Commit e3cd1cef authored by Ludovic Courtès's avatar Ludovic Courtès
getting-started: Add machine learning into the mix.
* getting-started.md: Add scikit-learn in the 'guix environment'
example.
parent 0d03cd3d
...@@ -100,10 +100,13 @@ Sometimes all you want is to try out a program without installing it in ...@@ -100,10 +100,13 @@ Sometimes all you want is to try out a program without installing it in
your profile. That’s your profile. That’s
where where
[`guix environment`](https://www.gnu.org/software/guix/manual/html_node/Invoking-guix-environment.html) comes [`guix environment`](https://www.gnu.org/software/guix/manual/html_node/Invoking-guix-environment.html) comes
in. To create an environment containing Python 3.x and NumPy, run: in. To create an environment containing Python 3.x, NumPy, and
scikit-learn, run:
$ guix environment --ad-hoc python@3 python-numpy $ python3
bash: python3: Command not found
$ guix environment --ad-hoc python@3 python-numpy python-scikit-learn
The following derivations will be built: The following derivations will be built:
/gnu/store/2g3mj1xdlq2rj8j0crl4sa68bqhmfsmd-profile.drv /gnu/store/2g3mj1xdlq2rj8j0crl4sa68bqhmfsmd-profile.drv
/gnu/store/wd0ma3xjq25w2qcnn3x0dgjyrck3dnk0-info-dir.drv /gnu/store/wd0ma3xjq25w2qcnn3x0dgjyrck3dnk0-info-dir.drv
...@@ -116,7 +119,8 @@ Python 3.5.3 (default, Jan 1 1970, 00:00:01) ...@@ -116,7 +119,8 @@ Python 3.5.3 (default, Jan 1 1970, 00:00:01)
[GCC 5.4.0] on linux [GCC 5.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information. Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy >>> import numpy
>>> >>> import sklearn
# Customizing Packages # Customizing Packages
