GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
c84f4738
"runtime/starpu/git@gitlab.inria.fr:solverstack/chameleon.git" did not exist on "b4d811dda90f20f8f06390e0ae2cab3eaf2fe38d"
c84f4738
3 years ago
Simon Delamare
Downloads
Patches
[lib] wiki gen : use nvme0n1 as primary disk if sda not found
17cdac7f
Pipeline
#254578
passed
3 years ago
Stage: validate
Stage: generate
Stage: deploy
Stage: .post
lib/refrepo/gen/wiki/generators/hardware.rb
+1
-1
1 addition, 1 deletion
1 addition
1 deletion
c84f4738
@@ -386,7 +386,7 @@ class G5KHardwareGenerator < WikiGenerator
next
if
node_hash
'status'
'retired'
next
if
node_hash
'status'
'retired'
sd
node_hash
'storage_devices'
sd
node_hash
'storage_devices'
reservable_disks
sd
select
v
v
'reservation'
true
count
reservable_disks
sd
select
v
v
'reservation'
true
count
maindisk
sd
select
v
v
'device'
'sda'
maindisk
sd
select
v
v
'device'
'sda'
sd
select
v
v
'device'
'nvme0n1'
maindisk_t
maindisk
'storage'
G5K
get_size
maindisk
'size'
'metric'
maindisk_t
maindisk
'storage'
G5K
get_size
maindisk
'size'
'metric'
other
sd
select
d
d
'device'
'sda'
other
sd
select
d
d
'device'
'sda'
hdds
other
select
d
d
'storage'
'HDD'
hdds
other
select
d
d
'storage'
'HDD'
This diff is collapsed.
Loading
Save comment
