GitLab
Support
Community forum
Keyboard shortcuts
H
Heritage_Platform
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Gérard Huet
Heritage_Platform
26ee877e
26ee877e
Gérard Huet
added some preverbs to a few roots
0af044f0
5
5 changed files
20 additions
17 deletions
+20
-17
ML/pada.ml
ML/pada.ml
+8
-7
ML/verbs.ml
ML/verbs.ml
+4
-3
ML/version.ml
ML/version.ml
+1
-1
SETUP/version.txt
SETUP/version.txt
+1
-1
SITE/manual.html
SITE/manual.html
+6
-5
ML/pada.ml
26ee877e
@@ -109,7 +109,7 @@ value voices_of = fun
| "kram" | "krii" | "k.san" | "k.sap#1" | "k.sal" | "k.sip" | "k.sud" | "khan"
| "gam" | "garh" | "guh" | "gras" | "gha.t.t" | "cat" | "carc" | "ci"
| "cint" | "cud" | "ce.s.t" | "cyu" | "chad#1" | "chand" | "chid#1" | "jan"
| "juu" | "j~naa#1" | "jyaa#1" | "jyut" | "ta.d" | "tan#1" | "tan#2"
| "tap"
| "tud#1" | "tul" | "t.rd" | "daaz#1" | "diz#1" | "dih" | "duh#1"
| "dev#1" | "draa#2" | "dvi.s#1" | "dhaa#1" | "dhaav#1" | "dhaav#2"
| "dhuu#1" | "dh.r" | "dhva.ms" | "nah" | "naath" | "nij" | "nii#1"
@@ -141,7 +141,7 @@ jan 4A 1U
j.rr 1U 4P
jyaa1 4A 9P
.damb 1A 10P (vi-)
tap 1
P
4A
tap 1
U
4A
daa1 2P 1U 3U
draa2 2P 4U
dh.r.s 1U 5P
@@ -173,11 +173,12 @@ value voices_of_gana g root = match g with
match
root
".r"
"k.r.s"
"cur"
"tap"
"budh#1"
"van"
"v.r#1"
"su#2"
"suu#1"
Para
(* but ".r" Atma for pv sam \Pan{1,3,29} *)
Para
"i"
"gha.t.t"
"ghuur.n"
".damb"
"bhra.mz"
"mid"
"mok.s"
"lok"
"svid#2"
Atma
"i.s#1"
"j.rr"
"daa#1"
"dh.r.s"
"as#2"
"kuc"
"i.s#1"
".r"
(* ".r" Atma for pv sam \Pan{1,3,29} also "tap" *)
"j.rr"
"tap"
"daa#1"
"dh.r.s"
"as#2"
"kuc"
"m.rj"
"m.rd#1"
"rud#1"
"stambh"
Ubha
"kliiba"
Atma
(* denominative verb *)
@@ -237,12 +238,12 @@ value voices_of_gana g root = match g with
(* Refining with potential preverb *)
value
voices_of_pv
upasarga
gana
fun
(* gana only used for "tap" "i" *)
value
voices_of_pv
upasarga
gana
fun
".r"
(* Paninian requirements *)
"zru"
.r"
gam"
"svar"
"vid#1"
(* | "praz" *)
"zru"
"gam"
"svar"
"vid#1"
(* | "praz" *)
if
upasarga
"sam"
then
Atma
else
Para
(* \Pan{1,3,29} *)
(* "praz" used in Atma with aa- but also without pv in epics (MW) *)
"car"
if
upasarga
"sam"
then
Ubha
else
Para
(* \Pan{1,3,54} *)
.r"
car"
if
upasarga
"sam"
then
Ubha
else
Para
(* \Pan{1,3,54} *)
"viz#1"
if
upasarga
"ni"
then
Atma
else
Para
(* \Pan{1,3,17} *)
"huu"
match
upasarga
"ni"
"sam"
"upa"
"vi"
Atma
(* \Pan{1,3,30} *)
ML/verbs.ml
26ee877e
@@ -4865,9 +4865,10 @@ value compute_present_system entry rstem gana pada third =
match
voices_of_gana
gana
entry
Para
(* active only *)
if
pada
then
compute_thematic_active
gana
Primary
stem
entry
third
else
if
entry
".r"
then
(* for sam- *)
compute_thematic_middle
gana
Primary
stem
entry
third
else
emit_warning
"Unexpected middle form: "
entry
(* else if entry = ".r"
|| entry = "tap" then (* for sam- *)
compute_thematic_middle gana Primary stem entry third *)
else
emit_warning
entry
Atma
(* middle only *)
if
padam
then
emit_warning
"Unexpected active form: "
entry
else
gana
Primary
stem
entry
third
ML/version.ml
26ee877e
@@ -8,4 +8,4 @@
(* Generated by make version - see main Makefile *)
value
version
"3.08"
version_date
"2018-07-
07
value
version
"3.08"
version_date
"2018-07-
22
SETUP/version.txt
26ee877e
VERSION='3.08'
DATE='2018-07-
07
DATE='2018-07-
22
SITE/manual.html
26ee877e
@@ -50,7 +50,7 @@ published recently as
<a
href=
"http://jlm.ipipan.waw.pl/index.php/JLM/article/view/108/140"
Design and
analysis of a lean interface for Sanskrit corpus annotation
</a>
<p>
Written on
April 17th 2018, for Sanskrit Engine Version 3.06
Written on
July 22nd 2018, for Sanskrit Engine Version 3.08
<h2
class=
"b2"
id=
"tour"
First approach to using the Sanskrit Heritage engine
</h2>
@@ -139,10 +139,11 @@ stem <i>āptavya</i> and form <i>āptavyam</i> may be derived using the
conjugation cum declension tools.
<p>
Here we are lucky - the correct word analysis (
<i>
padapāṭha
</i>
) of the sentence is
obtainable as the sequence of all the words in the upper line of the diagram.
Some have no competitor, they are checked blue.
The ambiguous segments have two marks, a green check sign and a red cross sign.
<i>
padapāṭha
</i>
) of the
sentence is obtainable as the sequence of all the words in the upper line
of the diagram. Some have no competitor, they are checked blue.
The remaining ambiguous segments have two marks, a green check sign
In two clicks on the green upper signs you get the intended segmentation.
<p>
