Commit 16bb487a authored by Gérard Huet's avatar Gérard Huet
uuh now takes periphratic perfect
parent c48147af
...@@ -3543,7 +3543,7 @@ conjugations, denominative verbs and a few roots. It builds a form in -aam ...@@ -3543,7 +3543,7 @@ conjugations, denominative verbs and a few roots. It builds a form in -aam
suffixed by a perfect form of the auxiliairies k.r bhuu et as \Pan{3,1,35-40} *) suffixed by a perfect form of the auxiliairies k.r bhuu et as \Pan{3,1,35-40} *)
value peri_perf_stem entry = value peri_perf_stem entry =
let stem = match entry with let stem = match entry with
[ "iik.s" | "ii.d" | "iir" | "iih" | "uk.s" | "uc" | "ujjh" | "edh" [ "iik.s" | "ii.d" | "iir" | "iih" | "uk.s" | "uc" | "ujjh" | "uuh" | "edh"
(* Macdonell§140a1 Whitney§1071c *) (* Macdonell§140a1 Whitney§1071c *)
| "ind" | "indh" | "inv" | "umbh" | "cakaas" -> entry | "ind" | "indh" | "inv" | "umbh" | "cakaas" -> entry
| "aas#2" -> "aas" (* trim *) | "aas#2" -> "aas" (* trim *)
...@@ -5356,7 +5356,7 @@ value den_stem_a entry = (* in general transitive Whitney§1059c *) ...@@ -5356,7 +5356,7 @@ value den_stem_a entry = (* in general transitive Whitney§1059c *)
| "kelaa" | "rekhaa" | "tiras" | "uras" | "payas" (* Kale§660 *) | "kelaa" | "rekhaa" | "tiras" | "uras" | "payas" (* Kale§660 *)
| "vaac" (* consonant Kale§642 *) | "vaac" (* consonant Kale§642 *)
| "dantura" (* possess *) | "dantura" (* possess *)
| "viira" | "zabda" | "tira" (* MW *) | "ma~njara" | "sraja" | "viira" | "zabda" | "tira" (* MW *) | "ma~njara" | "sraja" | "manas"
-> rstem (* -yati *) (* standard causative meaning *) -> rstem (* -yati *) (* standard causative meaning *)
| "madhu" | "v.r.sa" (* also madhvasyati v.r.siiyati *) | "madhu" | "v.r.sa" (* also madhvasyati v.r.siiyati *)
| "k.siira" | "lava.na" (* also putra *) | "k.siira" | "lava.na" (* also putra *)
...@@ -5367,8 +5367,8 @@ value den_stem_a entry = (* in general transitive Whitney§1059c *) ...@@ -5367,8 +5367,8 @@ value den_stem_a entry = (* in general transitive Whitney§1059c *)
value den_stem_m entry = (* in general intransitive or reflexive Whitney§1059c *) value den_stem_m entry = (* in general intransitive or reflexive Whitney§1059c *)
let rstem = revstem entry in let rstem = revstem entry in
match entry with match entry with
[ "artha" | "i.sa" | "kuha" | "carca" | "mantra" | "muutra" | "m.rga" [ "artha" | "i.sa" | "kuha" | "carca" | "manas" | "mantra" | "muutra"
| "viira" | "safgraama" | "suutra" (* also zithila below *) | "m.rga" | "viira" | "safgraama" | "suutra" (* also zithila below *)
-> rstem (* (a)-yate *) -> rstem (* (a)-yate *)
| "asuuya" (* "asu" lengthened *) | "vyaya" (* euphony *) | "asuuya" (* "asu" lengthened *) | "vyaya" (* euphony *)
-> trunc (trunc rstem) -> trunc (trunc rstem)
...@@ -5567,7 +5567,8 @@ value compute_conjugs_stems entry (vmorph,aa) = do (* main *) ...@@ -5567,7 +5567,8 @@ value compute_conjugs_stems entry (vmorph,aa) = do (* main *)
[ "paz" (* d.rz *) | "bruu" (* vac *) | "ma.mh" (* mah *) [ "paz" (* d.rz *) | "bruu" (* vac *) | "ma.mh" (* mah *)
| "ind" | "indh" | "inv" | "cakaas" | "dhii#1" | "vidh#1" -> () | "ind" | "indh" | "inv" | "cakaas" | "dhii#1" | "vidh#1" -> ()
(* no perfect *) (* no perfect *)
| _ -> compute_perfect entry | "uuh" -> () (* periphrastic *)
; (* Periphrastic Perfect *) (* .namul on demand - except gana 10 above *) ; (* Periphrastic Perfect *) (* .namul on demand - except gana 10 above *)
try let stem = peri_perf_stem entry in try let stem = peri_perf_stem entry in
