GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
grid5000
reference-repository
7cfd57f2
7cfd57f2
Jérémie Gaidamour
[dev] oar-properties.rb convert boolean and float to string
3db7ba9c
generators/oar-properties/lib/lib-oar-properties.rb
7cfd57f2
@@ -97,6 +97,17 @@ def get_node_properties(cluster_uid, cluster, node_uid, node)
h
'max_walltime'
# default
h
'max_walltime'
# default
h
'max_walltime'
node
'supported_job_types'
'max_walltime'
if
node
node
has_key?
'max_walltime'
h
'max_walltime'
node
'max_walltime'
if
node
node
has_key?
'max_walltime'
# convert booleans to YES/NO string
h
each
k
v
if
v
true
h
k
'YES'
elsif
v
false
h
k
'NO'
elsif
v
is_a?
Float
h
k
v
return
h
return
h
