Commit 1ccc88b0 authored by Ludovic Courtès's avatar Ludovic Courtès
guile: Actually handle "shutdown_request".
* jupyter/guile.scm (dispatch-route): Change "shutdown" to
"shutdown_request".
* tests/guile.scm ("kernel_info_request")
("execute_request", "execute_request, exception"): Send
"shutdown_request", not "shutdown".
parent a8a4a4a2
...@@ -197,7 +197,7 @@ from the evaluation of CODE, a string." ...@@ -197,7 +197,7 @@ from the evaluation of CODE, a string."
(define dispatch-route (define dispatch-route
`(("kernel_info_request" . ,reply-kernel-info-request) `(("kernel_info_request" . ,reply-kernel-info-request)
("execute_request" . ,reply-execute-request) ("execute_request" . ,reply-execute-request)
("shutdown" . ,shutdown))) ("shutdown_request" . ,shutdown)))
(define (request-handler handlers) (define (request-handler handlers)
"Return a request handler that dispatches to HANDLERS, an alist." "Return a request handler that dispatches to HANDLERS, an alist."
...@@ -48,7 +48,7 @@ ...@@ -48,7 +48,7 @@
(send-message client request) (send-message client request)
(let ((reply (read-message client 10000))) (let ((reply (read-message client 10000)))
(send-message client (send-message client
(message (header "shutdown" "luser" "12345") (message (header "shutdown_request" "luser" "12345")
(close-kernel client) (close-kernel client)
(json->kernel-info-reply (message-content reply))))) (json->kernel-info-reply (message-content reply)))))
...@@ -82,7 +82,7 @@ ...@@ -82,7 +82,7 @@
(read-message client 10000)) (read-message client 10000))
1+ 0))) 1+ 0)))
(map (lambda (message) (map (lambda (message)
...@@ -122,7 +122,7 @@ ...@@ -122,7 +122,7 @@
1+ 0))) 1+ 0)))
(json->execute-reply (json->execute-reply
