Commit 49da566f authored by Gérard Huet's avatar Gérard Huet
New style |> Html et Web
parent 0fb78fd9
This diff is collapsed.
No preview for this file type
...@@ -12,7 +12,6 @@ ...@@ -12,7 +12,6 @@
(* Generate the page displaying a view of the given corpus subdirectory. (* Generate the page displaying a view of the given corpus subdirectory.
The output channel is as always either [stdout] for CGI output or The output channel is as always either [stdout] for CGI output or
a static HTML file (according to the "magic switch" a static HTML file (according to the "magic switch"
Web.output_channel). NB: No error handling is done by this [Web.output_channel]). NB: No error handling is done by this function. *)
function. *)
value mk_page : string -> Web_corpus.permission -> unit value mk_page : string -> Web_corpus.permission -> unit
...@@ -76,9 +76,9 @@ value transducer = fun ...@@ -76,9 +76,9 @@ value transducer = fun
| Vocc -> transducers.vocc (* consonant-initial vocatives *) | Vocc -> transducers.vocc (* consonant-initial vocatives *)
| Iiy -> transducers.iiy (* iic avyayiibhava *) | Iiy -> transducers.iiy (* iic avyayiibhava *)
| Avy -> transducers.avya (* ifc avyayiibhava *) | Avy -> transducers.avya (* ifc avyayiibhava *)
| Inftu -> transducers.inftu (* infinitives in -tu *) | Inftu -> transducers.inftu (* infinitives in -tu iic. Renou HLS 72 *)
| Kama -> transducers.kama (* forms of kaama *) | Kama -> transducers.kama (* ifcs of kaama/manas: tyaktukaama dra.s.tumanas *)
| Sfx -> transducers.sfx (* ifc taddhita suffixes *) | Sfx -> transducers.sfx (* ifc taddhita suffixes *)
| Isfx -> transducers.isfx (* iifc taddhita suffixes *) | Isfx -> transducers.isfx (* iifc taddhita suffixes *)
| Cache -> transducers.cache (* cached forms *) | Cache -> transducers.cache (* cached forms *)
| Noun | Iic | Iik | Voca | Krid | Pvk | Vok | Noun | Iic | Iik | Voca | Krid | Pvk | Vok
...@@ -423,14 +423,14 @@ value check_sentence translit us text_orig checkpoints sentence ...@@ -423,14 +423,14 @@ value check_sentence translit us text_orig checkpoints sentence
] in do ] in do
{ make_visual cur_chunk.offset { make_visual cur_chunk.offset
; find_conflict 0 ; find_conflict 0
; pl html_break ; html_break |> pl
; pl (html_latin16 "Sentence: ") ; html_latin16 "Sentence: " |> pl
; ps (deva16_blue devainput) (* devanagari *) ; deva16_blue devainput |> ps (* devanagari *)
; pl html_break ; html_break |> ps
; ps (div_begin Latin16) ; div_begin Latin16 |> ps
; pl (table_begin Spacing20) ; table_begin Spacing20 |> pl
; pl tr_begin ; tr_begin |> pl
; ps (td_wrap (call_undo text checkpoints ^ "Undo")) ; td_wrap (call_undo text checkpoints ^ "Undo") |> ps
; let call_scl_parser n = (* invocation of scl parser *) ; let call_scl_parser n = (* invocation of scl parser *)
if scl_toggle then if scl_toggle then
ps (td_wrap (call_reader text cpts "o" ^ "UoH Analysis Mode")) ps (td_wrap (call_reader text cpts "o" ^ "UoH Analysis Mode"))
...@@ -438,34 +438,34 @@ value check_sentence translit us text_orig checkpoints sentence ...@@ -438,34 +438,34 @@ value check_sentence translit us text_orig checkpoints sentence
match count with match count with
[ Num.Int n -> if n > max_count then [ Num.Int n -> if n > max_count then
(* too many solutions would choke the parsers *) (* too many solutions would choke the parsers *)
ps (td_wrap ("(" ^ string_of_int n ^ " Solutions)")) td_wrap ("(" ^ string_of_int n ^ " Solutions)") |> ps
else if n=1 (* Unique remaining solution *) then do else if n=1 (* Unique remaining solution *) then do
{ ps (td_wrap (call_parser text cpts ^ "Unique Solution")) { td_wrap (call_parser text cpts ^ "Unique Solution") |> ps
; call_scl_parser 1 ; call_scl_parser 1
else do else do
{ ps (td_wrap (call_reader text cpts "p" ^ "Filtered Solutions")) { td_wrap (call_reader text cpts "p" ^ "Filtered Solutions") |> ps
; let info = string_of_int n ^ if flag then "" else " Partial" in ; let info = string_of_int n ^ if flag then "" else " Partial" in
ps (td_wrap (call_reader text cpts "t" ^ "All " ^ info ^ " Solutions")) td_wrap (call_reader text cpts "t" ^ "All " ^ info ^ " Solutions") |> ps
; call_scl_parser n ; call_scl_parser n
| _ -> ps (td_wrap "(More than 2^32 Solutions!)") | _ -> td_wrap "(More than 2^32 Solutions!)" |> ps
; pl tr_end ; tr_end |> pl
; pl table_end ; table_end |> pl
; ps div_end (* Latin16 *) ; div_end |> ps (* Latin16 *)
; ps (div_begin Latin12) ; div_begin Latin12 |> ps
; pl (table_begin Tcenter) ; table_begin Tcenter |> pl
; ps tr_begin ; tr_begin |> ps
; List.iter update_col_length chunks ; List.iter update_col_length chunks
; if Paths.platform="Station" then print_all text checkpoints chunks 0 ; if Paths.platform="Station" then print_all text checkpoints chunks 0
else List.iter print_first_server chunks else List.iter print_first_server chunks
; print_interf text checkpoints () ; print_interf text checkpoints ()
; ps div_end (* Latin12 *) ; div_end |> ps (* Latin12 *)
; reset_graph () ; reset_graph ()
; reset_visual () ; reset_visual ()
; set_cur_offset 0 ; set_cur_offset 0
...@@ -632,8 +632,8 @@ value graph_engine () = do ...@@ -632,8 +632,8 @@ value graph_engine () = do
(* Save sentence button *) (* Save sentence button *)
; if corpus_permission = Web_corpus.Annotator then ; if corpus_permission = Web_corpus.Annotator then
(* TODO: use segment_all to compute the nb of sols instead of (* TODO: use [segment_all] to compute the nb of sols instead of
passing 0 as nb_sols. *) passing 0 to [nb_sols]. *)
save_button query (Num.num_of_int 0) |> pl save_button query (Num.num_of_int 0) |> pl
else else
...@@ -173,7 +173,7 @@ value tags_of phase word = ...@@ -173,7 +173,7 @@ value tags_of phase word =
as sup kridanta forms with preverbs. The preverbs are packed in pv. *) as sup kridanta forms with preverbs. The preverbs are packed in pv. *)
| Tad (ph,sfx_ph) form sfx -> (* tag inherited from fake suffix entry *) | Tad (ph,sfx_ph) form sfx -> (* tag inherited from fake suffix entry *)
let sfx_tag = Deco.assoc sfx (morpho_tags sfx_ph) in let sfx_tag = Deco.assoc sfx (morpho_tags sfx_ph) in
(* let stem_tag = Deco.assoc sfx (morpho_tags ph) in - possible extension *) (* [let stem_tag = Deco.assoc sfx (morpho_tags ph) in] - possible extension *)
Taddhita (ph,form) [ 0 :: sfx ] sfx_ph sfx_tag (* 0 = "-" *) Taddhita (ph,form) [ 0 :: sfx ] sfx_ph sfx_tag (* 0 = "-" *)
| _ -> Atomic (Deco.assoc word (morpho_tags phase)) | _ -> Atomic (Deco.assoc word (morpho_tags phase))
(* NB Atomic comprises tin verbal forms of roots as well as sup atomic forms (* NB Atomic comprises tin verbal forms of roots as well as sup atomic forms
...@@ -48,18 +48,17 @@ value populate_corpus dirname file = ...@@ -48,18 +48,17 @@ value populate_corpus dirname file =
in in
let rec aux i = let rec aux i =
try try
(* let line = input_line ch in *) (* [let line = input_line ch in
(* let state = *) let state =
(* [ (Params.corpus_dir, dirname) *) [ (Params.corpus_dir, dirname)
(* ; (Params.sentence_no, string_of_int i) *) ; (Params.sentence_no, string_of_int i)
(* ; ("t", Paths.default_transliteration) *) ; ("t", Paths.default_transliteration)
(* ] *) ] in] *)
(* in *) failwith "TODO"
failwith "TODO" (* [do
(* do *) { extract_citation state (Corp.save_sentence True Web.graph_cgi) line i
(* { extract_citation state (Corp.save_sentence True Web.graph_cgi) line i *) ; aux (i + 1)
(* ; aux (i + 1) *) }] *)
with with
[ End_of_file -> () ] [ End_of_file -> () ]
in in
...@@ -79,12 +78,12 @@ value populate_corpus dirname file = ...@@ -79,12 +78,12 @@ value populate_corpus dirname file =
(* Entry point *) (* Entry point *)
value main = value main =
let dirname = ref "" in let dirname = ref "" in
let opts = let opts =
Arg.align Arg.align
[ ("-d", Arg.Set_string dirname, [ ("-d", Arg.Set_string dirname,
" Specify the destination directory") ] " Specify the destination directory") ]
in in
let usage_msg = let usage_msg =
Filename.basename Sys.argv.(0) ^ " -d <dest_dir> <citation_file>" Filename.basename Sys.argv.(0) ^ " -d <dest_dir> <citation_file>"
in in
...@@ -57,7 +57,7 @@ value analysis_of_env env = ...@@ -57,7 +57,7 @@ value analysis_of_env env =
let cpts = let cpts =
env env
|> Cgi.decoded_get "cpts" "" |> Cgi.decoded_get "cpts" ""
(* |> Checkpoints.parse_cpts *) (* [|> Checkpoints.parse_cpts] *)
in in
let nb_sols = let nb_sols =
env env
...@@ -88,7 +88,7 @@ and participle = (* participles *) ...@@ -88,7 +88,7 @@ and participle = (* participles *)
| Pfutm (* middle future participle *) | Pfutm (* middle future participle *)
| Pfutp of kritya (* passive future/potential participle/gerundive 3 forms *) | Pfutp of kritya (* passive future/potential participle/gerundive 3 forms *)
| Action_noun (* generative only for auxiliaries, for cvi compounds *) | Action_noun (* generative only for auxiliaries, for cvi compounds *)
(*| Agent_noun, etc. -- non generative, must be lexicalized; see nominal *) (*| [Agent_noun], etc. -- non generative, must be lexicalized; see nominal *)
(* Invariable verbal forms. (* Invariable verbal forms.
...@@ -149,7 +149,7 @@ and krit = (* coarser than Paninian krit suffixes *) ...@@ -149,7 +149,7 @@ and krit = (* coarser than Paninian krit suffixes *)
| Action_ti (* ktin \Pan{3,3,94} -ti f. *) | Action_ti (* ktin \Pan{3,3,94} -ti f. *)
| Action_i (* ki \Pan{3,3,92-93} -i f. *) | Action_i (* ki \Pan{3,3,92-93} -i f. *)
| Action_root (* unknown krit of non-agent noun *) | Action_root (* unknown krit of non-agent noun *)
| Object_root (* we should probably lump action and object in Non_agent *) | Object_root (* we should probably lump action and object in [Non_agent] *)
| Object_a (* ka -a n. *) | Object_a (* ka -a n. *)
| Instrument (* ka \Pan{3,1,136} 0/amui n. *) | Instrument (* ka \Pan{3,1,136} 0/amui n. *)
| Instra (* .s.tran -tra n. -trii f. traa f. *) | Instra (* .s.tran -tra n. -trii f. traa f. *)
...@@ -892,7 +892,7 @@ EXTEND Gram (* skt to nat *) ...@@ -892,7 +892,7 @@ EXTEND Gram (* skt to nat *)
| LETTER "S" -> 148 | LETTER "S" -> 148
| LETTER "H" -> 149 | LETTER "H" -> 149
(* duplication with lower necessary in order to get proper sharing of prefix *) (* duplication with lower necessary in order to get proper sharing of prefix *)
| "\""; LETTER "m" -> 41 | "\""; LETTER "m" -> 15
| "\""; LETTER "n" -> 36 | "\""; LETTER "n" -> 36
| LETTER "f" -> 36 | LETTER "f" -> 36
| "\""; LETTER "s" -> 48 | "\""; LETTER "s" -> 48
...@@ -13,7 +13,7 @@ ...@@ -13,7 +13,7 @@
(* Terminology. record functions will build the forms needed by Conjugation (* Terminology. record functions will build the forms needed by Conjugation
and Stemming. After change of this file, and "make releasecgi", these tables and Stemming. After change of this file, and "make releasecgi", these tables
are updated. But the Reader/Parser needs a full pass of generation, with are updated. But the Reader/Parser needs a full pass of generation, with
"make scratch", in order to rebuild the full automata. *) "make scratch" from Dictionary, in order to rebuild the full automata. *)
(*i module Verbs = struct i*) (*i module Verbs = struct i*)
...@@ -21,7 +21,7 @@ open List; (* map, length, rev *) ...@@ -21,7 +21,7 @@ open List; (* map, length, rev *)
open Phonetics; (* [vowel, homonasal, duhify, mrijify, nahify, light, nasal, open Phonetics; (* [vowel, homonasal, duhify, mrijify, nahify, light, nasal,
gana, mult, aug, trunc_a, trunc_u, trunc_aa] *) gana, mult, aug, trunc_a, trunc_u, trunc_aa] *)
open Skt_morph; open Skt_morph;
open Inflected; (* [Conju, roots, enter1, morpho_gen, admits_aa] *) open Inflected; (* [Conju, Invar, Inftu, roots, enter1, morpho_gen, admits_aa] *)
open Parts; (* [memo_part, record_part, cau_gana, fix, fix_augment, rfix, open Parts; (* [memo_part, record_part, cau_gana, fix, fix_augment, rfix,
compute_participles] *) compute_participles] *)
(* This module also uses modules [List2 Word Control Canon Encode Int_sandhi] (* This module also uses modules [List2 Word Control Canon Encode Int_sandhi]
...@@ -3460,7 +3460,7 @@ value compute_perfect entry = ...@@ -3460,7 +3460,7 @@ value compute_perfect entry =
| "zvaa" -> let (strong, weak,_,_,_) = redup_perf "zuu" in (* \Pan{6,1,30} *) | "zvaa" -> let (strong, weak,_,_,_) = redup_perf "zuu" in (* \Pan{6,1,30} *)
compute_perfect_v strong weak entry (* Whitney 794b zizvaaya *) compute_perfect_v strong weak entry (* Whitney 794b zizvaaya *)
(* Whitney 794b also jyaa pyaa vyaa hvaa; we treat vyaa above, and hvaa is huu. (* Whitney 794b also jyaa pyaa vyaa hvaa; we treat vyaa above, and hvaa is huu.
Thus pyaa is covered by pii. jyaa#1 as jii gives jijyau same WR *) Thus pyaa is covered by pii. jyaa1 as jii gives jijyau same WR *)
| "indh" -> compute_perfectm Primary (revcode "iidh") entry | "indh" -> compute_perfectm Primary (revcode "iidh") entry
| "mah" -> let (strong, weak, _, _, _) = redup_perf entry in | "mah" -> let (strong, weak, _, _, _) = redup_perf entry in
compute_perfectm Primary strong entry (* ZZ Atma for Para root *) compute_perfectm Primary strong entry (* ZZ Atma for Para root *)
...@@ -4303,6 +4303,10 @@ value build_infinitive c inf_stem root = do ...@@ -4303,6 +4303,10 @@ value build_infinitive c inf_stem root = do
bhaavitum have to be entered as supplements; see Witney§1051c. *) bhaavitum have to be entered as supplements; see Witney§1051c. *)
{ enter1 root (Invar (c,Infi) (fix inf_stem "tum")) { enter1 root (Invar (c,Infi) (fix inf_stem "tum"))
; enter1 root (Inftu c (fix inf_stem "tu")) (* Xtu-kaama compounds *) ; enter1 root (Inftu c (fix inf_stem "tu")) (* Xtu-kaama compounds *)
(* NB. bahuv cpds in -kaama and -manas constructed with infinitives in -tu
See Renou HLS p72 from Patanjali; also Assimil p194 eg tyaktukaama
anu.s.thaatukaama "desirious to proceed" vaktukaama "who wants to speak"
dra.s.tumanas "inclined to see" *)
value perif conj perstem entry = do value perif conj perstem entry = do
...@@ -8,4 +8,4 @@ ...@@ -8,4 +8,4 @@
(* Generated by make version - see main Makefile *) (* Generated by make version - see main Makefile *)
value version="3.02" and version_date="2017-10-05"; value version="3.02" and version_date="2017-10-13";
VERSION='3.02' VERSION='3.02'
DATE='2017-10-05' DATE='2017-10-13'
