Commit c240961c authored by DELABROYE Dimitri's avatar DELABROYE Dimitri
[lib/refrepo/gen/puppet/lanpower] make lanpower use data instead if input
parent ca5177ce
1 merge request!11Bug 9861 changement des donnees d'entrees des generateurs
...@@ -16,7 +16,7 @@ def generate_puppet_lanpowerg5k(options) ...@@ -16,7 +16,7 @@ def generate_puppet_lanpowerg5k(options)
config = YAML::load_file("#{options[:conf_dir]}/console.yaml") config = YAML::load_file("#{options[:conf_dir]}/console.yaml")
credentials = YAML::load_file("#{options[:conf_dir]}/console-password.yaml") credentials = YAML::load_file("#{options[:conf_dir]}/console-password.yaml")
refapi = load_yaml_file_hierarchy refapi = load_data_hierarchy
refapi['sites'].each { |site_uid, site_refapi| refapi['sites'].each { |site_uid, site_refapi|
