Commit f3b00c2d authored by IMBERT Matthieu's avatar IMBERT Matthieu
[ipv6, dhcp] add generation of dhcpv6 records
parent f65b8615
# Get the mac and ip of a node. Throw exception if error.
# Get the mac, ipv4, ipv6 of a node. Throw exception if error.
def get_network_info(node_hash, network_interface)
# Get node_hash["network_adapters"][network_interface]["ip"] and node_hash["network_adapters"][network_interface]["mac"]
# Get node_hash["network_adapters"][network_interface]["ip"], node_hash["network_adapters"][network_interface]["ip6"] and node_hash["network_adapters"][network_interface]["mac"]
node_network_adapters = node_hash.fetch("network_adapters")
# For the production network, find the mounted interface (either eth0 or eth1)
......@@ -21,24 +21,28 @@ def get_network_info(node_hash, network_interface)
node_mac = node_network_interface.fetch('mac')
node_ip = node_network_interface.fetch('ip')
node_ipv4 = node_network_interface.fetch('ip')
node_ipv6 = node_network_interface.fetch('ip6', nil)
raise '"mac" is nil' unless node_mac
raise '"ip" is nil' unless node_ip
raise '"ip" is nil' unless node_ipv4
#raise '"ipv6" is nil' unless node_ipv6 # commented right now, we don't yet impose ipv6 for everything
return [node_ip, node_mac]
return [node_ipv4, node_ipv6, node_mac]
def write_dhcp_file(data, options)
def write_dhcp_files(data, options)
if data["nodes"].nil?
puts "Error in #{__method__}: no entry for \"#{data['filename']}\" at #{data['site_uid']} (#{data['network_adapters']})."
return ""
output = ERB.new(File.read(File.expand_path('templates/dhcp.erb', File.dirname(__FILE__)))).result(binding)
output_file = Pathname("#{options[:output_dir]}/platforms/production/modules/generated/files/grid5000/dhcp/#{data.fetch("site_uid")}/#{data.fetch('filename')}")
output_file.dirname.mkpath()
File.write(output_file, output)
["dhcp", "dhcpv6"].each { |dhcpkind|
output = ERB.new(File.read(File.expand_path("templates/dhcp.erb", File.dirname(__FILE__)))).result(binding)
output_file = Pathname("#{options[:output_dir]}/platforms/production/modules/generated/files/grid5000/#{dhcpkind}/#{data.fetch("site_uid")}/#{data.fetch('filename')}")
def generate_puppet_dhcpg5k(options)
......@@ -79,7 +83,7 @@ def generate_puppet_dhcpg5k(options)
site_hash.fetch("clusters").each { |cluster_uid, cluster_hash|
# networks = ["eth", "bmc"]
# networks << 'mic0' if cluster_hash['nodes'].values.any? {|x| x['network_adapters']['mic0'] }
write_dhcp_file({
write_dhcp_files({
"filename" => "cluster-" + cluster_uid + ".conf",
"site_uid" => site_uid,
"nodes" => cluster_hash.fetch('nodes'),
......@@ -91,7 +95,7 @@ def generate_puppet_dhcpg5k(options)
# Other dhcp files
["networks", "laptops", "servers"].each { |key|
write_dhcp_file({
write_dhcp_files({
"filename" => key + ".conf",
"nodes" => site_hash[key],
......@@ -116,7 +120,7 @@ def generate_puppet_dhcpg5k(options)
key = 'pdus'
write_dhcp_file({
write_dhcp_files({
"nodes" => site_hash['pdus'],
......@@ -18,10 +18,11 @@
uid_net = node_uid
# Get ip and mac addresses
# Get ipv4, ipv6 and mac addresses
begin
ip, mac = get_network_info(node, network_interface)
dhcp_entries.push({ 'uid_net' => uid_net, 'ip' => ip, 'mac' => mac })
ipv4, ipv6, mac = get_network_info(node, network_interface)
next if dhcpkind == 'dhcpv6' && ipv6 == nil
dhcp_entries.push({ 'uid_net' => uid_net, 'ipv4' => ipv4, 'ipv6' => ipv6, 'mac' => mac })
rescue => e
next if data.fetch('optional_network_adapters').include?(network_interface)
......@@ -36,7 +37,7 @@ group {
<% dhcp_entries.each {|node| %>
host <%= node['uid_net'] %> {
hardware ethernet <%= node['mac'].upcase %>;
fixed-address <%= node['ip'] %>;
fixed-address <%= dhcpkind == 'dhcpv6' ? node['ipv6'] : node['ipv4'] %>;
