GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
grid5000
reference-repository
762cce70
762cce70
Jérémie Gaidamour
[dev] minor
5598e167
dev/run-g5kchecks/run-g5kchecks.rb
762cce70
# This script reserves nodes and then runs g5k-check as root using the g5kadmin credentials.
# Usage: cd run-g5kcheck; ruby run-g5kchecks.rb
; ruby postprocessing.rb
# - You can edit the node reservation at the beginning of the script (or create reservation manually).
# - The script will run g5k-checks on every nodes that have been reserved.
Supports
