Commit 7edfbafd authored by Cyril Rohr's avatar Cyril Rohr
Added network interfaces to genepi nodes.
parent 86f388ef
...@@ -9,7 +9,19 @@ ...@@ -9,7 +9,19 @@
"virtual_size": null "virtual_size": null
"network_adapters": [ "network_adapters": [
"enabled": true,
"interface": "InfiniBand 10G",
"ip": "172.16.16.1",
"network_address": "genepi-1.grenoble.grid5000.fr",
"rate": 10000000000,
"switch": null
"enabled": false,
"interface": "Ethernet",
"rate": 1000000000
"operating_system": { "operating_system": {
"name": null, "name": null,
"enabled": true,
"ip": "172.16.16.10",
"network_address": "genepi-10.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.11",
"network_address": "genepi-11.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.12",
"network_address": "genepi-12.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.13",
"network_address": "genepi-13.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.14",
"network_address": "genepi-14.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.15",
"network_address": "genepi-15.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.16",
"network_address": "genepi-16.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.17",
"network_address": "genepi-17.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.18",
"network_address": "genepi-18.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.19",
"network_address": "genepi-19.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.2",
"network_address": "genepi-2.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.20",
"network_address": "genepi-20.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.21",
"network_address": "genepi-21.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.22",
"network_address": "genepi-22.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.23",
"network_address": "genepi-23.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.24",
"network_address": "genepi-24.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.25",
"network_address": "genepi-25.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.26",
"network_address": "genepi-26.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.27",
"network_address": "genepi-27.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.28",
"network_address": "genepi-28.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.29",
"network_address": "genepi-29.grenoble.grid5000.fr",
"switch": null
"enabled": false,
"rate": 1000000000
"enabled": true,
"ip": "172.16.16.3",
"network_address": "genepi-3.grenoble.grid5000.fr",
