GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
861be85c
861be85c
8 years ago
MICHON Nicolas
Downloads
Patches
[dev] Added wiki oar_properties generator
a0e0cbea
3
3 changed files
generators/wiki/mw_utils.rb
+23
-1
23 additions, 1 deletion
generators/wiki/oar_properties.rb
+219
219 additions, 0 deletions
generators/wiki/wiki_generator.rb
+5
-2
5 additions, 2 deletions
247 additions
3 deletions
23
861be85c
@@ -2,6 +2,7 @@ require 'open-uri'
require
'uri'
require
'uri'
require
'net/http'
require
'net/http'
require
'net/https'
require
'net/https'
require
'mediawiki_api'
#Adding method to mediawiki_api client
module
MediawikiApi
module
MediawikiApi
@@ -27,6 +28,14 @@ module MediawikiApi
#Defines global Grid5000 helpers (TODO move to its own file once it is big enough)
module
G5K
SITES
%w{grenoble lille luxembourg lyon nancy nantes rennes sophia}
#Defines MediaWiki helpers
module
MW
module
MW
@@ -48,6 +57,10 @@ module MW
LINE_FEED
\n
LINE_FEED
\n
LIST_ITEM
NUMBERED_LIST_ITEM
HTML_LINE_FEED
"<br />"
HTML_LINE_FEED
"<br />"
def
self
generate_table
table_options
columns
rows
def
self
generate_table
table_options
columns
rows
@@ -86,8 +99,17 @@ module MW
def
self
italic
text
def
self
italic
text
text
text
def
self
bold
text
def
self
bold
text
text
text
def
self
heading
text
level
level
text
level
def
self
code
text
"<code>"
text
"</code>"
This diff is collapsed.
219
861be85c
require
'pp'
require_relative
'../lib/input_loader'
require_relative
'../oar-properties/lib/lib-oar-properties'
require_relative
'./wiki_generator'
require_relative
'./mw_utils'
class
OarPropertiesGenerator
WikiGenerator
def
initialize
page_name
super
page_name
#Static information about properties that cannot be infered from ref-api data
@@properties
"cluster_priority"
"description"
"The priority of this resource for job scheduling"
"besteffort"
"description"
"Can the resource be reserved in besteffort mode ?"
"value_type"
"Boolean"
"deploy"
"description"
"Can the resource be used for a deployment ?"
"value_type"
"Boolean"
"virtual"
"description"
"Node virtualization capacity"
"production"
"description"
"Is this resource available in production queue ?"
"value_type"
"Boolean"
"cluster"
"description"
"The name of the cluster the resource is part of"
"core"
"description"
"The ID of the CPU core the resource is part of. The unique scope is the OAR server."
"possible_values"
"1, 2, 3, ..."
"cpu"
"description"
"The ID of the CPU the resource is part of. The unique scope is the OAR server. "
"possible_values"
"1, 2, 3, ..."
"host"
"description"
"A user-friendly name for the network_address property"
"possible_values"
"edel-1.grenoble.grid5000.fr, ..."
"ip"
"description"
"The IPv4 address of the node the resource is part of"
"network_address"
"description"
"The full hostname of the node the resource is part of"
"possible_values"
"switch"
"description"
"On what switch the resource is directly connected ?"
"nodemodel"
"description"
"The type of the chassis"
"cpuarch"
"description"
"What CPU architecture resource's CPU is member of ?"
"cpucore"
"description"
"The number of core per CPU"
"cputype"
"description"
"What processor's family resource's CPU is member of"
"cpufreq"
"description"
"The frequency in GHz of resource's CPU"
"cpucount"
#Unused ?
"description"
"The number of CPUs"
"eth_count"
"description"
"The number of Ethernet interface the node has"
"eth_rate"
"description"
"The rate of the connected Ethernet interface"
"ib"
"description"
"The technology of the infiniband interface"
"ib_count"
"description"
"The number of Infiniband interfaces available"
"ib_rate"
"description"
"The rate of the connected infiniband interface"
"myri"
"description"
"The type of Myrinet interfaces available"
"myri_count"
"description"
"The number of Myrinet interfaces available"
"myri_rate"
"description"
"The rate of the connected Myrinet interface"
"disktype"
"description"
"What disk's interface family node's disk is member of ?"
"memcpu"
"description"
"The amount of memory in MB per CPU"
"memcore"
"description"
"The amount of memory in MB per CPU core"
"memnode"
"description"
"The amount of memory in MB of the node"
"gpu"
"description"
"The type of GPU available"
"gpu_count"
"description"
"The number of GPU cards available"
"wattmeter"
"description"
"The type of wattmeter available"
#Group properties by categories
@@categories
"Job-related properties"
"besteffort"
"deploy"
"production"
"cluster_priority"
"Hierarchy"
"cluster"
"cpu"
"core"
"host"
"network_address"
"ip"
"switch"
"Hardware"
"gpu"
"gpu_count"
"memnode"
"memcore"
"memcpu"
"disktype"
"myri_rate"
"myri_count"
"myri"
"ib_rate"
"ib_count"
"ib"
"eth_rate"
"eth_count"
"cpucount"
"cpufreq"
"cputype"
"cpucore"
"cpuarch"
"virtual"
"Miscellaneous"
"wattmeter"
"nodemodel"
#Existing properties that won't be documented
@@ignored_properties
"maintenance"
"state"
"max_walltime"
"ip_virtual"
def
get_nodes_properties
site_uid
site
properties
site
'clusters'
each
do
cluster_uid
cluster
cluster
'nodes'
each
do
node_uid
node
begin
properties
node_uid
get_node_properties
cluster_uid
cluster
node_uid
node
rescue
MissingProperty
e
puts
"Error while processing node
node_uid
e
return
properties
def
get_value_type
prop
values
if
@@properties
prop
"value_type"
return
@@properties
prop
"value_type"
if
values
empty?
case
values
class
name
when
"Fixnum"
return
"Integer"
when
"TrueClass"
"FalseClass"
return
"Boolean"
"String"
def
generate_content
refapi
load_yaml_file_hierarchy
File
expand_path
"../../input/grid5000/"
File
dirname
__FILE__
#Properties generated from oar-properties generator
props
G5K
SITES
each
site_uid
props
site_uid
site_uid
refapi
"sites"
site_uid
#Compiled properties used to generate page
oar_properties
props
each
site
site_props
site_props
each
node_uid
node_props
node_props
each
property
value
next
if
include?
property
oar_properties
property
oar_properties
property
"values"
oar_properties
property
"values"
value
unless
value
nil?
oar_properties
property
"values"
uniq!
oar_properties
property
"values"
sort!
a
b
a
b
oar_properties
each
prop
prop_hash
#Limit possible values to 20 elements
prop_hash
"values"
slice!
@generated_content
"Properties on resources managed by OAR allow users to select them according to their experiment's characteristics."
MW
LINE_FEED
@generated_content
MW
heading
"OAR Properties"
MW
LINE_FEED
@@categories
each
cat
cat_properties
@generated_content
MW
heading
cat
2
MW
LINE_FEED
cat_properties
each
property
values
oar_properties
property
"values"
rescue
@generated_content
MW
heading
MW
code
property
3
MW
LINE_FEED
@generated_content
@@properties
property
"description"
MW
LINE_FEED
value_type
get_value_type
property
values
@generated_content
MW
LIST_ITEM
" Value type: "
MW
code
value_type
MW
LINE_FEED
possible_values
@@properties
property
"possible_values"
values
join
@generated_content
MW
LIST_ITEM
" Possible values: "
MW
code
possible_values
MW
LINE_FEED
generator
new
"Generated/OAR_Properties"
options
WikiGenerator
parse_options
if
options
WikiGenerator
exec
generator
options
5
2
861be85c
@@ -70,7 +70,7 @@ class WikiGenerator
options
:update
true
options
:update
true
opts
on
p
'--print'
'Print the new generated content on stdout'
do
opts
on
o
'--print'
do
options
:print
true
options
:print
true
@@ -90,9 +90,12 @@ class WikiGenerator
#Execute actions on generator based on given options
def
self
exec
generator
options
def
self
exec
generator
options
generator
login
options
generator
generate_content
generator
generate_content
#Login only if we need to
if
options
:diff
options
:update
generator
login
options
if
options
:diff
if
options
:diff
generator
diff_page
generator
diff_page
Loading
Save comment
