Commit 62d05e6d authored by Lucas Nussbaum's avatar Lucas Nussbaum
Do not run rake valid:homogeneity
parent 0df5322e
Pipeline #93984 passed
...@@ -26,7 +26,6 @@ validate-data: ...@@ -26,7 +26,6 @@ validate-data:
- /usr/sbin/update-ca-certificates - /usr/sbin/update-ca-certificates
- rake valid:schema - rake valid:schema
- rake valid:duplicates - rake valid:duplicates
- rake valid:homogeneity
generate-reference-api: generate-reference-api:
stage: generate stage: generate
