GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Jens Gustedt
P99 - macros and functions for C99
054c8430
054c8430
Jens Gustedt
simplify P99_MACRO_PVAR and add some documentation for it
675d5e83
p99/p99_for.h
054c8430
@@ -1235,18 +1235,50 @@ __typeof__(EXP) __VA_ARGS__ P99_PASTE2(p00_macro_var_, NAME) = (EXP), \
NAME = P99_PASTE2(p00_macro_var_, NAME)
#define P00_MACRO_PVAR(NAME, EXP, ...) \
__typeof__(
__typeof__(*(EXP)) __VA_ARGS__*
__typeof__(*(EXP)) __VA_ARGS__* P99_PASTE2(p00_macro_var_, NAME) = (EXP), \
#ifdef DOXYGEN
#ifdef DOXYGEN
** @brief Define a variable with @a NAME that has the type and value of
** @a EXPR. If @a QUAL is given it must be a qualifier list that is
** @a EXPR.
** added to the resulting type.
** If @a QUAL is given it must be a qualifier list that is added to
** the resulting type.
** @remark Other than just redeclaring @a NAME this macro is safe
** even if @a EXPR contains the evaluation of a variable of the same
** name @a NAME.
** This is achieved by declaring two variables, one with a dummy name
** that receives @a EXPR as an initializer (so there can't be a name
** conflict), and then @a NAME that is initialized with the
** first. Any normal optimizer should optimize that auxiliary
** variable out.
P00_DOCUMENT_IDENTIFIER_ARGUMENT
P99_MACRO_VAR
P99_MACRO_VAR
P00_DOCUMENT_PERMITTED_ARGUMENT
P99_MACRO_VAR
P99_MACRO_VAR
#define P99_MACRO_VAR(NAME, EXPR, QUAL)
# define P99_MACRO_VAR(NAME, EXPR, QUAL)
** @a EXPR, where @a EXPR is of a pointer type.
** added to the type @a EXPR is pointing to.
** name @a NAME.
** variable out.
P99_MACRO_PVAR
P99_MACRO_PVAR
# define P99_MACRO_PVAR(NAME, EXPR, QUAL)
#else
#else
P99_MACRO_VAR
P99_MACRO_VAR
P99_MACRO_VAR
P99_MACRO_VAR
