Commit 50c001df authored by Jonathan Pastor's avatar Jonathan Pastor
add more spec tests for the generator to increase coverage
parent c3b96a5f
1 merge request!6WIP: Features/oar gpus
......@@ -1783,4 +1783,294 @@ TXT
expect(generator_output[:stdout]).to include(expected_output2)
context 'interracting with a configured OAR server (msising network interfaces)' do
before do
prepare_stubs("dump_oar_api_configured_server.json", "load_data_hierarchy_stubbed_data_missing_main_network_property.json")
it 'should propose a correction' do
uri = URI(conf["uri"])
response = Net::HTTP.get(uri)
expect(response).to be_an_instance_of(String)
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:site => "fakesite",
:clusters => ["clustera"],
:verbose => 2
expected_output = <<-TXT
Error (missing property) while processing node clustera-1: Node clustera-1 does not have a main network_adapter (ie. an ethernet interface with enabled=true && mounted==true && management==false)
TXT
expected_output2 = <<-TXT
*** Error: The following nodes exist in the OAR server but are missing in the reference-repo: clustera-1.
TXT
generator_output = capture do
generate_oar_properties(options)
expect(generator_output[:stdout]).to include(expected_output)
context 'interracting with a configured OAR server (wrong variable type for gpu)' do
before do
prepare_stubs("dump_oar_api_configured_server_wrong_vartype.json", "load_data_hierarchy_stubbed_data.json")
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:verbose => 2
Output format: [ '-', 'key', 'value'] for missing, [ '+', 'key', 'value'] for added, ['~', 'key', 'old value', 'new value'] for changed
clustera-1:
["~", "eth_rate", "10", 10]
TXT
Error: the OAR property 'eth_rate' is a 'String' on the fakesite server and this script uses 'Fixnum' for this property.
TXT
context 'interracting with a configured OAR server (different_values for wattmeters)' do
before do
prepare_stubs("dump_oar_api_configured_server.json", "load_data_hierarchy_stubbed_data_wattmeters_variations.json")
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:verbose => 2
clustera-1:
["~", "wattmeter", "MULTIPLE", "YES"]
clustera-2:
["~", "wattmeter", "MULTIPLE", "NO"]
TXT
context 'interracting with a configured OAR server (no wattmeters)' do
before do
prepare_stubs("dump_oar_api_configured_server.json", "load_data_hierarchy_stubbed_data_wattmeters_nil.json")
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:verbose => 2
clustera-1:
clustera-2: same modifications as above
TXT
context 'interracting with a configured OAR server (with missing property)' do
before do
prepare_stubs("dump_oar_api_configured_server_missing_property.json", "load_data_hierarchy_stubbed_data.json")
it 'should propose a correction (verbose=1)' do
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:verbose => 1
clustera-1:["ib_rate"]
clustera-2:["ib_rate"]
Properties that need to be created on the fakesite server: ib_rate
TXT
it 'should propose a correction (verbose=2)' do
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:verbose => 2
["+", "ib_rate", 0]
TXT
it 'should propose a correction (verbose=3)' do
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
:verbose => 3
"new values": {
"ip": "172.16.64.2",
"cluster": "clustera",
"nodemodel": "Dell PowerEdge T640",
"switch": "gw-fakesite",
"virtual": "ivt",
"cpuarch": "x86_64",
"cpucore": 8,
"cputype": "Intel Xeon Silver 4110",
"cpufreq": "2.1",
"disktype": "SATA",
"eth_count": 1,
"eth_rate": 10,
"ib_count": 0,
"ib_rate": 0,
"ib": "NO",
"opa_count": 0,
"opa_rate": 0,
"opa": "NO",
"myri_count": 0,
"myri_rate": 0,
"myri": "NO",
"memcore": 8192,
"memcpu": 65536,
"memnode": 131072,
"gpu_count": 4,
"mic": "NO",
"wattmeter": "MULTIPLE",
"cluster_priority": 201906,
"max_walltime": 86400,
"production": "YES",
"maintenance": "NO",
"disk_reservation_count": 0
TXT
This diff is collapsed.
