Commit b4edd5b5 authored by Jérémie Gaidamour's avatar Jérémie Gaidamour
[dev] Simplification of reference-api.rb. It generates the same output as...
[dev] Simplification of reference-api.rb. It generates the same output as before on the updated input example (pomme cluster).
parent bdcecb9f
#!/usr/bin/ruby #!/usr/bin/ruby
require 'pp'
require 'erb'
require 'fileutils'
require 'pathname' require 'pathname'
require 'json' require 'json'
require '../lib/input_loader'
# Output directory
refapi_path = "/tmp/data" refapi_path = "/tmp/data"
data = JSON.parse(STDIN.read)
#global_hash = JSON.parse(STDIN.read)
global_hash = load_yaml_file_hierarchy("../../input/example/")
# Write pretty and sorted JSON files # Write pretty and sorted JSON files
def write_json(filepath, data) def write_json(filepath, data)
...@@ -49,7 +57,7 @@ def net_switch_port_lookup(site, node_uid, interface='') ...@@ -49,7 +57,7 @@ def net_switch_port_lookup(site, node_uid, interface='')
return nil return nil
end end
data["sites"].each do |site_uid, site| global_hash["sites"].each do |site_uid, site|
site["clusters"].each do |cluster_uid, cluster| site["clusters"].each do |cluster_uid, cluster|
...@@ -60,49 +68,45 @@ data["sites"].each do |site_uid, site| ...@@ -60,49 +68,45 @@ data["sites"].each do |site_uid, site|
write_json(cluster_path.join("#{cluster_uid}.json"), write_json(cluster_path.join("#{cluster_uid}.json"),
cluster.reject {|k, v| k == "nodes"}) cluster.reject {|k, v| k == "nodes"})
# Write node info
cluster["nodes"].each do |node_uid, node| cluster["nodes"].each do |node_uid, node|
node["uid"] = node_uid node["uid"] = node_uid
# TODO: fix inconsistency? # Rename keys
node["storage_devices"].each {|s| s.update(node["block_devices"].values.at(node["storage_devices"].index(s)))} node["storage_devices"] = node.delete("block_devices")
node.delete("block_devices") node["network_adapters"] = node.delete("network_interfaces")
if node.key?("chassis")
# TODO: fix inconsistency? node["chassis"]["name"] = node["chassis"].delete("product_name")
node["chassis"]["name"] = node["chassis"]["product_name"] node["chassis"]["serial"] = node["chassis"].delete("serial_number")
node["chassis"]["serial"] = node["chassis"]["serial_number"]
node["network_adapters"].each do |iface|
node["network_interfaces"].select {|k| k.to_s == iface["device"]}.each do |k, v|
iface.update(v)
end end
# Convert hashes to arrays
node["storage_devices"] = node["storage_devices"].values
node["network_adapters"] = node["network_adapters"].values
# Network Reference # Populate "network_address", "switch" and "port" from the network equipment description for each network adapters
node["network_adapters"].each do |iface| node["network_adapters"].each { |network_adapter|
if iface["enabled"] if network_adapter["enabled"]
if iface["management"] if network_adapter["management"]
# Managment iface # Management network_adapter
iface["network_address"] = "#{node_uid}-bmc.#{site_uid}.grid5000.fr" network_adapter["network_address"] = "#{node_uid}-bmc.#{site_uid}.grid5000.fr"
elsif iface["mounted"] elsif network_adapter["mounted"]
# Primary iface # Primary network_adapter
iface["bridged"] = true network_adapter["bridged"] = true
iface["network_address"] = "#{node_uid}.#{site_uid}.grid5000.fr" network_adapter["network_address"] = "#{node_uid}.#{site_uid}.grid5000.fr"
# Interface may not be specified in Network Reference for primary iface # Interface may not be specified in Network Reference for primary network_adapter
iface["switch"], iface["port"] = \ network_adapter["switch"], network_adapter["port"] = \
net_switch_port_lookup(site, node_uid) || net_switch_port_lookup(site, node_uid, iface["device"]) net_switch_port_lookup(site, node_uid) || net_switch_port_lookup(site, node_uid, network_adapter["device"])
else else
# Secondary iface(s) # Secondary network_adapter(s)
iface["network_address"] = "#{node_uid}-#{iface["device"]}.#{site}.grid5000.fr" network_adapter["network_address"] = "#{node_uid}-#{network_adapter["device"]}.#{site}.grid5000.fr"
iface["switch"], iface["port"] = net_switch_port_lookup(site, node_uid, iface["device"]) network_adapter["switch"], network_adapter["port"] = net_switch_port_lookup(site, node_uid, network_adapter["device"])
end end
end end
end }
#pp cluster_path.join("nodes","#{node_uid}.json")
write_json(cluster_path.join("nodes","#{node_uid}.json"), node) write_json(cluster_path.join("nodes","#{node_uid}.json"), node)
end end
end end
