Commit c785dd61 authored by Lucas Nussbaum's avatar Lucas Nussbaum
Adaptation du script de génération pour le nouveau schéma
parent 1d86b1f9
...@@ -66,26 +66,28 @@ d['sites'].each_pair do |site, ds| ...@@ -66,26 +66,28 @@ d['sites'].each_pair do |site, ds|
o['clusterList'] = [] o['clusterList'] = []
ds['clusters'].each_pair do |cluster, dc| ds['clusters'].each_pair do |cluster, dc|
oc = {} oc = {}
oc['clusterName'] = cluster oc['name'] = cluster
nodes = dc['nodes'].values.select { |n| not n['status'] == 'retired' } nodes = dc['nodes'].values.select { |n| not n['status'] == 'retired' }
next if nodes.empty? next if nodes.empty?
fn = nodes.first fn = nodes.first
oc['vendorName'] = case fn['chassis']['manufacturer'] oc['vendorName'] = [
when 'Dell Inc.' then 'Dell' # normalize according to schema when 'Dell Inc.' then 'Dell' # normalize according to schema
when 'HP' then 'HPE' when 'HP' then 'HPE'
else fn['chassis']['manufacturer'] else fn['chassis']['manufacturer']
end end
oc['jobschedulerName'] = 'oar' oc['jobschedulerName'] = 'oar'
oc['clusterCoreNumber'] = nodes.length * fn['architecture']['nb_cores'] oc['clusterCoreNumber'] = nodes.length * fn['architecture']['nb_cores']
oc['nodeType'] = [ oc['nodeType'] = [
"CPUType" => "#{fn['processor']['model']} #{fn['processor']['version']}", "CPUType" => "#{fn['processor']['model']} #{fn['processor']['version']}",
"coreNumber" => fn['architecture']['nb_cores'], "CPUCoreNumber" => fn['architecture']['nb_cores'] / fn['architecture']['nb_procs'],
"cpuNumber" => fn['architecture']['nb_procs'], # FIXME check name of property "nodeCPUNumber" => fn['architecture']['nb_procs'],
"memory" => (fn['main_memory']['ram_size'].to_f / 1024**3).to_i, "nodeRAMSize" => (fn['main_memory']['ram_size'].to_f / 1024**3).to_i,
"nodeNumber" => nodes.length, "nodeNumber" => nodes.length,
"localDisk" => (fn['storage_devices'].map { |sd| sd['size'] }.sum.to_f / 1024**4).round(2) "nodeStorageSize" => (fn['storage_devices'].map { |sd| sd['size'] }.sum.to_f / 1024**4).round(2)
if not fn['network_adapters'].select { |na| na['interface'] == 'InfiniBand' }.empty? if not fn['network_adapters'].select { |na| na['interface'] == 'InfiniBand' }.empty?
...@@ -99,7 +101,7 @@ d['sites'].each_pair do |site, ds| ...@@ -99,7 +101,7 @@ d['sites'].each_pair do |site, ds|
if (fn['gpu_devices'] || {}).values.length > 0 if (fn['gpu_devices'] || {}).values.length > 0
gpus = fn['gpu_devices'].values gpus = fn['gpu_devices'].values
oc['nodeType'].first['GPUType'] = "#{gpus.first['vendor']} #{gpus.first['model']}" oc['nodeType'].first['GPUType'] = "#{gpus.first['vendor']} #{gpus.first['model']}"
oc['nodeType'].first['GPUNumber'] = gpus.length oc['nodeType'].first['nodeGPUNumber'] = gpus.length
end end
o['clusterList'] << oc o['clusterList'] << oc
end end
...@@ -176,8 +178,8 @@ d['sites'].each_pair do |site, ds| ...@@ -176,8 +178,8 @@ d['sites'].each_pair do |site, ds|
'size' => 40 'size' => 40
end end
o['totalCoreNumber'] = o['clusterList'].map { |c| c['clusterCoreNumber'] }.sum o['mesoCoreNumber'] = o['clusterList'].map { |c| c['clusterCoreNumber'] }.sum
o['totalStorage'] = (o['clusterList'].map { |c| c['nodeType'].map { |n| n['localDisk'] * n['nodeNumber'] }.sum }.sum + o['mesoStorageSize'] = (o['clusterList'].map { |c| c['nodeType'].map { |n| n['nodeStorageSize'] * n['nodeNumber'] }.sum }.sum +
o['storageList'].map { |s| s['size'] }.sum).round(2) o['storageList'].map { |s| s['size'] }.sum).round(2)
JSON::Validator.validate!(mesos_schema, o) JSON::Validator.validate!(mesos_schema, o)
File::open("grid5000-#{site}.json", "w") { |fd| fd.puts JSON::pretty_generate(o) } File::open("grid5000-#{site}.json", "w") { |fd| fd.puts JSON::pretty_generate(o) }
