Commit 4bade482 authored by SAINT-MARCEL Frederic's avatar SAINT-MARCEL Frederic
[grenoble] fix dahu-2 configuration
parent cb93cccc
...@@ -145,4 +145,4 @@ ...@@ -145,4 +145,4 @@
"type": "node", "type": "node",
"uid": "dahu-2" "uid": "dahu-2"
\ No newline at end of file
...@@ -17,7 +17,11 @@ dahu-2: ...@@ -17,7 +17,11 @@ dahu-2:
main_memory: main_memory:
ram_size: 206158430208 ram_size: 206158430208
network_adapters: network_adapters:
enp24s0f0: bmc:
ip: 172.17.20.2
mac: 50:9a:4c:78:e8:d1
management: true
eth0:
driver: i40e driver: i40e
firmware_version: 5.40 0x80002d39 18.0.17 firmware_version: 5.40 0x80002d39 18.0.17
interface: Ethernet interface: Ethernet
...@@ -28,7 +32,7 @@ dahu-2: ...@@ -28,7 +32,7 @@ dahu-2:
name: enp24s0f0 name: enp24s0f0
rate: 10000000000 rate: 10000000000
vendor: Intel vendor: Intel
enp24s0f1: eth1:
...@@ -37,14 +41,6 @@ dahu-2: ...@@ -37,14 +41,6 @@ dahu-2:
model: Ethernet Controller X710 for 10GbE SFP+ model: Ethernet Controller X710 for 10GbE SFP+
name: enp24s0f1 name: enp24s0f1
ib0:
driver: hfi1
guid: 80:00:00:02:fe:80:00:00:00:00:00:00:00:11:75:01:01:71:10:1a
interface: InfiniBand
management: false
model: Omni-Path HFI Silicon 100 Series [discrete]
rate: 100000000000
vendor: Intel
operating_system: operating_system:
cstate_driver: intel_idle cstate_driver: intel_idle
cstate_governor: menu cstate_governor: menu
...@@ -64,7 +60,6 @@ dahu-2: ...@@ -64,7 +60,6 @@ dahu-2:
model: Intel Xeon model: Intel Xeon
other_description: Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz other_description: Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
version: Gold 6130
storage_devices: storage_devices:
sda: sda:
by_id: "/dev/disk/by-id/wwn-0x5002538c0010aad8" by_id: "/dev/disk/by-id/wwn-0x5002538c0010aad8"
