Commit d1431757 authored by Émile Morel's avatar Émile Morel
[All] seperate rb files en two files (one generated by g5k-checks, one set manualy)
parent 0fc33282
...@@ -16,121 +16,121 @@ site :bordeaux do |site_uid| ...@@ -16,121 +16,121 @@ site :bordeaux do |site_uid|
supported_job_types({ supported_job_types({
:deploy => true, :deploy => true,
:besteffort => true, :besteffort => true,
:virtual => lookup('bordeplage', node_uid, 'supported_job_types', 'virtual') :virtual => lookup('bordeplage_generated', node_uid, 'supported_job_types', 'virtual')
architecture({ architecture({
:smp_size => lookup('bordeplage', node_uid, 'architecture', 'smp_size'), :smp_size => lookup('bordeplage_generated', node_uid, 'architecture', 'smp_size'),
:smt_size => lookup('bordeplage', node_uid, 'architecture', 'smt_size'), :smt_size => lookup('bordeplage_generated', node_uid, 'architecture', 'smt_size'),
:platform_type => lookup('bordeplage', node_uid, 'architecture', 'platform_type') :platform_type => lookup('bordeplage_generated', node_uid, 'architecture', 'platform_type')
processor({ processor({
:vendor => lookup('bordeplage', node_uid, 'processor', 'vendor'), :vendor => lookup('bordeplage_generated', node_uid, 'processor', 'vendor'),
:model => lookup('bordeplage', node_uid, 'processor', 'model'), :model => lookup('bordeplage_generated', node_uid, 'processor', 'model'),
:version => lookup('bordeplage', node_uid, 'processor', 'version'), :version => lookup('bordeplage_generated', node_uid, 'processor', 'version'),
:clock_speed => lookup('bordeplage', node_uid, 'processor', 'clock_speed'), :clock_speed => lookup('bordeplage_generated', node_uid, 'processor', 'clock_speed'),
:instruction_set => lookup('bordeplage', node_uid, 'processor', 'instruction_set'), :instruction_set => lookup('bordeplage_generated', node_uid, 'processor', 'instruction_set'),
:other_description => lookup('bordeplage', node_uid, 'processor', 'other_description'), :other_description => lookup('bordeplage_generated', node_uid, 'processor', 'other_description'),
:cache_l1 => lookup('bordeplage', node_uid, 'processor', 'cache_l1'), :cache_l1 => lookup('bordeplage_generated', node_uid, 'processor', 'cache_l1'),
:cache_l1i => lookup('bordeplage', node_uid, 'processor', 'cache_l1i'), :cache_l1i => lookup('bordeplage_generated', node_uid, 'processor', 'cache_l1i'),
:cache_l1d => lookup('bordeplage', node_uid, 'processor', 'cache_l1d'), :cache_l1d => lookup('bordeplage_generated', node_uid, 'processor', 'cache_l1d'),
:cache_l2 => lookup('bordeplage', node_uid, 'processor', 'cache_l2'), :cache_l2 => lookup('bordeplage_generated', node_uid, 'processor', 'cache_l2'),
:cache_l3 => lookup('bordeplage', node_uid, 'processor', 'cache_l3') :cache_l3 => lookup('bordeplage_generated', node_uid, 'processor', 'cache_l3')
main_memory({ main_memory({
:ram_size => lookup('bordeplage', node_uid, 'main_memory', 'ram_size'), :ram_size => lookup('bordeplage_generated', node_uid, 'main_memory', 'ram_size'),
:virtual_size => nil :virtual_size => nil
operating_system({ operating_system({
:name => lookup('bordeplage', node_uid, 'operating_system', 'name'), :name => lookup('bordeplage_generated', node_uid, 'operating_system', 'name'),
:release => "Squeeze", :release => "Squeeze",
:version => lookup('bordeplage', node_uid, 'operating_system', 'version'), :version => lookup('bordeplage_generated', node_uid, 'operating_system', 'version'),
:kernel => lookup('bordeplage', node_uid, 'operating_system', 'kernel') :kernel => lookup('bordeplage_generated', node_uid, 'operating_system', 'kernel')
storage_devices [{ storage_devices [{
:interface => 'SCSI', :interface => 'SCSI',
:size => lookup('bordeplage', node_uid, 'block_devices', 'sda', 'size'), :size => lookup('bordeplage_generated', node_uid, 'block_devices', 'sda', 'size'),
:driver => "mptspi", :driver => "mptspi",
:device => lookup('bordeplage', node_uid, 'block_devices', 'sda', 'device'), :device => lookup('bordeplage_generated', node_uid, 'block_devices', 'sda', 'device'),
:model => lookup('bordeplage', node_uid, 'block_devices', 'sda', 'model'), :model => lookup('bordeplage_generated', node_uid, 'block_devices', 'sda', 'model'),
:vendor => lookup('bordeplage', node_uid, 'block_devices', 'sda', 'vendor'), :vendor => lookup('bordeplage_generated', node_uid, 'block_devices', 'sda', 'vendor'),
:rev => lookup('bordeplage', node_uid, 'block_devices', 'sda', 'rev') :rev => lookup('bordeplage_generated', node_uid, 'block_devices', 'sda', 'rev')
network_adapters [{ network_adapters [{
:interface => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'interface'), :interface => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'interface'),
:rate => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'rate'), :rate => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'rate'),
:enabled => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'enabled'), :enabled => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'enabled'),
:management => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'management'), :management => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'management'),
:mountable => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'mountable'), :mountable => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'mountable'),
:mounted => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'mounted'), :mounted => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'mounted'),
:bridged => true, :bridged => true,
:device => "eth0", :device => "eth0",
:vendor => "Intel", :vendor => "Intel",
:version => "82546GB Gigabit Ethernet Controller", :version => "82546GB Gigabit Ethernet Controller",
:driver => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'driver'), :driver => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'driver'),
:network_address => "#{node_uid}.#{site_uid}.grid5000.fr", :network_address => "#{node_uid}.#{site_uid}.grid5000.fr",
:ip => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'ip'), :ip => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'ip'),
:ip6 => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'ip6'), :ip6 => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'ip6'),
:switch => "sbordeplage", :switch => "sbordeplage",
:switch_port => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'switch_port'), :switch_port => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'switch_port'),
:mac => lookup('bordeplage', node_uid, 'network_interfaces', 'eth0', 'mac') :mac => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth0', 'mac')
:interface => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'interface'), :interface => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'interface'),
:rate => 1.G, :rate => 1.G,
:enabled => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'enabled'), :enabled => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'enabled'),
:management => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'management'), :management => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'management'),
:mountable => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'mountable'), :mountable => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'mountable'),
:mounted => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'mounted'), :mounted => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'mounted'),
:bridged => false, :bridged => false,
:device => "eth1", :device => "eth1",
:network_address => "#{node_uid}-eth1.#{site_uid}.grid5000.fr", :network_address => "#{node_uid}-eth1.#{site_uid}.grid5000.fr",
:ip => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'ip'), :ip => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'ip'),
:driver => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'driver'), :driver => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'driver'),
:mac => lookup('bordeplage', node_uid, 'network_interfaces', 'eth1', 'mac') :mac => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'eth1', 'mac')
:interface => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'interface'), :interface => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'interface'),
:rate => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'rate'), :rate => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'rate'),
:device => "ib0", :device => "ib0",
:enabled => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'enabled'), :enabled => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'enabled'),
:management => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'management'), :management => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'management'),
:mountable => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'mountable'), :mountable => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'mountable'),
:mounted => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'mounted'), :mounted => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'mounted'),
:vendor => 'Mellanox', :vendor => 'Mellanox',
:version => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'version'), :version => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'version'),
:driver => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'driver'), :driver => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'driver'),
:network_address => "#{node_uid}-ib0.#{site_uid}.grid5000.fr", :network_address => "#{node_uid}-ib0.#{site_uid}.grid5000.fr",
:ip => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'ip'), :ip => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'ip'),
:ip6 => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'ip6'), :ip6 => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'ip6'),
:guid => lookup('bordeplage', node_uid, 'network_interfaces', 'ib0', 'guid') :guid => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib0', 'guid')
:interface => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'interface'), :interface => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'interface'),
:rate => 10.G, :rate => 10.G,
:device => "ib1", :device => "ib1",
:enabled => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'enabled'), :enabled => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'enabled'),
:management => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'management'), :management => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'management'),
:mountable => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'mountable'), :mountable => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'mountable'),
:mounted => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'mounted'), :mounted => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'mounted'),
:version => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'version'), :version => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'version'),
:driver => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'driver'), :driver => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'driver'),
:guid => lookup('bordeplage', node_uid, 'network_interfaces', 'ib1', 'guid') :guid => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'ib1', 'guid')
:interface => 'Ethernet', :interface => 'Ethernet',
:rate => 100.M, :rate => 100.M,
:network_address => "#{node_uid}-bmc.#{site_uid}.grid5000.fr", :network_address => "#{node_uid}-bmc.#{site_uid}.grid5000.fr",
:ip => lookup('bordeplage', node_uid, 'network_interfaces', 'bmc', 'ip'), :ip => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'bmc', 'ip'),
:mac => lookup('bordeplage', node_uid, 'network_interfaces', 'bmc', 'mac'), :mac => lookup('bordeplage_generated', node_uid, 'network_interfaces', 'bmc', 'mac'),
:enabled => true, :enabled => true,
:mounted => false, :mounted => false,
:mountable => false, :mountable => false,
...@@ -139,15 +139,15 @@ site :bordeaux do |site_uid| ...@@ -139,15 +139,15 @@ site :bordeaux do |site_uid|
chassis({ chassis({
:serial => lookup('bordeplage', node_uid, 'chassis', 'serial_number'), :serial => lookup('bordeplage_generated', node_uid, 'chassis', 'serial_number'),
:name => lookup('bordeplage', node_uid, 'chassis', 'product_name'), :name => lookup('bordeplage_generated', node_uid, 'chassis', 'product_name'),
:manufacturer => lookup('bordeplage', node_uid, 'chassis', 'manufacturer') :manufacturer => lookup('bordeplage_generated', node_uid, 'chassis', 'manufacturer')
bios({ bios({
:version => lookup('bordeplage', node_uid, 'bios', 'version'), :version => lookup('bordeplage_generated', node_uid, 'bios', 'version'),
:vendor => lookup('bordeplage', node_uid, 'bios', 'vendor'), :vendor => lookup('bordeplage_generated', node_uid, 'bios', 'vendor'),
:release_date => lookup('bordeplage', node_uid, 'bios', 'release_date') :release_date => lookup('bordeplage_generated', node_uid, 'bios', 'release_date')
gpu({ gpu({
...@@ -49,7 +49,6 @@ bordeplage-1: ...@@ -49,7 +49,6 @@ bordeplage-1:
driver: e1000 driver: e1000
mountable: true mountable: true
ip: 172.16.0.1 ip: 172.16.0.1
switch: sbordeplage-1
eth1: eth1:
mounted: false mounted: false
rate: 1000000000 rate: 1000000000
...@@ -125,7 +124,6 @@ bordeplage-2: ...@@ -125,7 +124,6 @@ bordeplage-2:
ip: 172.16.0.2 ip: 172.16.0.2
eth1: eth1:
...@@ -212,7 +210,6 @@ bordeplage-3: ...@@ -212,7 +210,6 @@ bordeplage-3:
ip: 172.16.0.3 ip: 172.16.0.3
eth1: eth1:
...@@ -306,7 +303,6 @@ bordeplage-4: ...@@ -306,7 +303,6 @@ bordeplage-4:
ip: 172.16.0.4 ip: 172.16.0.4
eth1: eth1:
...@@ -386,7 +382,6 @@ bordeplage-5: ...@@ -386,7 +382,6 @@ bordeplage-5:
ip: 172.16.0.5 ip: 172.16.0.5
eth1: eth1:
...@@ -473,7 +468,6 @@ bordeplage-6: ...@@ -473,7 +468,6 @@ bordeplage-6:
ip: 172.16.0.6 ip: 172.16.0.6
eth1: eth1:
...@@ -560,7 +554,6 @@ bordeplage-7: ...@@ -560,7 +554,6 @@ bordeplage-7:
ip: 172.16.0.7 ip: 172.16.0.7
eth1: eth1:
...@@ -647,7 +640,6 @@ bordeplage-8: ...@@ -647,7 +640,6 @@ bordeplage-8:
ip: 172.16.0.8 ip: 172.16.0.8
eth1: eth1:
...@@ -734,7 +726,6 @@ bordeplage-9: ...@@ -734,7 +726,6 @@ bordeplage-9:
ip: 172.16.0.9 ip: 172.16.0.9
eth1: eth1:
...@@ -813,7 +804,7 @@ bordeplage-10: ...@@ -813,7 +804,7 @@ bordeplage-10:
eth0: eth0:
mounted: true mounted: true
mac: mac:
ip6: fe80::214:22ff:fe0c:da94 ip6: fe80::214:22ff:fe0c:da94
management: false management: false
enabled: true enabled: true
...@@ -821,11 +812,10 @@ bordeplage-10: ...@@ -821,11 +812,10 @@ bordeplage-10:
ip: 172.16.0.10 ip: 172.16.0.10
eth1: eth1:
mac: mac:
enabled: false enabled: false
interface: Ethernet interface: Ethernet
...@@ -915,7 +905,6 @@ bordeplage-11: ...@@ -915,7 +905,6 @@ bordeplage-11:
ip: 172.16.0.11 ip: 172.16.0.11
switch: sbordeplage-2
eth1: eth1:
...@@ -1006,7 +995,6 @@ bordeplage-12: ...@@ -1006,7 +995,6 @@ bordeplage-12:
ip: 172.16.0.12 ip: 172.16.0.12
eth1: eth1:
...@@ -1082,7 +1070,6 @@ bordeplage-13: ...@@ -1082,7 +1070,6 @@ bordeplage-13:
ip: 172.16.0.13 ip: 172.16.0.13
eth1: eth1:
...@@ -1176,7 +1163,6 @@ bordeplage-14: ...@@ -1176,7 +1163,6 @@ bordeplage-14:
ip: 172.16.0.14 ip: 172.16.0.14
eth1: eth1:
...@@ -1267,7 +1253,6 @@ bordeplage-15: ...@@ -1267,7 +1253,6 @@ bordeplage-15:
ip: 172.16.0.15 ip: 172.16.0.15
eth1: eth1:
...@@ -1343,7 +1328,6 @@ bordeplage-16: ...@@ -1343,7 +1328,6 @@ bordeplage-16:
ip: 172.16.0.16 ip: 172.16.0.16
eth1: eth1:
...@@ -1430,7 +1414,6 @@ bordeplage-17: ...@@ -1430,7 +1414,6 @@ bordeplage-17:
ip: 172.16.0.17 ip: 172.16.0.17
eth1: eth1:
...@@ -1524,7 +1507,6 @@ bordeplage-18: ...@@ -1524,7 +1507,6 @@ bordeplage-18:
ip: 172.16.0.18 ip: 172.16.0.18
eth1: eth1:
...@@ -1615,7 +1597,6 @@ bordeplage-19: ...@@ -1615,7 +1597,6 @@ bordeplage-19:
ip: 172.16.0.19 ip: 172.16.0.19
eth1: eth1:
...@@ -1691,7 +1672,6 @@ bordeplage-20: ...@@ -1691,7 +1672,6 @@ bordeplage-20:
ip: 172.16.0.20 ip: 172.16.0.20
eth1: eth1:
...@@ -1778,7 +1758,6 @@ bordeplage-21: ...@@ -1778,7 +1758,6 @@ bordeplage-21:
ip: 172.16.0.21 ip: 172.16.0.21
eth1: eth1:
...@@ -1865,7 +1844,6 @@ bordeplage-22: ...@@ -1865,7 +1844,6 @@ bordeplage-22:
ip: 172.16.0.22 ip: 172.16.0.22
eth1: eth1:
...@@ -1952,7 +1930,6 @@ bordeplage-23: ...@@ -1952,7 +1930,6 @@ bordeplage-23:
ip: 172.16.0.23 ip: 172.16.0.23
eth1:
