Commit e581457e authored by Ludovic Courtès's avatar Ludovic Courtès
Add (jupyter json).
Code taken from (guix swh) as of Guix commit
81c3dc32244a17241d74eea9fa265edfcb326f6d.
* jupyter/json.scm: New file.
* Makefile.am (SOURCES): Add it.
parent 0841118f
...@@ -21,6 +21,7 @@ moddir=@guilemoduledir@ ...@@ -21,6 +21,7 @@ moddir=@guilemoduledir@
godir=@guileobjectdir@ godir=@guileobjectdir@
SOURCES = \ SOURCES = \
jupyter/json.scm \
jupyter/messages.scm \ jupyter/messages.scm \
jupyter/kernels.scm \ jupyter/kernels.scm \
jupyter/servers.scm \ jupyter/servers.scm \
;;; Guix-kernel -- Guix kernel for Jupyter
;;; Copyright (C) 2018, 2019 Ludovic Courtès <ludo@gnu.org>
;;; This program is free software: you can redistribute it and/or modify
;;; it under the terms of the GNU General Public License as published by
;;; the Free Software Foundation, either version 3 of the License, or
;;; (at your option) any later version.
;;; This program is distributed in the hope that it will be useful,
;;; but WITHOUT ANY WARRANTY; without even the implied warranty of
;;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
;;; GNU General Public License for more details.
;;; You should have received a copy of the GNU General Public License
;;; along with this program. If not, see <https://www.gnu.org/licenses/>.
(define-module (jupyter json)
#:use-module (json)
#:use-module (srfi srfi-9)
#:export (define-json-mapping))
;;; Commentary:
;;; Helpers to map JSON objects to SRFI-9 records. Taken from (guix swh).
;;; Code:
(define-syntax-rule (define-json-reader json->record ctor spec ...)
"Define JSON->RECORD as a procedure that converts a JSON representation,
read from a port, string, or hash table, into a record created by CTOR and
following SPEC, a series of field specifications."
(define (json->record input)
(let ((table (cond ((port? input)
(json->scm input))
((string? input)
(json-string->scm input))
((or (null? input) (pair? input))
input))))
(let-syntax ((extract-field (syntax-rules ()
((_ table (field key json->value))
(json->value (assoc-ref table key)))
((_ table (field key))
((_ table (field))
(assoc-ref table
(symbol->string 'field))))))
(ctor (extract-field table spec) ...)))))
(define-syntax-rule (define-json-mapping rtd ctor pred json->record
(field getter spec ...) ...)
"Define RTD as a record type with the given FIELDs and GETTERs, à la SRFI-9,
and define JSON->RECORD as a conversion from JSON to a record of this type."
(begin
(define-record-type rtd
(ctor field ...)
pred
(field getter) ...)
(field spec ...) ...)))
Supports Markdown
