GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
grid5000
reference-repository
ab3e7be2
ab3e7be2
IMBERT Matthieu
[gen] ipv6: fix network_adapter select + add code to fail on unhandled cases
96d0404b
Pipeline
#133186
passed with stages
in 4 minutes and 43 seconds
lib/refrepo/input_loader.rb
ab3e7be2
@@ -114,8 +114,10 @@ def add_ipv6(h)
hc
'nodes'
each_pair
do
node_uid
hn
hc
'nodes'
each_pair
do
node_uid
hn
# get IPv4
# get IPv4
ip4
nil
ip4
nil
num_main_interfaces
hn
'network_adapters'
each_pair
do
iface
nh
hn
'network_adapters'
each_pair
do
iface
nh
if
nh
'mountable'
true
nh
'interface'
'Ethernet'
if
nh
'mounted'
true
nh
'interface'
'Ethernet'
nh
'management'
false
num_main_interfaces
# for mounted && ethernet interfaces only
ip4
nh
'ip'
ip4
nh
'ip'
if
not
ip4
nil?
if
not
ip4
nil?
@@ -132,6 +134,9 @@ def add_ipv6(h)
# for all other cases, force no IPv6
nh
delete
'ip6'
nh
delete
'ip6'
if
num_main_interfaces
raise
node_uid
site_uid
: more than one interface with mounted == true && interface == 'Ethernet' && management == false"
