Commit 49a979b5 authored by Ludovic Courtès's avatar Ludovic Courtès
about: Add "Talks & Papers".
* about.md (Talks & Papers): New section.
parent e79c05b6
...@@ -14,6 +14,23 @@ the ...@@ -14,6 +14,23 @@ the
[Max Delbrück Center for Molecular Medicine (MDC)](https://www.mdc-berlin.de/), [Max Delbrück Center for Molecular Medicine (MDC)](https://www.mdc-berlin.de/),
and the [Utrecht Bioinformatics Center (UBC)](https://ubc.uu.nl/). and the [Utrecht Bioinformatics Center (UBC)](https://ubc.uu.nl/).
# Talks & Papers
The following talks and papers cover our motivation for Guix-HPC:
- [_Reproducible and user-controlled software management in HPC with GNU Guix_](https://www.youtube.com/watch?v=cH6wCL6GeOQ&list=PLir-OOQiOhXZX_2zmUJz0fx8RLALi3tkK&index=26) ([PDF](https://www.gnu.org/software/guix/guix-bosc-20170724.pdf)),
[BOSC](https://www.open-bio.org/wiki/BOSC_2017_Schedule), July 2017
- [_Optimized and Reproducible HPC Deployment_](https://archive.fosdem.org/2017/schedule/event/hpc_deployment_guix/),
[FOSDEM](https://fosdem.org/2017),
Feb. 2017
- [_Reproducible and User-Controlled Software Environments in HPC with Guix_](https://hal.inria.fr/hal-01161771/en)
([slides](https://www.gnu.org/software/guix/guix-reppar-20150825.pdf)),
paper presented at the 2nd International Workshop on Reproducibility
in Parallel Computing ([RepPar](http://www.reppar.org/2015/)),
Aug. 2015
# Join us!
If you are using Guix in an HPC context at your workplace, or if you If you are using Guix in an HPC context at your workplace, or if you
would like to find ways to address your own HPC use cases, or if you are would like to find ways to address your own HPC use cases, or if you are
an HPC vendor interested in improving the software deployment experience an HPC vendor interested in improving the software deployment experience
