Commit f8dfba7f authored by Jonathan Pastor's avatar Jonathan Pastor
[yaml_find_duplicates] the script can take sites and clusters as parameters
parent f9987521
...@@ -12,48 +12,107 @@ require '../lib/input_loader' ...@@ -12,48 +12,107 @@ require '../lib/input_loader'
class ::Hash class ::Hash
def deep_merge(other_hash) def deep_merge(other_hash)
# merger = proc { |key, v1, v2| Hash === v1 && Hash === v2 ? v1.merge(v2, &merger) : v2 } # merger = proc { |key, v1, v2| Hash === v1 && Hash === v2 ? v1.merge(v2, &merger) : v2 }
merger = proc { |key, v1, v2| merger = proc {|key, v1, v2|
if Hash === v1 && Hash === v2 if Hash === v1 && Hash === v2
v1.merge(v2, &merger) v1.merge(v2, &merger)
else else
v1.gsub!('!duplicated: ') if String === v1 v1.gsub!('!duplicated: ') if String === v1
v2.gsub!('!duplicated: ') if String === v2 v2.gsub!('!duplicated: ') if String === v2
if Hash === v1 || Hash === v2 if Hash === v1 || Hash === v2
# for example, this occurs if there are some empty entries on yaml files that need to be deleted (ex: parasilo-1 => {}) # for example, this occurs if there are some empty entries on yaml files that need to be deleted (ex: parasilo-1 => {})
# return a hash because it is needed by expand_square_brackets # return a hash because it is needed by expand_square_brackets
{ 'v1' => v1, 'v2' => v2, 'error' => "!duplicated: #{key}" } {'v1' => v1, 'v2' => v2, 'error' => "!duplicated: #{key}"}
else else
# remove the following 'if' if you want all the duplicated keys # remove the following 'if' if you want all the duplicated keys
#if v1 != v2 #if v1 != v2
"!duplicated: '#{v1}' '#{v2}'" "!duplicated: '#{v1}' '#{v2}'"
#else #else
# v2 # v2
#end #end
end end
end end
self.merge(other_hash, &merger) self.merge(other_hash, &merger)
end end
end end
global_hash = load_yaml_file_hierarchy("../../input/grid5000/") def yaml_input_find_duplicates(refapi_hash, options)
refapi_hash["sites"].sort.each do |site_uid, site|
if options.key?(:sites) && !options[:sites].include?(site_uid)
refapi_hash["sites"].delete(site_uid)
site["clusters"].sort.each do |cluster_uid, cluster|
if options.key?(:clusters) && !options[:clusters].include?(cluster_uid)
site["clusters"].delete(cluster_uid)
# remove entries that are not duplicate # remove entries that are not duplicate
global_hash.deep_reject! { |k, v| !( refapi_hash.deep_reject! {|k, v| !(
(v.is_a?(Hash) && !v.empty?) || (v.is_a?(Hash) && !v.empty?) ||
v.is_a?(String) && v.start_with?('!duplicated:') v.is_a?(String) && v.start_with?('!duplicated:')
# remove ip, mac and mounted properties (as it can be use to bootstrap the installation of a cluster) # remove ip, mac and mounted properties (as it can be use to bootstrap the installation of a cluster)
global_hash.deep_reject! { |k, v| k == 'ip' || k == 'mac' || k == 'mounted' } refapi_hash.deep_reject! {|k, v| k == 'ip' || k == 'mac' || k == 'mounted'}
global_hash.deep_reject! { |k, v| v == {} } refapi_hash.deep_reject! {|k, v| v == {}}
if refapi_hash.empty?
puts "OK: no duplicate entries."
else
puts refapi_hash.to_yaml
if global_hash.empty?
else
puts global_hash.to_yaml
end end
if __FILE__ == $0
require 'optparse'
options = {}
options[:sites] = %w{grenoble lille luxembourg lyon nancy nantes rennes sophia}
options[:api] = {}
OptionParser.new do |opts|
opts.banner = "Usage: yaml-input-find-duplicates.rb [options]"
opts.separator ""
opts.separator "Example: ruby yaml-input-find-duplicates.rb -v"
opts.separator ""
opts.separator "Filters:"
opts.on('-s', '--sites a,b,c', Array, 'Select site(s)',
"Default: "+options[:sites].join(", ")) do |s|
raise "Wrong argument for -s option." unless (s - options[:sites]).empty?
options[:sites] = s
opts.on('-c', '--clusters a,b,c', Array, 'Select clusters(s). Default: all') do |s|
options[:clusters] = s
opts.separator ""
opts.separator "Common options:"
opts.on("-v", "--[no-]verbose", "Run verbosely") do |v|
options[:verbose] ||= 0
options[:verbose] = options[:verbose] + 1
# Print an options summary.
opts.on_tail("-h", "--help", "Show this message") do
puts opts
exit
end.parse!
refapi_hash = load_yaml_file_hierarchy("../../input/grid5000/")
