Commit 99ec32ef authored by Vidal WATAT's avatar Vidal WATAT
[sophia] update json
parent e44502ab
...@@ -66,7 +66,7 @@ ...@@ -66,7 +66,7 @@
"enabled": true, "enabled": true,
"interface": "Myrinet", "interface": "Myrinet",
"ip": "172.18.47.136", "ip": "172.18.47.136",
"ip6": "fe80::fe80::260:ddff:fe47:49b7", "ip6": "fe80::260:ddff:fe47:49b7",
"mac": "00:60:dd:47:49:b7", "mac": "00:60:dd:47:49:b7",
"management": false, "management": false,
"mountable": true, "mountable": true,
...@@ -2599,7 +2599,7 @@ chinqchint-36: ...@@ -2599,7 +2599,7 @@ chinqchint-36:
mounted: true mounted: true
rate: 10000000000 rate: 10000000000
mac: 00:60:dd:47:49:b7 mac: 00:60:dd:47:49:b7
ip6: fe80::fe80::260:ddff:fe47:49b7 ip6: fe80::260:ddff:fe47:49b7
management: false management: false
enabled: true enabled: true
interface: Myrinet interface: Myrinet
