GitLab
Support
Community forum
Keyboard shortcuts
H
Heritage_Platform
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Gérard Huet
Heritage_Platform
c0cef2c8
c0cef2c8
Gérard Huet
Root vlii
d3a0f200
9
Expand all
9 changed files
269 additions
365 deletions
+269
-365
DOC/Heritage_Platform.pdf
+0
DOC/Heritage_Platform.tex
+223
-321
DOC/docintro
DOC/docintro
+1
-1
ML/COPYRIGHT
ML/COPYRIGHT
+2
-2
ML/canon.ml
ML/canon.ml
+4
-4
ML/interface.ml
ML/interface.ml
+1
-1
ML/verbs.ml
ML/verbs.ml
+34
-32
ML/version.ml
ML/version.ml
+3
-3
SETUP/version.txt
SETUP/version.txt
+1
-1
c0cef2c8
No preview for this file type
c0cef2c8
This diff is collapsed.
DOC/docintro
c0cef2c8
@@ -6,7 +6,7 @@
@@ -6,7 +6,7 @@
{\Large (Sanskrit Library V#VERSION; Zen toolkit V3.1)}\\[15pt]
{\large #DATE}\\[15pt]
{\large G\'erard Huet \& Pawan Goyal}\\[10pt]
{\large Copyright \copyright ~2000-201
7
Inria}\\[20pt]
8
Inria}\\[20pt]
\end{center}
\end{center}
% Macros
% Macros
ML/COPYRIGHT
c0cef2c8
The Sanskrit Heritage Platform
The Sanskrit Heritage Dictionary Generator
Gérard Huet & Pawan Goyal
Gérard Huet
(* ©2018 Institut National de Recherche en Informatique et en Automatique *)
ML/canon.ml
c0cef2c8
@@ -26,7 +26,7 @@ value canon = fun
12
"o"
12
"o"
13
"au"
13
"au"
14
".m"
(* anusvaara *)
14
".m"
(* anusvaara *)
15
(* anun
a
asika candrabindu *)
15
(* anun
16
".h"
16
".h"
17
"k"
17
"k"
18
"kh"
18
"kh"
@@ -381,7 +381,7 @@ value canon2 = fun
49
"h"
49
"h"
50
"_"
(* hiatus *)
50
"_"
(* hiatus *)
2
(* Inconsistent with previous versions *)
2
3
"A|a"
(* sandhi of A and (a,A) - phantom phoneme *)
3
"A|a"
4
"A|i"
(* sandhi of A and (i,I) - phantom phoneme *)
4
"A|i"
5
"A|u"
(* sandhi of A and (u,U) - phantom phoneme *)
5
"A|u"
@@ -396,9 +396,9 @@ value catenate2 c (s,b) =
let
protected
if
b
b'
then
"_"
s
else
s
in
let
protected
if
b
b'
then
"_"
s
else
s
in
canon2
c
protected
b'
canon2
c
protected
b'
[decode2 : word -> string
decode2 : word -> string (debug for [Morpho_xml
value
decode2
word
value
decode2
word
try
let
s
,_
fold_right
catenate2
word
False
in
s
try
let
s
,_
fold_right
catenate2
word
False
in
s
Failure
_
failwith
"decode2: "
robust_decode
Word
mirror
word
Failure
_
failwith
"decode2: "
robust_decode
Word
mirror
word
value
canon_upper
fun
value
canon_upper
fun
ML/interface.ml
c0cef2c8
@@ -540,7 +540,7 @@ value graph_engine () = do
allSol (deprecated Validate mode)
corpus sentenceNumber linkNumber (Corpus mode)
corpdir sentno corpmode (defined in Params)
guess gender revised
rev_off rev_ind (User-aid)
[rev_off] [rev_ind] (User-aid)
let
url_encoded_input
get
"text"
env
let
url_encoded_input
get
"text"
env
url_encoded_topic
get
"topic"
env
(* topic carry-over *)
url_encoded_topic
get
"topic"
env
st
get
"st"
env
"t"
(* sentence parse default *)
st
get
"st"
env
"t"
ML/verbs.ml
c0cef2c8
@@ -376,7 +376,7 @@ value stems root =
"spardh"
sampra
"sp.rdh"
"spardh"
sampra
"sp.rdh"
"svap"
sampra
"sup"
(* \Pan{6,1,15} *)
"svap"
sampra
"sup"
(* \Pan{6,1,15} *)
(* note "vac", "yaj" etc not concerned although having samprasaara.na *)
_
let
weak
weak_stem
root
rstem
_
let
weak
weak_stem
root
rstem
strong
strong_stem
root
rstem
in
strong
strong_stem
root
rstem
in
let
long
lengthened
weak
in
let
long
lengthened
weak
in
weak
strong
long
weak
strong
long
@@ -523,9 +523,9 @@ value redup3 entry rstem =
_
rstem
_
rstem
in
in
strong
rstem
wstem
strong
rstem
wstem
glue
revaffix
rv
rc
in
glue
revaffix
rv
rc
in
if
entry
"s.r"
then
ad-hoc nonsense
if
entry
"s.r"
then
i ad-hoc nonsense to avoid si.sarti ? i
revcode
"sisar"
revcode
"sis.r"
iiflag
(* to avoid si.sarti ?!? *)
revcode
"sisar"
revcode
"sis.r"
iiflag
else
glue
strong
glue
weak
iiflag
else
glue
strong
glue
weak
iiflag
@@ -2397,7 +2397,7 @@ value intercalates root =
"vyadh"
"zak"
"zad"
"zap"
"zi.s"
"zudh"
"zu.s"
"vyadh"
"zak"
"zad"
"zap"
"zi.s"
"zudh"
"zu.s"
"zli.s"
"sa~nj"
"sic"
"sidh#1"
"s.rp"
"skand"
"zli.s"
"sa~nj"
"sic"
"sidh#1"
"s.rp"
"skand"
"sva~nj"
"svid#2"
"had"
"sva~nj"
"svid#2"
"had"
anit
anit
_
set
(* default all multisyllabic, gana 10, nominal verbs plus:
_
set
[ "afg" | "a~nc" | "an#2" | "arh" | "av" | "az#1" | "az#2" | "as#2" | "aas#2"
| "indh" | "inv" | "i.s#1" | "i.s#2" | "iik.s" | "iifkh" | "ii.d" | "iiz#1"
@@ -2545,8 +2545,8 @@ value compute_ppp_stems entry rstem =
"tud#1"
"t.rd"
"t.rr"
"dagh"
"d.rr"
"dev"
"draa#1"
"draa#2"
"tud#1"
"t.rd"
"t.rr"
"dagh"
"d.rr"
"dev"
"draa#1"
"draa#2"
"nud"
"pad#1"
"pi#2"
"p.rr"
"pyaa"
"bha~nj"
"bhid#1"
"bhuj#1"
"nud"
"pad#1"
"pi#2"
"p.rr"
"pyaa"
"bha~nj"
"bhid#1"
"bhuj#1"
"majj"
"man"
"mid"
"mlaa"
"ri"
"lii"
"luu#1"
"vij"
"vid#2"
"majj"
"man"
"mid"
"mlaa"
"ri"
"lii"
"luu#1"
"vij"
"vid#2"
zad"
"zuu"
"z.rr"
"sad#1"
"skand"
"syand"
"st.rr"
"styaa
vlii"
"zad"
"zuu"
"z.rr"
"sad#1"
"skand"
"syand"
"st.rr
"had"
"svid#2"
"haa#2"
(* but not "k.svi.d" "zrath" *)
styaa"
had"
"svid#2"
"haa#2"
(* except lag which is "nipaatana" \Pan{7,2,18} *)
let
ppna
w
Na
w
in
let
ppna
w
Na
w
in
@@ -3977,18 +3977,19 @@ value compute_aorist entry =
"dhaa#1"
"dhaa#2"
"paa#1"
"bhuu#1"
"muc#1"
"zaa"
"dhaa#1"
"dhaa#2"
"paa#1"
"bhuu#1"
"muc#1"
"zaa"
"saa#1"
"sthaa#1"
"has"
"haa#1"
do
"saa#1"
"sthaa#1"
"has"
"haa#1"
do
compute_root_aorista
weak
strong
entry
weak
strong
entry
if
entry
"k.r#1"
entry
"gam"
entry
"jan"
match
entry
then
compute_root_aoristm
weak
entry
(* rare *)
"k.r#1"
"gam"
"jan"
weak
entry
(* rare *)
else
if
entry
"sthaa#1"
(* Whitney §834a. *)
"sthaa#1"
then
revstem
"sthi"
entry
(* asthita *)
revstem
"sthi"
entry
(* asthita *)
(*i [else if entry = "dhaa#1" then compute_root_aoristm (revstem "dhii") entry] ? i*)
(*i [| "dhaa#1" -> compute_root_aoristm (revstem "dhii") entry] ? i*)
else
_
let
stem
if
entry
"muc#1"
then
strong
else
match
long
let
stem
if
entry
"muc#1"
then
strong
else
match
long
2
(* aa *)
_
42
(* y *)
long
2
(* aa *)
_
42
(* y *)
long
_
long
_
long
in
in
compute_root_aoristp
stem
entry
(* passive *)
stem
entry
(* passive *)
f
or root aorist participles, see Whitney§840 and Burrow p178 *)
F
"prii"
let
st
revcode
"priiyaa"
in
st
st
entry
"prii"
let
st
revcode
"priiyaa"
in
st
st
entry
"svid#2"
let
st
revcode
"svidyaa"
in
st
st
entry
"svid#2"
let
st
revcode
"svidyaa"
in
st
st
entry
@@ -4003,8 +4004,8 @@ value compute_aorist entry =
"rabh"
revcode
"rambh"
entry
"rabh"
revcode
"rambh"
entry
"jaag.r"
"t.rr"
"pac"
"zru"
"stu"
"hu"
"jaag.r"
"t.rr"
"pac"
"zru"
"stu"
"hu"
long
entry
long
entry
(* "zru" -> azraayi Whitney§844a typo ? (azraayi WR)
(* NB "zru" -> azraavi WR while Whitney§844a azraayi typo
_
(* "i" -> iiyaat
difficile
_
(* "i" -> iiyaat
hard
match
entry
(* 2. thematic aorist af *)
match
entry
"aap"
"krudh"
"gam"
"g.rdh"
"ghas"
"das"
"dyut#1"
"muc#1"
"aap"
"krudh"
"gam"
"g.rdh"
"ghas"
"das"
"dyut#1"
"muc#1"
@@ -4012,7 +4013,7 @@ value compute_aorist entry =
"zuc#1"
"zudh"
"sic"
"stan"
"huu"
"zuc#1"
"zudh"
"sic"
"stan"
"huu"
do
do
compute_thematic_aorista
weak
entry
weak
entry
compute_thematic_aoristm
weak
entry
(* middle
is
very rare *)
weak
entry
(* middle very rare *)
"vyaa"
let
stem
revcode
"vi"
in
do
"vyaa"
let
stem
revcode
"vi"
in
do
stem
entry
stem
entry
@@ -4038,8 +4039,8 @@ value compute_aorist entry =
compute_redup_aorista
stem
entry
(* but atu.s.tavam RV (WR) *)
stem
entry
compute_redup_aoristm
stem
entry
stem
entry
"iik.s"
"k
lid"
"gup"
"cur"
"m.r"
"d.rz#1"
"dyut#1"
"vrazc
"iik.s"
"k
amp"
"klid"
"gup"
"cur"
"m.r"
"d.rz#1"
"dyut#1
(* active only *)
"vrazc"
(* active only *)
let
stem
redup_aor
weak
entry
in
let
stem
redup_aor
weak
entry
in
stem
entry
stem
entry
"grah"
do
"grah"
do
@@ -4047,8 +4048,7 @@ value compute_aorist entry =
stem
entry
stem
entry
stem
entry
stem
entry
let
stem
redup_aor
revcode
"grabh"
entry
in
do
let
stem
redup_aor
revcode
"grabh"
entry
in
do
(* ved Whitney§223g *)
(* ved -- Whitney§223g *)
stem
entry
stem
entry
stem
entry
stem
entry
@@ -4058,7 +4058,7 @@ value compute_aorist entry =
stem
entry
stem
entry
(* then exceptions to treatment of aa with intercalaring ii *)
"raadh"
let
stem
redup_aor
revcode
"radh"
entry
in
(* riiradh *)
"raadh"
let
stem
redup_aor
revcode
"radh"
(* riiradh *)
entry
in
stem
entry
(* Macdonnel p 126 *)
stem
entry
"haa#1"
let
stem
revcode
"jiijah"
in
"haa#1"
let
stem
revcode
"jiijah"
in
stem
entry
stem
entry
@@ -4074,12 +4074,12 @@ value compute_aorist entry =
"nii#1"
"pac"
"praz"
"prii"
"budh#1"
"bhaa#1"
"bhii#1"
"nii#1"
"pac"
"praz"
"prii"
"budh#1"
"bhaa#1"
"bhii#1"
"muc#1"
"yaj#1"
"yuj#1"
"ram"
"labh"
"v.r#2"
"vyadh"
"zru"
"muc#1"
"yaj#1"
"yuj#1"
"ram"
"labh"
"v.r#2"
"vyadh"
"zru"
"s.rj#1"
"stu"
"sp.rz#1"
"hu"
do
"s.rj#1"
"stu"
"sp.rz#1"
"hu"
do
let
stem
a
match
entry
let
stem
match
entry
"d.rz#1"
"s.rj#1"
"sp.rz#1"
long_metathesis
weak
"d.rz#1"
"s.rj#1"
"sp.rz#1"
long_metathesis
weak
"ram"
weak
"ram"
weak
_
long
_
long
in
in
compute_ath_s_aorista
stem
a
entry
stem
entry
if
entry
"yuj#1"
entry
"chid#1"
if
entry
"yuj#1"
entry
"chid#1"
then
strong
entry
else
then
strong
entry
else
(* ayok.siit and acchetsiit besides ayauk.siit and acchaitsiit *)
@@ -4132,7 +4132,7 @@ value compute_aorist entry =
compute_ath_is_aorista
revcode
"zve"
entry
revcode
"zve"
entry
"kan"
"k.r#2"
"p.rr"
(* active only *)
"kan"
"k.r#2"
"p.rr"
(* active only *)
long
entry
long
entry
"jan"
"zii#1"
"spand"
(* middle only *)
kamp"
jan"
"zii#1"
"spand"
(* middle only *)
compute_ath_is_aoristm
strong
entry
strong
entry
"grah"
do
"grah"
do
let
stem
revcode
"grah"
in
do
(* same as group above *)
let
stem
revcode
"grah"
in
do
@@ -4336,6 +4336,7 @@ value perif conj perstem entry = do
"p.rr"
revcode
"puuri"
(* puuritum *)
"p.rr"
revcode
"puuri"
(* puuritum *)
"sva~nj"
revcode
"svaj"
(* svaktum *)
"sva~nj"
revcode
"svaj"
(* svaktum *)
"sa~nj"
revcode
"saj"
(* saktum *)
"sa~nj"
revcode
"saj"
(* saktum *)
".dii"
revcode
".dii"
(* .diitum *)
_
perstem
_
perstem
_
perstem
_
perstem
@@ -5276,13 +5277,14 @@ value den_stem_a entry = (* in general transitive Whitney§1059c *)
"kar.na"
"kalafka"
"kalu.sa"
"kavala"
"ku.t.ta"
"kusuma"
"kar.na"
"kalafka"
"kalu.sa"
"kavala"
"ku.t.ta"
"kusuma"
"kha.da"
"garva"
"gopaa"
"carca"
"cuur.na"
"chala"
"chidra"
"kha.da"
"garva"
"gopaa"
"carca"
"cuur.na"
"chala"
"chidra"
"tantra"
"tarafga"
"taru.na"
"tuhina"
"da.n.da"
"deva"
"dola"
"tantra"
"tarafga"
"taru.na"
"tuhina"
"da.n.da"
"deva"
"dola"
"dhiira#1"
"nuutana"
"pa.tapa.taa"
"pallava"
"pavitra"
"paaza"
"dravat"
"dhiira#1"
"nuutana"
"pa.tapa.taa"
"pallava"
"pi.n.da"
"pulaka"
"puula"
"pratikuula"
"prati.sedha"
"pavitra"
"paaza"
"pi.n.da"
"pulaka"
"puula"
"pratikuula"
"pradak.si.na"
"prasaada"
"bhi.saj"
"mantra"
"malina"
"mizra"
"prati.sedha"
"pradak.si.na"
"prasaada"
"bhi.saj"
"mantra"
"mukula"
"mukhara"
"mu.n.da"
"muutra"
"m.rga"
"yantra"
"rasa"
"malina"
"mizra"
"mukula"
"mukhara"
"mu.n.da"
"muutra"
"ruuk.sa"
"lagha"
(* u -> a *)
"var.na"
"vaasa#3"
"vizada"
"m.rga"
"yantra"
"rasa"
"ruuk.sa"
"lagha"
(* u -> a *)
"vra.na"
"zaanta"
"zithila"
"zyena"
".sa.n.dha"
"sapi.n.da"
"var.na"
"vaasa#3"
"vizada"
"vra.na"
"zaanta"
"zithila"
"saphala"
"sabhaaja"
"saantva"
"saavadhaana"
"suutra"
"stena"
"zyena"
".sa.n.dha"
"sapi.n.da"
"saphala"
"sabhaaja"
"saantva"
"saavadhaana"
"suutra"
"stena"
"sthaga"
"tapas"
(* practice \Pan{3,1,15} *)
"sthaga"
"tapas"
"u.sas"
"namas"
"varivas"
(* do \Pan{3,1,19} *)
"u.sas"
"namas"
"varivas"
"udan"
(* Kale§645 *)
"udan"
(* Kale§645 *)
ML/version.ml
c0cef2c8
Gérard Huet
(* Generated by make version - see main Makefile *)
value
version
"3.05"
version_date
"2018-0
3-15
value
version
"3.05"
version_date
"2018-0
4-01
SETUP/version.txt
c0cef2c8
VERSION='3.05'
VERSION='3.05'
DATE='2018-0
3-15
DATE='2018-0
4-01
