Commit a2737770 authored by Pierre Neyron's avatar Pierre Neyron 🚴
[grenoble] update data for yeti after the raid controller change
parent 3c925932
Pipeline #52812 passed with stages
in 1 minute and 39 seconds
...@@ -175,55 +175,55 @@ ...@@ -175,55 +175,55 @@
"storage_devices": [ "storage_devices": [
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a09c00223ab220cfc3b8e0", "by_id": "/dev/disk/by-id/wwn-0x55cd2e414de1d705",
"by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:2:0:0", "by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:0:0:0",
"device": "sda", "device": "sda",
"driver": "megaraid_sas", "driver": "megaraid_sas",
"firmware_version": 5.03, "firmware_version": "SCV1DL53",
"interface": "SAS", "interface": "SAS",
"model": "PERC H740P Adp", "model": "SSDSC2KG480G7R",
"size": 479559942144, "size": 480103981056,
"storage": "SSD", "storage": "SSD",
"vendor": "DELL" "vendor": "ATA"
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a09c0021fcc937c12e0d1b", "by_id": "/dev/disk/by-id/wwn-0x5000c500a08870d7",
"by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:2:1:0", "by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:0:1:0",
"device": "sdb", "device": "sdb",
"firmware_version": 5.03, "firmware_version": "NT31",
"model": "PERC H740P Adp", "model": "ST2000NX0463",
"reservation": true, "reservation": true,
"size": 1999844147200, "size": 2000398934016,
"storage": "HDD", "storage": "HDD",
"vendor": "DELL" "vendor": "SEAGATE"
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a09c0021fcc93ac4f0fd93", "by_id": "/dev/disk/by-id/wwn-0x5000c500a0897757",
"by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:2:2:0", "by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:0:2:0",
"device": "sdc", "device": "sdc",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a09c0021fcc93dc8e0d879", "by_id": "/dev/disk/by-id/wwn-0x5000c500a0ae94bf",
"by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:2:3:0", "by_path": "/dev/disk/by-path/pci-0000:18:00.0-scsi-0:0:3:0",
"device": "sdd", "device": "sdd",
"by_id": "/dev/disk/by-id/nvme-eui.0025389671000bb3", "by_id": "/dev/disk/by-id/nvme-eui.0025389671000bb3",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbc60023762be4210faa5e", "by_id": "/dev/disk/by-id/wwn-0x55cd2e414de16d7a",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbc60023762be421275098", "by_id": "/dev/disk/by-id/wwn-0x5000c500a08aab8f",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbc60023762be4213e8b27", "by_id": "/dev/disk/by-id/wwn-0x5000c500a088ce2f",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbc60023762be42155c247", "by_id": "/dev/disk/by-id/wwn-0x5000c500a0ae06af",
"by_id": "/dev/disk/by-id/nvme-eui.0025389571001020", "by_id": "/dev/disk/by-id/nvme-eui.0025389571001020",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a3cb00223b92d7caa2ee25", "by_id": "/dev/disk/by-id/wwn-0x55cd2e414de1d730",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a3cb00223b92d9ccfeedee", "by_id": "/dev/disk/by-id/wwn-0x5000c500a08a4beb",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a3cb00223b92dbd095b1ac", "by_id": "/dev/disk/by-id/wwn-0x5000c500a089563f",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030a3cb00223b92ded465c604", "by_id": "/dev/disk/by-id/wwn-0x5000c500a0adf81f",
"by_id": "/dev/disk/by-id/nvme-eui.002538957100101f", "by_id": "/dev/disk/by-id/nvme-eui.002538957100101f",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbb700223ab55ccfde5c8a", "by_id": "/dev/disk/by-id/wwn-0x55cd2e414de0fa6e",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbb70021fcbaecc8ec4a10", "by_id": "/dev/disk/by-id/wwn-0x5000c500a08a9c6b",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbb70021fcbaf0ce536e29", "by_id": "/dev/disk/by-id/wwn-0x5000c500a08a7bb3",
"by_id": "/dev/disk/by-id/wwn-0x6d09466030bbb70021fcbaf2d230b931", "by_id": "/dev/disk/by-id/wwn-0x5000c500a0ae58b3",
"by_id": "/dev/disk/by-id/nvme-eui.0025389671000bb5", "by_id": "/dev/disk/by-id/nvme-eui.0025389671000bb5",
