Commit b04e7baf authored by PARISOT Clement's avatar PARISOT Clement
Merge branch 'nessie-more-ram' into 'master'
[grenoble] nessie - Add more RAM
See merge request !1101
parents 439bcfaa 95df2a87
1 merge request!1101[grenoble] nessie - Add more RAM
Pipeline #1135362 passed with warnings
Pipeline: Resources Explorer
#1135367
    ...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
    "model": "HPE ProLiant DL385 Gen10+ v2", "model": "HPE ProLiant DL385 Gen10+ v2",
    "nodes_count": 1, "nodes_count": 1,
    "nodes_description": "2 CPUs Intel Xeon Gold 6430, 32 cores/CPU, 64GB RAM, 1788GB SSD, 447GB SSD, 1 x 25Gb Ethernet", "nodes_description": "2 CPUs Intel Xeon Gold 6430, 32 cores/CPU, 128GB RAM, 1788GB SSD, 447GB SSD, 1 x 25Gb Ethernet",
    "priority": 202408, "priority": 202408,
    "queues": [ "queues": [
    "admin", "admin",
    ...@@ -21,7 +21,7 @@ ...@@ -21,7 +21,7 @@
    "exotic": false, "exotic": false,
    "main_memory": { "main_memory": {
    "ram_size": 68719476736 "ram_size": 137438953472
    "management_tools": { "management_tools": {
    "bmc_vendor_tool": "ipmitool", "bmc_vendor_tool": "ipmitool",
    ...@@ -35,10 +35,20 @@ ...@@ -35,10 +35,20 @@
    "size": 34359738368, "size": 34359738368,
    "technology": "dram" "technology": "dram"
    "device": "dimm_proc 1 dimm 3",
    "device": "dimm_proc 2 dimm 10", "device": "dimm_proc 2 dimm 10",
    "device": "dimm_proc 2 dimm 3",
    "network_adapters": [ "network_adapters": [
    ...@@ -19,7 +19,6 @@ nodes: ...@@ -19,7 +19,6 @@ nodes:
    processor: processor:
    microarchitecture: Sapphire Rapids microarchitecture: Sapphire Rapids
    clock_speed: 3_400_000_000 clock_speed: 3_400_000_000
    version: Gold 6430
    network_adapters: network_adapters:
    bmc: bmc:
    enabled: true enabled: true
    ...@@ -17,14 +17,20 @@ nessie-1: ...@@ -17,14 +17,20 @@ nessie-1:
    name: ProLiant DL380 Gen11 name: ProLiant DL380 Gen11
    serial: CZ243200MS serial: CZ243200MS
    main_memory: main_memory:
    ram_size: 68719476736 ram_size: 137438953472
    memory_devices: memory_devices:
    dimm_proc 1 dimm 10: dimm_proc 1 dimm 10:
    size: 34359738368 size: 34359738368
    technology: dram technology: dram
    dimm_proc 1 dimm 3:
    technology: dram
    dimm_proc 2 dimm 10: dimm_proc 2 dimm 10:
    dimm_proc 2 dimm 3:
    technology: dram
    bmc: bmc:
    ip: 172.17.25.1 ip: 172.17.25.1
    ...@@ -72,6 +78,7 @@ nessie-1: ...@@ -72,6 +78,7 @@ nessie-1:
    model: Intel Xeon model: Intel Xeon
    other_description: Intel(R) Xeon(R) Gold 6430 other_description: Intel(R) Xeon(R) Gold 6430
    vendor: Intel vendor: Intel
    version: Gold 6430
    storage_devices: storage_devices:
    pci-0000:36:00.0-scsi-0:2:1:0: pci-0000:36:00.0-scsi-0:2:1:0:
    by_path: "/dev/disk/by-path/pci-0000:36:00.0-scsi-0:2:1:0" by_path: "/dev/disk/by-path/pci-0000:36:00.0-scsi-0:2:1:0"
