Attention une mise à jour du serveur va être effectuée le vendredi 16 avril entre 12h et 12h30. Cette mise à jour va générer une interruption du service de quelques minutes.
Commit 834c8f9c authored by MICHON Nicolas's avatar MICHON Nicolas
[grenoble] Added mounted,mountable,enabled properties to yeti-ib0
parent d7e6a206
...@@ -114,6 +114,7 @@ ...@@ -114,6 +114,7 @@
"device": "ib0", "device": "ib0",
"driver": "hfi1", "driver": "hfi1",
"enabled": true,
"firmware_version": 1.24, "firmware_version": 1.24,
"guid": "0x00117501017beaee", "guid": "0x00117501017beaee",
"interface": "Omni-Path", "interface": "Omni-Path",
...@@ -122,7 +123,10 @@ ...@@ -122,7 +123,10 @@
"mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:7b:ea:ee", "mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:7b:ea:ee",
"management": false, "management": false,
"model": "Omni-Path HFI Silicon 100 Series [discrete]", "model": "Omni-Path HFI Silicon 100 Series [discrete]",
"mountable": true,
"mounted": true,
"name": "ib0", "name": "ib0",
"network_address": "yeti-1-ib0.grenoble.grid5000.fr",
"rate": 100000000000, "rate": 100000000000,
"vendor": "Intel" "vendor": "Intel"
"enabled": true,
"guid": "0x00117501017b005e", "guid": "0x00117501017b005e",
"mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:7b:00:5e", "mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:7b:00:5e",
"mountable": true,
"mounted": true,
"network_address": "yeti-2-ib0.grenoble.grid5000.fr",
"enabled": true,
"guid": "0x00117501017b0b94", "guid": "0x00117501017b0b94",
"mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:7b:0b:94", "mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:7b:0b:94",
"mountable": true,
"mounted": true,
"network_address": "yeti-3-ib0.grenoble.grid5000.fr",
"enabled": true,
"guid": "0x001175010178447b", "guid": "0x001175010178447b",
"mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:78:44:7b", "mac": "80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:78:44:7b",
"mountable": true,
"mounted": true,
"network_address": "yeti-4-ib0.grenoble.grid5000.fr",
...@@ -34967,6 +34967,7 @@ ...@@ -34967,6 +34967,7 @@
"enabled": true,
...@@ -34975,7 +34976,10 @@ ...@@ -34975,7 +34976,10 @@
"mountable": true,
"mounted": true,
...@@ -35197,6 +35201,7 @@ ...@@ -35197,6 +35201,7 @@
"enabled": true,
...@@ -35205,7 +35210,10 @@ ...@@ -35205,7 +35210,10 @@
"mountable": true,
"mounted": true,
...@@ -35427,6 +35435,7 @@ ...@@ -35427,6 +35435,7 @@
"enabled": true,
...@@ -35435,7 +35444,10 @@ ...@@ -35435,7 +35444,10 @@
"mountable": true,
"mounted": true,
...@@ -35657,6 +35669,7 @@ ...@@ -35657,6 +35669,7 @@
"enabled": true,
...@@ -35665,7 +35678,10 @@ ...@@ -35665,7 +35678,10 @@
"mountable": true,
"mounted": true,
...@@ -41,6 +41,10 @@ nodes: ...@@ -41,6 +41,10 @@ nodes:
enabled: false enabled: false
mountable: false mountable: false
mounted: false mounted: false
ib0:
enabled: true
mountable: true
mounted: true
storage_devices: storage_devices:
sda: sda:
interface: SAS interface: SAS
