Verified Commit 92bed98f authored by Konrad Hinsen's avatar Konrad Hinsen Committed by Efraim Flashner
Add python24-numarray 1.5.2
parent 45e749ac
;;; Guix Past --- Packages from the past for GNU Guix. ;;; Guix Past --- Packages from the past for GNU Guix.
;;; Copyright © 2020 Efraim Flashner <efraim@flashner.co.il> ;;; Copyright © 2019, 2020 Efraim Flashner <efraim@flashner.co.il>
;;; Copyright © 2020 Konrad Hinsen <konrad.hinsen@fastmail.net>
;;; This file is part of Guix Past. ;;; This file is part of Guix Past.
...@@ -18,6 +19,9 @@ ...@@ -18,6 +19,9 @@
(define-module (past packages python) (define-module (past packages python)
#:use-module (guix) #:use-module (guix)
#:use-module (guix build-system python)
#:use-module ((guix licenses) #:prefix license:)
#:use-module (gnu packages maths)
#:use-module (gnu packages onc-rpc) #:use-module (gnu packages onc-rpc)
#:use-module (gnu packages python) #:use-module (gnu packages python)
#:use-module (gnu packages tcl) #:use-module (gnu packages tcl)
...@@ -111,3 +115,61 @@ read read ssl ssl tcl tcl tk tk ,(version-major+minor (package-version tcl)) ,(v ...@@ -111,3 +115,61 @@ read read ssl ssl tcl tcl tk tk ,(version-major+minor (package-version tcl)) ,(v
started with 2.4.0, released on 2004-11-30. Python 2.5 was started with 2.4.0, released on 2004-11-30. Python 2.5 was
released on 2006-09-19."))) released on 2006-09-19.")))
(define-public python24-numarray
(package
(name "python24-numarray")
(version "1.5.2")
(source
(origin
(method url-fetch)
(uri (string-append
"mirror://sourceforge/numpy/Old Numarray/" version
"/numarray-" version ".tar.gz"))
(sha256
(base32
"0x1i4j7yni7k4p9kjxs1lgln1psdmyrz65wp2yr35yn292iw2vbg"))))
(build-system python-build-system)
(arguments
`(#:python ,python-2.4
#:use-setuptools? #f
#:phases
(modify-phases %standard-phases
(replace 'build
(lambda _
(invoke "python" "setup.py" "config" "build"
"--gencode" "--use_lapack")))
(add-after 'unpack 'find-lapack-and-openblas
(lambda* (#:key inputs #:allow-other-keys)
(let ((lapack (assoc-ref inputs "lapack"))
(blas (assoc-ref inputs "openblas")))
(substitute* "cfg_packages.py"
(("lapack_libs = .*'m']")
"lapack_libs = ['lapack', 'openblas', 'm']\n")
(("lapack_dirs = .*")
(string-append "lapack_dirs = ['"
lapack "/lib', '" blas "/lib']\n"))
(("lapack_include_dirs = .*")
(string-append "lapack_include_dirs = ['"
lapack "/include', '" blas "/include']\n")))
#t)))
(replace 'install
(lambda* (#:key outputs #:allow-other-keys)
(let ((out (assoc-ref outputs "out")))
"install" "--use_lapack"
(string-append "--prefix=" out))))))
#:tests? #f)) ; no test target
(inputs
`(("lapack" ,lapack)
("openblas" ,openblas)))
(properties '((release-date "2006-08-26")))
(home-page "https://sourceforge.net/projects/numpy/files/Old%20Numarray/1.5.2/")
(synopsis "Final numarray release from 2006-08-26")
(description "Numarray and Numeric were the predecessors of NumPy.
Numarray was created as an alternative to Numeric because the latter
was cumbersome to use when efficiency for large array operations was a
priority. Howver, numarray was less efficient for small arrays, and
thus could not replace Numeric. Many packages of the early SciPy
ecosystem supported both Numeric and numarray, with the choice made
at build time.")
(license license:bsd-3)))
Supports Markdown
