Verified Commit 6e56a6a8 authored by Efraim Flashner's avatar Efraim Flashner
Add python24-six 1.4.1
parent cc38fa02
...@@ -473,3 +473,39 @@ fixtures, and many external plugins.") ...@@ -473,3 +473,39 @@ fixtures, and many external plugins.")
`(#:python ,python-2.4)) `(#:python ,python-2.4))
(native-inputs (native-inputs
`(("setuptools" ,python24-setuptools))))) `(("setuptools" ,python24-setuptools)))))
(define-public python24-six
(package
(name "python24-six")
(version "1.4.1")
(source
(origin
(method url-fetch)
(uri (pypi-uri "six" version))
(sha256
(base32
"0rw3bymdjs1fvs8myjqx4rqhxpn4mklprjqs8705qxgvvzbayigh"))))
(build-system python-build-system)
(arguments
#:tests? #f
#:phases
(modify-phases %standard-phases
(replace 'check
(lambda* (#:key inputs outputs tests? #:allow-other-keys)
(add-installed-pythonpath inputs outputs)
(when tests?
;; Taken from tox.ini
(invoke "py.test" "-rfsxX")
#t))))))
(home-page "https://pypi.org/project/six/")
(native-inputs
`(("pytest" ,python24-pytest)
(properties '((release-date "2013-09-02")))
(synopsis "Six 1.4.1, released 2013-09-02")
(description
"Six is a Python 2 and 3 compatibility library. It provides utility
functions for smoothing over the differences between the Python versions with
the goal of writing Python code that is compatible on both Python versions.")
(license license:expat)))
Supports Markdown
