Commit d2bece23 authored by Pascal Morillon's avatar Pascal Morillon
[admin] Update sensors
parent 8ee623f5
......@@ -132,11 +132,11 @@ site :nancy do |site_uid|
:switch => lookup('graphene', node_uid, 'network_interfaces', 'bmc', 'switch_name'),
:switch_port => lookup('graphene', node_uid, 'network_interfaces', 'bmc', 'switch_port')
pdu({
:vendor => "American Power Conversion",
:pdu => lookup('graphene', node_uid, 'pdu', 'pdu_name'),
:pdu_port => lookup('graphene', node_uid, 'pdu', 'pdu_position')
# pdu({
# :vendor => "American Power Conversion",
# :pdu => lookup('graphene', node_uid, 'pdu', 'pdu_name'),
# :pdu_port => lookup('graphene', node_uid, 'pdu', 'pdu_position')
bios({
:version => lookup('graphene', node_uid, 'bios', 'version'),
:vendor => "American Megatrends Inc.",
......@@ -147,29 +147,29 @@ site :nancy do |site_uid|
if (105<=i+1 and i+1<=144) then
monitoring({
:wattmeter => true
sensors({
:power => {
:available => true,
:via => {
:ganglia => { :metric => 'pdu' }
sensors({
:power => {
:available => true,
:via => {
:api => { :metric => 'pdu' },
:pdu => {
:uid => lookup('graphene', node_uid, 'pdu', 'pdu_name'),
:port => lookup('graphene', node_uid, 'pdu', 'pdu_position'),
else
monitoring({
:wattmeter => false
sensors({
:power => {
:available => false
sensors({
:power => {
:available => false, # Set to true when pdu resources will be declared
:via => {
:pdu => { :uid => lookup('graphene', node_uid, 'pdu', 'pdu_name') }
end # cluster graphene
......@@ -114,12 +114,13 @@ site :nancy do |site_uid|
:switch => lookup('griffon', node_uid, 'network_interfaces', 'bmc', 'switch_name'),
:switch_port => lookup('griffon', node_uid, 'network_interfaces', 'bmc', 'switch_port')
pdu({
:pdu => lookup('griffon', node_uid, 'pdu', 'pdu_name'),
:pdu_port => lookup('griffon', node_uid, 'pdu', 'pdu_position'),
bios({
# pdu({
# :pdu => lookup('griffon', node_uid, 'pdu', 'pdu_name'),
# :pdu_port => lookup('griffon', node_uid, 'pdu', 'pdu_position'),
bios({
:version => lookup('griffon', node_uid, 'bios', 'version'),
:vendor => lookup('griffon', node_uid, 'bios', 'vendor'),
:release_date => lookup('griffon', node_uid, 'bios', 'release_date'),
......@@ -128,15 +129,12 @@ site :nancy do |site_uid|
:gpu => false
monitoring({
:wattmeter => false
sensors({
:power => {
:available => false
:via => {
:pdu => { :uid => lookup('griffon', node_uid, 'pdu', 'pdu_name') }
