Commit a160e367 authored by REGAL-MEZIN Colin's avatar REGAL-MEZIN Colin
Merge branch 'testing-engelbourg-merge' into 'master'
Merge engelbourg into master
See merge request !1227
parents 2a48d15b 499f297e
1 merge request!1227Merge engelbourg into master
Pipeline #1159748 passed
Pipeline: Resources Explorer
#1159751
    with 1161 additions and 142 deletions
    "boot_type": "uefi",
    "created_at": "Thu, 01 Jan 1970 00:00:00 GMT",
    "exotic": true,
    "kavlan": false,
    "manufactured_at": "1970-01-01",
    "metrics": [
    "model": "Switch P4",
    "nodes_count": 8,
    "nodes_description": "1 CPU Intel(R) Pentium(R) D1517, 4 cores/CPU, 8GB RAM, 119GB SSD, 1 x 1Gb Ethernet",
    "priority": 197001,
    "queues": [
    "admin",
    "testing"
    "redfish": true,
    "type": "cluster",
    "uid": "engelbourg",
    "warranty_end": "1970-01-01"
    \ No newline at end of file
    "architecture": {
    "cpu_core_numbering": "contiguous",
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "platform_type": "x86_64"
    "bios": {
    "release_date": "02/08/2021",
    "vendor": "American Megatrends Inc.",
    "version": "R1.00.E4"
    "bmc_version": "unknown",
    "chassis": {
    "manufacturer": "Default string",
    "name": "Default string",
    "serial": "Default string",
    "exotic": true,
    "main_memory": {
    "ram_size": 8589934592
    "management_tools": {
    "bmc_vendor_tool": "wedge",
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "device": "sodimm_a1",
    "size": 8589934592,
    "technology": "dram"
    "network_adapters": [
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "firmware_version": "3.16.0",
    "interface": "Ethernet",
    "ip": "172.16.161.1",
    "ip6": "2001:660:4406:a00:2::1",
    "kavlan": false,
    "mac": "00:90:fb:78:0f:7a",
    "management": false,
    "model": "I210 Gigabit Network Connection",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-1.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "sriov_totalvfs": 0,
    "switch": "sw-admin",
    "switch_port": "Ethernet31",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.1",
    "kavlan": false,
    "mac": "01:01:01:01:01:01",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-1-bmc.strasbourg.grid5000.fr"
    "nodeset": "engelbourg",
    "operating_system": {
    "cstate_driver": "intel_idle",
    "cstate_governor": "menu",
    "ht_enabled": true,
    "pstate_driver": "intel_cpufreq",
    "pstate_governor": "performance",
    "turboboost_enabled": false
    "performance": {
    "core_flops": 25600000000,
    "node_flops": 102400000000
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "cache_l3": 6291456,
    "clock_speed": 1600000000,
    "ht_capable": true,
    "instruction_set": "x86-64",
    "microarchitecture": "Broadwell",
    "microcode": "0x700001c",
    "model": "Intel(R) Pentium(R)",
    "other_description": "Intel(R) Pentium(R) CPU D1517 @ 1.60GHz",
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "forced-deployment-timestamp": 202007300948,
    "postinstall-version": "1.2025040409",
    "standard-environment": "debian11-x64-std"
    "storage_devices": [
    "by_id": "/dev/disk/by-id/wwn-0x502b2a201d1c1b1a",
    "by_path": "/dev/disk/by-path/pci-0000:00:1f.2-ata-1",
    "firmware_version": "L17606",
    "id": "disk0",
    "interface": "SATA",
    "model": "M.2 (S80) 3ME4",
    "size": 128035676160,
    "storage": "SSD",
    "vendor": "Innodisk"
    "supported_job_types": {
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-1"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.2",
    "ip6": "2001:660:4406:a00:2::2",
    "kavlan": false,
    "mac": "00:90:fb:78:0f:12",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-2.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet13",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.2",
    "kavlan": false,
    "mac": "e0:01:a6:a4:4c:fc",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-2-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-2"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.3",
    "ip6": "2001:660:4406:a00:2::3",
    "kavlan": false,
    "mac": "00:90:fb:78:0f:39",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-3.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet14",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.3",
    "kavlan": false,
    "mac": "e0:01:a6:a4:3a:f0",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-3-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-3"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.4",
    "ip6": "2001:660:4406:a00:2::4",
    "kavlan": false,
    "mac": "00:90:fb:78:0e:d7",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-4.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet15",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.4",
    "kavlan": false,
    "mac": "e0:01:a6:a4:36:04",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-4-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-4"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.5",
    "ip6": "2001:660:4406:a00:2::5",
    "kavlan": false,
    "mac": "00:90:fb:78:0f:42",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-5.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet16",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.5",
    "kavlan": false,
    "mac": "e0:01:a6:a4:3c:08",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-5-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-5"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.6",
    "ip6": "2001:660:4406:a00:2::6",
    "kavlan": false,
    "mac": "00:90:fb:76:cd:89",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-6.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet17",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.6",
    "kavlan": false,
    "mac": "e0:01:a6:a4:4b:e4",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-6-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-6"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.7",
    "ip6": "2001:660:4406:a00:2::7",
    "kavlan": false,
    "mac": "00:90:fb:76:cd:8a",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-7.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet18",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.7",
    "kavlan": false,
    "mac": "e0:01:a6:a4:49:28",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-7-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-7"
    "architecture": {
    "nb_cores": 4,
    "nb_procs": 1,
    "nb_threads": 8,
    "bios": {
    "chassis": {
    "exotic": true,
    "main_memory": {
    "ipmitool": {
    "retries": 5
    "memory_devices": [
    "size": 8589934592,
    "device": "eth0",
    "driver": "igb",
    "enabled": true,
    "ip": "172.16.161.8",
    "ip6": "2001:660:4406:a00:2::8",
    "kavlan": false,
    "mac": "00:90:fb:78:0f:38",
    "mountable": true,
    "mounted": true,
    "name": "enp2s0",
    "network_address": "engelbourg-8.strasbourg.grid5000.fr",
    "rate": 1000000000,
    "sriov": false,
    "switch_port": "Ethernet19",
    "vendor": "Intel"
    "device": "bmc",
    "enabled": true,
    "ip": "172.17.161.8",
    "kavlan": false,
    "mac": "e0:01:a6:a4:3b:7c",
    "management": true,
    "mountable": false,
    "mounted": false,
    "network_address": "engelbourg-8-bmc.strasbourg.grid5000.fr"
    "ht_enabled": true,
    "performance": {
    "processor": {
    "cache_l1": null,
    "cache_l1d": 32768,
    "cache_l1i": 32768,
    "cache_l2": 262144,
    "ht_capable": true,
    "vendor": "Intel",
    "version": "D1517"
    "redfish": true,
    "software": {
    "id": "disk0",
    "storage": "SSD",
    "besteffort": true,
    "deploy": true,
    "max_walltime": 0,
    "queues": [
    "admin",
    "testing"
    "virtual": "ivt"
    "type": "node",
    "uid": "engelbourg-8"
    ......@@ -131,7 +131,7 @@
    "rate": 25000000000,
    "sriov": true,
    "sriov_totalvfs": 128,
    "switch": "gw",
    "switch": "sw-core",
    "switch_port": "Ethernet6",
    "vendor": "Intel"
    ......@@ -171,7 +171,7 @@
    "sriov": true,
    "sriov_totalvfs": 64,
    "switch": "gw",
    "switch_port": "Ethernet8",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet33",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet35",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet9",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet11",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet12",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet20",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet21",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet23",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet24",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet26",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet27",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet29",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet30",
    "vendor": "Intel"
    "sriov": true,
    "switch": "gw",
    "switch_port": "Ethernet32",
    "vendor": "Intel"
    ......@@ -2,14 +2,6 @@
    "alias": [
    "gw-strasbourg"
    "channels": {
    "port-channel1": {
    "kind": "server",
    "port": "port-channel1",
    "rate": 50000000000,
    "uid": "srv-data"
    "ip": "172.16.175.254",
    "ip6": "2001:660:4406:a00::ffff:ffff",
    "kind": "router",
    ......@@ -21,177 +13,94 @@
    "kind": "node",
    "ports": [
    "kind": "channel",
    "kind": "other",
    "snmp_name": "Ethernet0",
    "uid": "port-channel1"
    "uid": "dev-strasbourg"
    "kind": "channel",
    "kind": "other",
    "snmp_name": "Ethernet1",
    "uid": "dev-apornet"
    "kind": "server",
    "kind": "other",
    "snmp_name": "Ethernet2",
    "uid": "pve-1"
    "uid": "stonet-1"
    "kind": "server",
    "kind": "other",
    "snmp_name": "Ethernet3",
    "uid": "pve-2"
    "uid": "ibat-1"
    "kind": "other",
    "snmp_name": "Ethernet4",
    "uid": "wiki-net"
    "kind": "other",
    "snmp_name": "Ethernet5",
    "uid": "strasbourg"
    "kind": "node",
    "port": "eth0",
    "kind": "other",
    "snmp_name": "Ethernet6",
    "uid": "fleckenstein-1"
    "uid": "dev-www"
    "kind": "other",
    "snmp_name": "Ethernet7",
    "uid": "soknet-1"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet8",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet9",
    "uid": "fleckenstein-2"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet11",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet12",
    "uid": "fleckenstein-3"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet14",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet15",
    "uid": "fleckenstein-4"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet17",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet18",
    "uid": "fleckenstein-5"
    "kind": "other",
    "snmp_name": "Ethernet19",
    "uid": "PE-RENATER"
    "kind": "node",
    "port": "eth2",
    "kind": "other",
    "snmp_name": "Ethernet20",
    "uid": "sw-core-oob"
    "kind": "node",
    "port": "eth0",
    "kind": "switch",
    "snmp_name": "Ethernet21",
    "uid": "fleckenstein-6"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet23",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet24",
    "uid": "fleckenstein-7"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet26",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet27",
    "uid": "fleckenstein-8"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet29",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet30",
    "uid": "fleckenstein-9"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet32",
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Ethernet33",
    "uid": "fleckenstein-10"
    "uid": "sw-core"
    "kind": "node",
    "port": "eth2",
    "snmp_name": "Ethernet35",
    "kind": "other",
    "snmp_name": "Ethernet22",
    "uid": "pfsense-icube"
    "rate": 10000000000,
    "snmp_pattern": "Ethernet%PORT%"
    "managed_by_us": true,
    "model": "wedge100bf_32x",
    "serial": "AM26029251",
    "model": "Juniper EX4600-40F",
    "site": "strasbourg",
    "snmp_community": "Unknown",
    "type": "network_equipment",
