value strip w = match w with
value rstem w = strip (Word.mirror w) value rstem w = strip (Word.mirror w)
value rev_strip w = Word.mirror (rstem w) (* ugly - temp *) value rev_strip w = Word.mirror (rstem w) (* [compute_mw_links] *)
(* Builds revword normalised stem from entry string of root *) (* Builds revword normalised stem from entry string of root *)
(* Used by [Verbs.revstem], [Nouns.enter_iic], [Print_dict] *) (* Used by [Verbs.revstem], [Nouns.enter_iic], [Print_dict] *)
...@@ -10,7 +10,7 @@ ...@@ -10,7 +10,7 @@
(* A very simple lexer recognizing 1 character idents and integers (* A very simple lexer recognizing 1 character idents and integers
and skipping spaces and comments between [%] and eol; and skipping spaces and comments between [%] and eol;
used for various transduction tasks with Camlp4 Grammars. used for various transduction tasks with Camlp4 Grammars.
It is a copy of ZEN/zen_lexer.ml in order to simplify dependencies. *) It is a copy of [ZEN/zen_lexer.ml] in order to simplify dependencies. *)
(*i module Min_lexer = struct i*) (*i module Min_lexer = struct i*)
...@@ -43,8 +43,8 @@ value voices_of = fun ...@@ -43,8 +43,8 @@ value voices_of = fun
| "ghraa" | "cakaas" | "ca.t" | "cand" | "cam" | "car" | "cal" | "cit#1" | "ghraa" | "cakaas" | "ca.t" | "cand" | "cam" | "car" | "cal" | "cit#1"
| "cumb" | "chur" | "ch.rd" | "jak.s" | "jap" | "jabh#2" | "jam" | "jalp" | "cumb" | "chur" | "ch.rd" | "jak.s" | "jap" | "jabh#2" | "jam" | "jalp"
| "jas" | "jaag.r" | "jinv" | "jiiv" | "jvar" | "jval" | "tak" | "tak.s" | "jas" | "jaag.r" | "jinv" | "jiiv" | "jvar" | "jval" | "tak" | "tak.s"
| "ta~nc" | "tam" | "tarj" | "tup" | "tu.s" | "t.rp#1" | "t.r.s#1" | "t.rr" | "ta~nc" | "tam" | "tarj" | "tup" | "tu.s" | "t.rp#1" | "t.r.s#1" | "t.rh"
| "tyaj#1" | "tras" | "tru.t" | "tvak.s" | "tsar" | "da.mz" | "dagh" | "t.rr" | "tyaj#1" | "tras" | "tru.t" | "tvak.s" | "tsar" | "da.mz" | "dagh"
| "dabh" | "dam#1" | "dal" | "das" | "dah#1" | "daa#2" | "daa#3" | "diiv#1" | "dabh" | "dam#1" | "dal" | "das" | "dah#1" | "daa#2" | "daa#3" | "diiv#1"
| "du" | "du.s" | "d.rp" | "d.rbh" | "d.rz#1" | "d.rh" | "d.rr" | "dhyaa" | "du" | "du.s" | "d.rp" | "d.rbh" | "d.rz#1" | "d.rh" | "d.rr" | "dhyaa"
| "draa#1" | "dru#1" | "druh#1" | "dham" | "dhaa#2" | "dhru" | "dhvan" | "draa#1" | "dru#1" | "druh#1" | "dham" | "dhaa#2" | "dhru" | "dhvan"
...@@ -4,9 +4,10 @@ ...@@ -4,9 +4,10 @@
(* Gérard Huet & Pawan Goyal *) (* Gérard Huet & Pawan Goyal *)
(* Chunking mechanism for guessing partial padapatha form from list of chunks *) (* Chunking mechanism for guessing partial padapatha form from list of chunks *)
(* Essential for maximum parallelism in segmentation *)
value sanskrit_chunk encode s = value sanskrit_chunk encode s =
match encode s with (* avagraha reverts to a *) match encode s with (* avagraha reverts to a *)
...@@ -128,21 +128,6 @@ value print_uni_kridanta pvs phase word multitags (n,m) = ...@@ -128,21 +128,6 @@ value print_uni_kridanta pvs phase word multitags (n,m) =
; ps th_end ; ps th_end
(* deprecated
value print_uni_taddhita pvs m phase stem sfx sfx_phase = fun
[ [ (delta,polytag) ] -> (* we assume n=1 taddhita form unambiguous *)
let unitag = [ project m polytag ]
and gen = generative phase
and cached = False in do
{ ps th_begin
; pl (Lex.table_morph_of sfx_phase) (* table begin *)
; let _ = Lex.print_morph_tad pvs cached 0 gen stem sfx 0 (delta,unitag) in ()
; ps table_end (* table end *)
; ps th_end
| _ -> failwith "Multiple sfx tag"
value print_projection phase rword ((_,m) as index) = do value print_projection phase rword ((_,m) as index) = do
{ ps tr_begin (* tr begins *) { ps tr_begin (* tr begins *)
; Morpho_html.print_signifiant_yellow rword ; Morpho_html.print_signifiant_yellow rword
...@@ -151,14 +136,6 @@ value print_projection phase rword ((_,m) as index) = do ...@@ -151,14 +136,6 @@ value print_projection phase rword ((_,m) as index) = do
[ Atomic tags -> print_uni_kridanta [] phase word tags index [ Atomic tags -> print_uni_kridanta [] phase word tags index
| Preverbed (_,phase) pvs form tags -> | Preverbed (_,phase) pvs form tags ->
print_uni_kridanta pvs phase form tags index print_uni_kridanta pvs phase form tags index
(* deprecated
| Taddhita (ph,form) sfx sfx_phase sfx_tags ->
match Lex.tags_of ph form with
[ Atomic _ -> print_uni_taddhita [] m phase form sfx sfx_phase sfx_tags
| Preverbed _ pvs _ _ ->
print_uni_taddhita pvs m phase form sfx sfx_phase sfx_tags
| _ -> failwith "taddhita recursion unavailable"
; ps tr_end (* tr ends *) ; ps tr_end (* tr ends *)
(*i module Phonetics = struct i*) (*i module Phonetics = struct i*)
...@@ -318,7 +318,7 @@ value phantom_elim = fun ...@@ -318,7 +318,7 @@ value phantom_elim = fun
(* For m.rj-like verbs (Whitney§219-a) Panini{8,2,36} (* For m.rj-like verbs (Whitney§219-a) Panini{8,2,36}
"bhraaj" "m.rj" "yaj1" "raaj1" "vraj" "s.rj1" "bhraaj" "m.rj" "yaj1" "raaj1" "vraj" "s.rj1" "bh.rjj"
replace phoneme j=24 by j'=124 with sandhi j'+t = .s.t (j' is j going to z) *) replace phoneme j=24 by j'=124 with sandhi j'+t = .s.t (j' is j going to z) *)
value mrijify stem = match stem with value mrijify stem = match stem with
[ [ 24 :: r ] -> [ 124 :: r ] [ [ 24 :: r ] -> [ 124 :: r ]
...@@ -394,8 +394,10 @@ value finalize rstem = match rstem with ...@@ -394,8 +394,10 @@ value finalize rstem = match rstem with
| 24 (* j *) (* e.g. bhi{\d s}aj; bhuj; as{\d r}j -yuj *) | 24 (* j *) (* e.g. bhi{\d s}aj; bhuj; as{\d r}j -yuj *)
| 25 (* jh *) -> match rest with | 25 (* jh *) -> match rest with
[ [ 26 (* \~n *) :: ante ] -> [ 21 (* \.n *) :: ante ] [ [ 26 (* \~n *) :: ante ] -> [ 21 (* \.n *) :: ante ]
| [ 21 (* \.n *) :: _ ] -> rest | [ 24 (* j *) :: ante ] | [ 22 (* c *) :: ante ]
| _ -> [ 17 (* k *) :: rest ] (* but sometimes {\d t} - beware *) -> [ 27 (* {\d t} *) :: ante ] (* majj bh.rjj pracch *)
| _ -> [ 17 (* k *) :: rest ] (* but sometimes {\d t} - eg devej *)
| 20 (* gh *) -> [ 17 (* k *) :: asp rest ] | 20 (* gh *) -> [ 17 (* k *) :: asp rest ]
| 26 (* \~n *) -> [ 21 (* \.n *) :: rest ] | 26 (* \~n *) -> [ 21 (* \.n *) :: rest ]
...@@ -415,7 +417,13 @@ value finalize rstem = match rstem with ...@@ -415,7 +417,13 @@ value finalize rstem = match rstem with
| _ -> [ 27 (* {\d t} *) :: rest ] (* default *) | _ -> [ 27 (* {\d t} *) :: rest ] (* default *)
(* NB optionally nak Whitney§218a *) (* NB optionally nak Whitney§218a *)
| 47 (* {\d s} *) -> [ 27 (* {\d t} *) :: rest ] (* e.g. dvi{\d s} {\R} dvi{\d t} *) | 47 (* {\d s} *) -> match rest with
[ [ 7 :: [ 35 :: _ ] ] (* -dh{\d r}{\d s} {\R} -dh{\d r}k *)
-> [ 17 (* k *) :: rest ] (* Kane §97 *)
| [ 17 :: ante ] (* -k{\d s} {\R} -k *)
-> [ 17 (* k *) :: ante ] (* vivik.s Kane §97 but MW: vivi.t *)
| _ -> [ 27 (* {\d t} *) :: rest ] (* e.g. dvi{\d s} {\R} dvi{\d t} *)
| 49 (* h *) -> [ 27 (* {\d t} *) :: asp rest ] (* e.g. lih {\R} li{\d t} *) | 49 (* h *) -> [ 27 (* {\d t} *) :: asp rest ] (* e.g. lih {\R} li{\d t} *)
| 149 (* h' *) -> [ 17 (* k *) :: asp rest ] (* -duh {\R} -dhuk , impft doh adhok, etc. *) | 149 (* h' *) -> [ 17 (* k *) :: asp rest ] (* -duh {\R} -dhuk , impft doh adhok, etc. *)
| 249 (* h'' *) -> [ 32 (* t *) :: asp rest ] | 249 (* h'' *) -> [ 32 (* t *) :: asp rest ]
...@@ -443,7 +451,11 @@ value finalize_r stem = match stem with ...@@ -443,7 +451,11 @@ value finalize_r stem = match stem with
else stem else stem
| [] -> failwith "Illegal arg r to finalize" | [] -> failwith "Illegal arg r to finalize"
| 48 (* s *) -> [ 34 (* t *) :: rest ] (* for roots sras dhvas *) | 48 (* s *) -> match rest with
[ [ 1 :: [ 45 :: [ 35 :: _ ] ] ] -> [ 34 (* t *) :: rest ] (* dhvas *)
| [ 1 :: [ 45 :: _ ] ] -> stem (* suvas *)
| _ -> [ 34 (* t *) :: rest ] (* sras *)
| _ -> finalize stem | _ -> finalize stem
(* CGI-bin sktreader alias Reader for segmentation, tagging and parsing. (* CGI-bin sktreader alias Reader for segmentation, tagging and parsing.
...@@ -8,4 +8,4 @@ ...@@ -8,4 +8,4 @@
(* Generated by make version - see main Makefile *) (* Generated by make version - see main Makefile *)
value version="3.12" and version_date="2019-01-22"; value version="3.13" and version_date="2019-02-03";
VERSION='3.12' VERSION='3.13'
DATE='2019-01-22' DATE='2019-02-03'
