Commit 515680f0 authored by Pierre Neyron's avatar Pierre Neyron :bicyclist:
[gen/wiki/oar] Rework descriptions
parent 99839392
1 merge request!100Update the OAR-Properties wiki page
......@@ -47,7 +47,7 @@ class OarPropertiesGenerator < WikiGenerator
"possible_values" => "1, 2, 3, ..."
"cpuset" => {
"description" => "CPU hardware identifier (useful for gnu-parallel).",
"description" => "Logical processor identifier (only the first thread in case of HyperThreading).",
"possible_values" => "0, 1, 2, 3, ..."
"disk" => {
......@@ -63,18 +63,18 @@ class OarPropertiesGenerator < WikiGenerator
"gpudevice" => {
"description" => "GPU hardware identifier (useful for gnu-parallel).",
"description" => "GPU device identifier.",
"possible_values" => "0, 1, 2, 3"
"host" => {
"description" => "The full hostname of the node the resource is part of",
"description" => "The full hostname of the node the resource is part of.",
"possible_values" => "dahu-1.grenoble.grid5000.fr, ..."
"ip" => {
"description" => "The IPv4 address of the node the resource is part of"
"network_address" => {
"description" => "The full hostname of the node the resource is part of (deprecated, please use host instead)",
"description" => "The full hostname of the node the resource is part of, please use 'host' instead.",
"slash_[16-22]" => {
......@@ -177,7 +177,7 @@ class OarPropertiesGenerator < WikiGenerator
"possible_values" => "kavlan-topo, storage, disk, kavlan-local, kavlan-global, default, subnet, kavlan"
"expiry_date" => {
"description" => "Expiration datefor the given resource. (g5k internal property)",
"description" => "Expiration date for the given resource.",
"possible_values" => "0"
"comment" => {
......@@ -185,7 +185,7 @@ class OarPropertiesGenerator < WikiGenerator
"possible_values" => "Retired since 2018-01-30: retired_cluster, PSU Dead, Retired"
"maintenance" => {
"description" => "Is this resource under maintenance ? (g5k internal property)",
"description" => "Is this resource under maintenance ?",
"value_type" => "Boolean",
"possible_values" => "YES, NO"
